My tv changes channels at random and sometimes won't stop
  • 520 Answers
Try taking the batteries out of the remote. The channel buttons may be sticking.
Posted on Jul 25, 2008
Wont stop changing channels
Check and replace the main system memory IC. It is faulty. It is a very small IC, won't cost more. An eight solder terminal IC. Even though the physical size is small, function to it when the TV works is great. The work is a skilled one.
Jul 29, 2012 | Emerson LC320EMXF 32 in. LCD TV
Sceptre TV unexpectedly changes input source away from HDMI
My sceptre tv just started randomly changing through input modes, sometimes once or twice before stopping and sometimes it continues
Jun 30, 2012 | Sceptre X405BV-FHD3 40 in. LCD HDTV
Won't stop changing channels
The memorey IC to your TV is faulty. It can be located near to main systtem control IC. If you have sound knoledge in electronics, locate it and replace it.
May 08, 2012 | Televison & Video
My LG LCD TV cant stop changing channels on it own . I ve removed the batteries from the remote but still its changing them on its own
Is it going one way - channel 1-2-3-4-5 bottom to up or any way at random. Find out which way and check the channel button on the TV to see if it is stuck.
Mar 17, 2011 | LG 37LD450 37 in. TV
My tv randomly turns on, and changes the channel... i have tried everything to get it to stop and cant, and now it just goes between channel 3 and 44 randomly
Hi my name is Roety,
I can help you with your issue ,
You either have a stuck button or a bad main board.
Running the autoscan / autoprogram with a good signal sometimes locks the TV processor to the received channels only.
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
Dec 01, 2009 | Televison & Video
I'm having difficulities with a RCA entertainment series television. A little while ago my T.V started going crazy. For example, Sometimes when i go to turn it on to change the channel it will say panel...
Best Way reset the set,U right it well reboot itself,before u go to sleep unplug the tv,take out the bateries to remote.Morning,plug in and put the bateris back might reset it self.
Aug 17, 2009 | RCA 32F531T 32" TV
Vizio 42" LCD - Random appearance of small black rectangles
There is a processing fault that is starting to occure. What you are seeing is a type of aliasing. This can be in the main signal processing or in one of the control areas.
The set will require service. The service rep will test the set by using board substitution. There are typicaly a number of areas in the TV set that can cause this type of fault. Once the defective board is located the fault will be easy to service with a simple board swap and some adjustments.
If the set is out of warranty, it may be expensive to service. With many of the no-name brands, spare parts can be difficult or impossible to have.
Jerry G.
Jan 02, 2009 | Vizio L32 32 in. LCD HDTV
Channel changes automatically
There are a few things that can cause this. #1 most often cause is either something spilled on the channel button or something wrong with the bezel where the buttons are located causing the button to be pressed all the time. Check the buttons on the tv and make sure none of them are stuck. #2 is a bad button (switch). Replace the switch or the control board. #3 is a short on the wiring harness going from the switch to the mian board. Maybe it's squished against the frame somewhere. #4 would be a bad main board. You will likely have to take this unit to a service centre to have it looked at.
Apr 14, 2008 | ViewSonic NextVision N2010 20 in. LCD...
Ghosts?
re- program...................................................
Jan 25, 2008 | RCA F32450 32" TV
Turn tv on, and it scrolls through the channels
Had the same problem, channels would not stop scrolling.
It was as though someone had there finger on the channel up button.
Disconnected the sixth wire, starting with the black wire on the wiring harness for the front buttons, on/off, ch. up/down, vol. up/down, etc.
It works fine, no more unwanted channel surfing!!
Aug 29, 2007 | GE 32GT740 32" TV
Televison & Video Logo
55 people viewed this question
Top Televison & Video Experts
