Question about Lexmark X1270 All-In-One InkJet Printer
  • lamador01 Jul 27, 2008
    I also have windows vista and im unable to get this printer to work. I have the cd but I don't even know how to copy with this thing. Please Help!
If you have windows vista the installation cd is not gonna work, go to and down you can see driver downloads download the one of your os and unplug the usb cable and turn the printer off and remove the driver already installed. start the setup you download from the site and then it will ask you to connect the usb cable and turn the printer on, connect the usb cable ant turn the printer on and the setup will continue automatically. and thats it now it will say "Printer Status: Ready" not "Printer Status: Cannot Communicate" hope i helped bye
Posted on Jun 11, 2010
I do not have its disk and I want to download it, so I need help in order to be able to install it without its disk
please send me email that how I can set up it.'
thank you for your nice cooperation at this matter.
yours turly
karim shah
Posted on Jul 27, 2008
Printer write as javascipt
I presume you are using the Lexmark X1270 inkjet printer since you're posting under this model.
It could be that the printer driver on your computer is not properly installed. Try to uninstall your existing printer driver then reinstall using the X1270 driver on the Lexmark website. To uninstall, from your computer, go to Start menu > Programs > Lexmark X1200 Series folder > Tools > Uninstall. After the uninstall process, reboot your pc when prompted.
When the computer turns on, please visit the Lexmark website to download and install the Lexmark X1270 XP Printer Driver on your computer. Select your operating system > click on "FILTER" > click on the driver under Recommended Downloads > download and execute the file. Simply follow the instructions on your computer screen to complete the installation.
Try to print your document again to verify that the problem is fixed now.
Nov 22, 2011 | Lexmark X1270 All-In-One InkJet Printer
My lexmark X1270 Printer is only printing in colour ......wont print in black
It could be that your black cartridge needs cleaning or is not properly seated in the carrier. Open the printer cover and reseat the black cartridge. Close the printer cover. Open Lexmark Solution Center on your computer. Go to Maintenance tab and select Clean to fix horizontal lines. Your printer will then print a test page forcing ink through the nozzles and clean them.
May 31, 2011 | Lexmark X1270 All-In-One InkJet Printer
I have a new computer and have installes the disk
make sure it is set as default printer in the printers menu in your control panel. make sure you rebooted the computer after installing the software. unplug the printer/scanner and let it stand for 30 seconds before plugging it in. change USB ports.
Oct 01, 2009 | Lexmark X1270 All-In-One InkJet Printer
Lexmark x1270 printer not working
Uninstall the software and reinstall it.Most printers must be disconnected from the CPU during insallation of the firmware
Sep 26, 2009 | Lexmark X1270 All-In-One InkJet Printer
Lexmark 1270 scans but will not print
With the Lexmark printers communication subsystem you MUST let the driver ask for you to plug in the printer. DO NOT plug the printer into the USB port until told to do so.
To fix a fouled install :
(1) Uninstall the Lexmark drivers in Add Remove Programs
(2) Shutdown the computer
(3) Disconnect the printer from the USB port
(4) Restart the computer
(5) Run the Driver Installation software
(6) Cancel ALL attempts by windows to auto install the printer
(7) When the sofware asks for the printer connect it and continue
Dec 13, 2008 | Lexmark X1270 All-In-One InkJet Printer
Lexmark 1200 Series
unplug your usb cable,uninstall printer then reinstall
Nov 09, 2008 | Lexmark X1270 All-In-One InkJet Printer
Will not Print
Try a hardware check of the printer first. To check the hardware of the printer, do the following:
  1. Switch off the printer.
  2. Load one sheet of paper into the paper feeder.
  3. Press the Power button and the Paper Feed button at the same time and hold them both down for three seconds. Then release the Power button only.
  4. When the printer begins to print, release the Paper Feed button. A page will be printed. The page should contain some text at the top and a series of horizontal color lines (cyan, magenta and yellow) below the text, with a thick black line below the colored lines. All the lines should be solid.
  5. When the test is complete, switch off the printer. NOTE: If you do not switch off the printer, it will continue to print.
Sep 24, 2008 | Lexmark X1270 All-In-One InkJet Printer
X1270lexmark all in one willnot work any more
nver could get lexmark x1270 printer to work trying several different repairs. replaced printer with hp laser and worked just fine.
Sep 05, 2008 | Lexmark X1270 All-In-One InkJet Printer
Can't get my printer to print
Hello lilltlellulu2,
This is Enday, to solve your problem, try to check if you have installed the ink cartridges properly... If you have installed the software for the printer ,you must restart your system unit inorder to take effect on what changes you as ther hardware to work.
Now, after restarting, click on the control panel, then you can see your printer installed,,right click on the printer icon>properties>print test page...
Just see if its working this time...
Thank you... and Good day...
Jan 26, 2008 | Lexmark X1270 All-In-One InkJet Printer
Lexmark X1270 All-In-One InkJet Printer Logo
111 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
