Question about Whirlpool Calypso GVW9959K Top Load Washer
Rust Stains The clothes are coming out of my calypso washer with rust stains all over them I have tried washer magic which did not solve the problem We have well water & a water conditioner (soft water) but I am not having a problem with any other of my appliances dishwasher etc..Anyone have any ideas on how to stop the rust???
  • prov3560 Jul 26, 2008
    Thanks for responding!!! How do you get access to the recirculating pipe?
    Genius:
  • 1,028 Answers
You will probaly need serviceman..the parts that control the plate in the bottom are starting to corrode and accumilate gunk that is coming back off on clothes replacing them only fix also may ck the recirculating pipe on right rear side of tub gunk can accumilate there also
Posted on Jul 26, 2008
  • oldfixer Jul 28, 2008
    there is a screw behind the whirlpool enblem on the front edge of cabinet..remove the emeblem pry it out remove screw pull top forward and lift up ..remove the white plastic ring around top 1 hose connects to top i thing ring has tabs all the way around ..pry up with fingers and lift ring off the tube back right is the recirculating tube it slides intio bottom of tub and is held in place by a tab that pushes into top of tub..clean and reinstall but although it may help i think the universal/leveler will still need replacing to completely solve problem let me know how it goes thanks
I get what look like rust streaks on my white clothing when I wash them in my washer. The stains do not come out even with straight bleach. RIT rust stain remover will get them out, but there's not...
1. Iron or manganese in the water supply. • Avoid using chlorine bleach on rust stains. It will make them darker and more obvious. • When iron is dissolved in the water, use granular detergent plus a non-precipitating water conditioner, such as Calgon or Spring Rain*. Better results may be obtained by dissolving detergent and water conditioner in the wash before adding the clothes. Be certain that all clothes are down into the water before starting washer. • If the iron is suspended in the water (it will settle out), attach a rust filter to the faucet and inlet hoses or to the water line. • If iron or manganese stains are a recurring problem, the customer may need a special filter or chemical feeder installed in the home to remove these minerals from the water supply. To remove: Launder with RoVer* Rust Remover Part No. 057961 using the directions below: • Top loading washers: a. Fill the washer with water (no detergent), selecting a temperature suitable for the fabric (hot or warm). b. Add 1/3 cup RoVer and let it dissolve by agitation. c. Add clothes and allow washer to complete the cycle. d. Follow up with an additional wash with detergent.
Be sure to check the spin basket for rust spots also.
Jan 16, 2011 | Maytag Centennial 3.2 cu. ft. SuperSize...
Why is my washer leaving black stains on my clothes
It sounds like it might be leaving mold deposits. Try running a cycle with no clothes in it, hot, with a cup of bleach. If the stains are more brown than black, though, that would be rust in the pipes.
Oct 16, 2010 | Kenmore 44102 Front Load Washer
Brown stains in the drum of my whirlpool dryer
Apparently a common problem with 4-5 year old Kenmore and Whirlpool dryers. The paint is rubbed off the back panel by the felt seal attached to the rotating drum. The bare metal gets rusty from the damp clothes. The rust is rubbed off by the felt seal. The entire felt seal will turn brown. The stains are transfered to the clothes. The rust stains can generally be removed by additional cleaning.
I'm going to replace the felt seal on the drum, clean the rust off the back panel and see how long it lasts. Seal w/ adhesive is $30-40.
Some have suggested painting the back panel, but i don't think fresh paint is going to last long. The original paint was probably electrostatically applied and maybe baked on.
Nov 05, 2009 | Dryers
Rust in Kenmore washed clothes
Sounds like you have a bad drum bearing. I would guess that it's grees rather than rust although it will look like rust.
Please rate solution if helpful
Aug 23, 2009 | Kenmore 24032\24036 Top Load Washer
My Frigidaire Washer Leaves Stains all over our clothes
Since this happened from day 1, your water may be the problem. Do you have well water? If so, get a softener system. This will get rid of the iron, which is responsible for rust stains. I really doubt that a new machine would cause rust or grease.
Why didn't you do something five years ago when you first noticed this? It will be much more difficult to get a resolution from the manufacturer after5 years.
Jul 31, 2009 | Frigidaire GLTF2940ES Front Load Washer
How to remove rust stains from driveway.
http://living.aol.com/gmc-trade-secrets/eric-stromer/how-to-fix-driveway-stains-step-by-step
Jul 08, 2009 | Electronics - Others
Rust from washer getting on clothes
Don't let anything sit in the washer. When it's done running, take the clothes out. You can get a product called rust reverser. It has to be applied to a dry surface.
Jun 29, 2009 | Frigidaire ATF6000ES Front Load Washer
Rusty stains on all white clothes washed
I don't think the washer is at fault; the clue is 'Used very little.' I think the rust is originating in the water pipes serving the washer. The only help there is to run one machine with no clothes in it (wasting water) or putting splitters on the faucets and flushing the lines into a sink or other drain. To remove rust stains from WHITE (!) clothing and many synthetics, buy a product named 'Whink.' It is available in many drug stores, super markets, etc. in the area where one finds other laundry items.  It is fairly safe to use (with precautions) but keep out of reach of kids.
Jul 26, 2008 | Kenmore 24032\24036 Top Load Washer
Stains from dryer
rear seal on drum needs replacing front 1 too if it has one the felt seals tend to turn brown and the "rust"will come back off on clothes leaving brown streaks
Jun 30, 2008 | Kenmore Dryers
Rust stains and bleach spots.
I'm sorry but the white spots will be due to bleach. It may be that there was undissolved bleach in the washer after the first load. Maybe some of it came out with the whites and lay in wait in the basket.
I doubt the makers would guarantee anything for 7 years, so no free basket or installation is likely. Seems there is a chip in the enamel and dampness / water from the previous wash days before sits there collecting iron as rust particles.
For the time being you could try rinsing the machine out before the first load. That might prevent the rust marks or reduce them.
May 01, 2008 | Kenmore 22422 Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
140 people viewed this question
Dan Webster
Dan Webster
Sal De
