Question about Dell Inspiron 6000 Notebook
Onboard rj45 quirk?
The system appears to have had a slow rj45. replaced MB, now cant acquire ip address. a tech worked on it and used the rj45 w/ no problem. why is this rj45 not working with a new dell supplied MB? The isp is comcast and there is a usb connection which works ok. I cant see the possible issue with the rj45 port. Diagnostics were done and no problems on the 1394 area. what gives?
  • ray moreau Jul 31, 2008
    the isp/comcast was called and tested with trace route. there were a lot of hops. The problems lies on the isp to solve the connectivity slowness.
    thanks.
    Genius:
  • 2,028 Answers
This could possibly be a driver glitch. Uninstall the drivers from the device manger, then shut down and restart. Make sure the device is attached for the restart. The machine will find it and automatically reinstall the drivers. If this is a driver glitch, then this will clear it. If it doesn't fix it, then get back with me and we'll see what else I can find on the matter.
Posted on Jul 25, 2008
Just install XP PRO sp3 on P4C800 board and current version of 3Com 3C940 onboard LAN. Installation went fine but LAN can not acquired network address and get no or limited connection.Therefore internet...
When your using Internet connection via LAN you need to configure the Internet Protocol (TCP/IP) Properties at the Network Connection Wizard. To configure the Network Connection just follow this steps:
1. Double click the My Computer from your desktop/screen.
2. At the left side of the My Computer menu click the My Network Places then click View Network Connections in the left side of that window also.
3. Double click the Local Area Connection and click Properties.
4. When the Local Area Connection Properties was appear select Internet Protocol (TCP/IP) then click Properties.
5. The Internet Protocol (TCP/IP) Properties are also apear, then click Use the following IP address and fill-up the following: IP Address, Subnet Mask, Default Gateway, Preferred DNS Server and Alternate DNS Server.
6. After all you fill-up click OK Button.
Note: Make sure that the IP Address you fill-up in your network connection are not the same with the other computer to avoid conflict. Just copy the configuration on the computer like: Subnet Mask, Default Gateway, Preferred DNS Server and Alternate DNS Server. Only the IP Address are unique to the other computer. Example; 192.168.0.5 that is the IP Address of last computer are connected in the network. The IP Address you able to use is 192.168.0.6, only the last digit of the IP Address your going to change.
Jun 04, 2010 | ASUS P4C800 Deluxe Motherboard
Tip
IP Conflicts in a work place
An IP address conflict occurs when two computers on a LAN or the Internet have been assigned the same IP. IP conflicts between two computers normally render either one or both of them unusable for network operations.
How IP Address Conflicts Happen
Two computers can acquire conflicting IP addresses in any of several ways:
· A system administrator assigns two computers on the LAN the same Static IP Address.
· A system administrator assigns a computer a static IP address within the local network's DHCP range (dynamic IP range), and the same address is automatically assigned by the LAN DHCP server.
· A malfunction in the network's DHCP server allows the same dynamic address to automatically be assigned to multiple computers.
· An ISP accidentally assigns two customers the same IP address (either statically or dynamically).
· A mobile computer is put into standby / hibernate mode and then awakened later.
Note that other forms of IP conflicts can also occur on a network. For example, one computer may experience an IP address conflict with itself if that computer is configured with multiple Network Adapters. System administrators may also create IP conflicts by accidentally connecting two ports of a network switch or router to each other.
Recognizing IP Address Conflicts
On most Microsoft Windows computers, if you attempt to set a fixed (static) IP address that is already active on the local network, you will receive the following pop-up error message:
The static IP address that was just configured is already in use on the network. Please reconfigure a different IP address.
On newer Microsoft Windows computers having dynamic IP conflicts, you should receive a balloon error message in the Taskbar as soon as the operating system detects the issue:
There is an IP address conflict with another system on the network.
Sometimes, especially on older Windows computers, a message similar to the following may instead appear in a pop-up window:
The system has detected a conflict for IP address...
On Mac or Linux computers, a similar message will normally appear on screen.
