Portable AC/Heater has "Stop" indicator flashing. After using the dehumidifier.
  • JourneyNC Jul 30, 2008
    I thought I purchased a self evaporating unit. With the dehumidifier, I have to continually release water, which was full at the time the "Stop" indicator lit up. Thanks a bunch!
    Genius:
  • 1,027 Answers
The internal water bucket may be full.
Posted on Jul 26, 2008
Haier CPN12XH9 Portlable Air Conditioner/Heater - The upper water plug (which I can't find a picture of on any manual) accumulates water while the lower tank (where water should be) is dry. Unit is only...
Not up on the unit, but water condenses on the evaporator of an a/c unit dropping onto a tray, as self evaporating, would assume that the drain from that tray is fed to the top of the compresor, which will have a tray around the top, heat from the compressor will evaporate the water, same as with a fridge. In dehumidifier mode, water would need to be collected, rather than evaporated back into the atmosphere, defeats the object other wise. so is lower tank around compressor? that would be for a/c mode upper tank for dehumidifier
Aug 05, 2014 | Haier CPN12XH9 12,000 btu Portable AC Air...
Using as heater and unit is blowing cold air
A heat pump is an air conditioner that reverses its refrigerant flow. In the cooling mode, the evaporator is cold to the room and its condenser is hot. In the heating mode, a valve reverses the refrigerant flow and makes the evaporator warm and the condenser cold.
Nov 24, 2013 | Soleus 10,000 Btu Portable Ac Air...
Using heater...cold air out of the back
With heat pumps that's the way they work. In heat mode they are using the evaporator as the condenser and it blows heat out the front and cold out the back. In cooling mode, a reversing valve switches the gas flow reversing the operation of the coils and it blows cold out the front and heat out the back.
Flashing AC Adaptor
Is the battery any good? A bad battery will cause erratic operation of adapter/charger.
Jun 10, 2017 | Samsung Kitchen Ranges
AC stopped working - only flashes "PF" now.
I found the instructions call 1800 322 3848... My just said the same thing
Sep 10, 2012 | Kenwood PAC C130EK 13000 BTU Portable Room...
LG 1210 BXR portable air conditioner collecting water on "cool" setting. How do you fix this?
In AC mode, the unit still has some dehumidifying properties. So, it may be that there is more humidity in the air this Summer, than in prior years. Having to empty the tank every 24 hours is not unusual. Be sure that the air intake filter is clean & check the exhaust hose for obstructions.
Hope this helped you & thanks fr choosing FixYa.
Aug 13, 2011 | LG LP1200DXR Portable Air Conditioner
My Danby DPAC1010 Portable Air Conditioner is dehumidifying when simply in AC mode. I don't want it to, but if fills up a 2 gallon bucket every 2-3 days. I've had it overflow twice and I cannot...
The only way to stop it from dehumidifying is to stop it. A dehumidifier is a AC that is 'tuned poorly'. In your machine, while in dehumidify mode, you actually are running the AC in 'slow".
It is a law of physics. Warm air can hold moisture. Cold air can not hold moisture. When you remove the heat from the air, the water has to go somewhere, so it condenses on the coils and drips into the tank. Yes, that is true: Heat is a thing, you have to remove heat from the air. You don't simply "cool it", you remove the heat.
Your Danby should have a automatic shut off that comes into play when the condensate tank gets full. MY Danby, which is a sllightly different model than yours, has a connection that allows me to connect a hose that I lead to a floor drain to disponse of the condensate (water).
If yours is not equipped with a shut off nor a drain and you say it fills every 2 to 3 days, the options I see that you have is to dump it every day, or - don't run it all the time, or - turn the setting to a higher number which will reduce the AC and dehumidifying effect. On the down side of that, your humidity will remain high at the higher setting.
Thanks for your question @ FixYa.com and thanks for letting me assist you this evening.
Jun 29, 2011 | Heating & Cooling
How do I get my LG 12000 BTU ac/dehumidifier to dehumidify
This is a quote from the manufacturer.
Dry mode is used to remove humidity from the room
without additional cooling. Once the set temperature
is reached, the compressor and circulation fan turns
off and only the exhaust fan will run. Fan speed is
pre-set and cannot be adjusted.
Apr 24, 2011 | LG LP1200DXR Portable Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
