Question about Gateway Computers & Internet
Monitor on laptop rolling screen syatem check says monitor is fine
    Scholar:
  • 81 Answers
Hi gooby,
Video card - reseat card and boot to see if fixed or has gone bad. If your video card is integrated, then the system board needs replacing.
Monitor screen - need to replace.
One thing you can try is to re-install the video drivers. If this does not work, then the only thing that can be done is replacing the parts formentioned.
Posted on Jul 26, 2008
Toshiba Satellite M300 screen problem
Hi, I can't guaranty this will help the problem, but for a quick try I say its worth it. On the Desktop, right click to open Personalize, select Display Settings; by adjusting the resolution it helps with the "Flicker effect" aswell, by selecting different settings, you can "view" the best Monitor Display. "If the solution helped, rating it is appreciated, thanks."
Mar 28, 2010 | Computers & Internet
In my syatem, start with no display after windows
start windows in vga mode by pressing F8 at starting after POST. then set the resolution of your screen to 800X600 and restart.
Dec 21, 2009 | Intel DG31PR Motherboard
CHEK YOUR pc OR SIGNAL CABALE
You should Check monitor on different system, after that, although if your monitor is ok then you should check your display your System (CPU) restart the syatem and check display in Key-board by pressing Num Lock Key whether on or off, if key is not working so problem in your system not in Monitor, check then reply
I hope that this has been very helpful for you
Dec 01, 2009 | AOpen A75P Monitor
Tower is beeping and monitor on/off switch is blinking
I have not solved the problem of the blinking on off switch, but I have solved the problem of the monitor attached to my laptop waiting so long to start up. I never shut down the computer and I never hibernate it either. I leave it on 24 hours a day.
May 19, 2009 | Acer Computers & Internet
Monitor flickering and rolling
Thanks for the git back: #1 I hooked up a second monitor (depressed fn+f5) and was able to view everything fine. No problem in any area. Ran Some security checks (malwarebytes,checked windows updates,Secunia PSI,and a virus scan. #2 I opened up the monitor and checked for possible loose connections. #3 brought up the graphics display and checked that 60 hrz was set and correct. #4 ran a backup of all my data from my other monitor,and I made the assumption that it was a bad monitor and I might save some money if I just bought a new laptop.Would like to here your comments. Sincerely : dandee4u3
Mar 22, 2009 | Acer Aspire 3690-2196 Notebook
Rolling Waterfall Effect going up my westinghouse LCD monitor
try moving the monitors.
it could be feedback signal.
also try different leads or without switch.
you will then be able to narrow down the problem to one component.
Feb 25, 2009 | Acer AL1711 17" LCD Monitor
Screen
Just turn the monitor off and on,,it should cure the problem,,also,,,tap the space bar on your laptop,,,,also,,you may want to change your settings on your laptop to prevent it going into sleep mode, or standby state,,which is what is causing this problem with your monitor.
Jan 19, 2009 | Hannspree HANNS-G 19" Widescreen Monitor
Acer laptop has developed a fully dark screen
I am assuming that you have tried switching from external monitor output and local monitor. There should be a hot key on the keyboard to switch it. Also, try looking to make sure the driver for the display is up to date. I f it was update recently try rolling the driver back. If you need help with doing any of this post a comment. Hope this has helped some.
Dec 02, 2008 | Acer Aspire 3680 Laptop
HP Pavilion dv9207us DISPLAY PROBLEM [BLUE SCREEN PROBLEM]
safe mode roll back driver if cant roll back uninstall in safe mode, then deleting driver info, so it does not reinstall.
Oct 18, 2008 | HP Pavilion dv9207us PC Notebook
Can a cracked notebook screen be replaced?
you don't have to purchase a new laptop/all you have to do is call your computer manufacture and get the LCD replaced.
or else
you can connect a desktop monitor with your laptop if you have a desktop
as its cracked so only thing we can do is either get the LCD replaced or connect a monitor with it to use your system.
Jun 09, 2008 | Dell Latitude D600 Notebook
Computers & Internet Logo
245 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