Resolving IP Address Conflicts
Try the following remedies for IP conflicts:
1. For networks where IP addresses are fixed (statically assigned), ensure each local host is configured with a unique IP address.
2. If your computer has a dynamically assigned address, releasing and renewing its IP address can workaround IP address conflicts.
3. If your home router is believed to have a faulty DHCP server causing IP conflicts on the home network, upgrading the router firmware may resolve this problem.
on Nov 24, 2010 | Computers & Internet
Cannot aquire ip address from wireless router
Hi, If your newer usb wireless adaptor does not have the same settings as your router this is the problem you have. First make sure you have installed the cd software that came with the usb adaptor without it plugged in. After that is complete make sure the wireless adaptor is seen by the computer it is attached to. Then you need to open the settings of the usb adaptor and set it up same as your router's settings. This includes the WEP security password if you use it. Good Luck.
Sep 19, 2009 | Linksys WUSB54GC 802.11g/b Wireless...
Wireless printer gets ip address different from my routers ip add
Check on the wireless network the printer is connecting to. Make sure it is your router.
Feb 03, 2009 | Lexmark X4650 InkJet Printer
Netgear wg111v2 usb wireless adapter will not acquire ip address
Sorry, forgot to mention this earlier. Maybe netgear offers free Live Chat tech support. Go to their web site.
Nov 27, 2008 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Acquiring Address Problem
you will need to make sure that DHCP is enabled within the routers settings as this will tell the router to assign ip addresses automatically, then go to network connections, right click on your network card>properties>TCP/IP line>properties and tick 'obtain an ip address automatically', click ok, close window and restart pc.
Sep 24, 2008 | HP PAVILION A6230N DESKTOP PC
Failure to acquire IP address
How is the DHCP setting of the modem configured?
Nov 03, 2007 | Dell Dimension 4700 PC Desktop
Wireless Router
If you clicked repair connection at anytime, you need to reset the router, by way of a reset button on the rear or front, go to your wired network card properties in control panel>network connections, click TCP/IP line, click properties again and select obtain ip address automatically. At this point you can run the setup wizard again if you wish using the rj45 cable You should set up the router using an RJ45 lan cable which comes with the unit and get into the routers settings by typing it's ip address in your web browser 192.168.0.1. Check that DHCP is set at enabled to give your pc's an automatic ip address. Check that wireless is also enabled and save any changed settings. Go to the properties of your pc's wireless adapter in control panel network connections and on its TCP/IP line check that obtain ip address automatically is ticked. when you have set up your wireless connection and the router is set up correctly, disconnect the rj45 cable and if neccassary dissable the wired network card so as the router looks for your wireless adapter and gives it an ip address. When a connection is found by your wireless connection you need to go into the router again and set up your wireless security, using whatever method you choose eg WEP or WPA PSK. You need to select the numbers and letters mixture pass phrase that you use for encyption and use the same numbers in the wireless adapter when it asks for the passkey no., you should then be able to connect again securely.
Sep 10, 2007 | Linare Desktop, AMD Sempron 2200,40 GB HDD...
Setup problems with DELL 2350 router
sometimes windows messes the whole network up when using the set up wizard, you need to go to the properties of your wireless cards and check on the TCP/IP line that the radio button that says obtain ip address automaticaly is ticked. Go into the routers properties menu and check that DHCP is enabled and so allow the router to allocate ip addresses automatically, although you may need to do this via an rj45 cable and not wireless to begin with.
Jun 11, 2007 | Dell Wireless 2350 Router
Camera Not Working Wirelessly
I think maybe the problem is that the cam has already been recognised and given an ip address when you connect via RJ45 cable, but when you try wirelessly, there is a replication of the ip address which is not allowed. Check your router to see what ip address was given to the cam and remove if neccasary so as to re new the cam ipaddress. I would turn off the encryption first to try and get it working, then turn on again.
Feb 08, 2007 | Trendware TV-IP400W Network Camera
Dell Inspiron 6000 Notebook Logo
64 people viewed this question
Alun Cox
