Question about Lexmark X1270 All-In-One InkJet Printer
All-in-one not communicating with computer
I have gotten the printer installed on my computer and when tryin to print...stating the cannot communicate......i have a windows vista
    Scholar:
  • 71 Answers
How many devices do you have connected to your USB ports. Many computers power supplies cannot handle the power drain of excessive devices (cell phone charger, digital camera, wireless keyboards and mouse, wifi adapter, and printers. Remove a few devices and see if the printer will work. If it does, get a cheap powered USB hub. And plug the other devices into it.
It may also be a software issue.
Vista has it's own drivers and will assign it's own to your printer when you plug it in. This method will not work with many external devices. Completely disconnect the printer. Then install the lexmark driver. A window will pop up saying that the software being loaded is not approved by windows. Click install anyway. The software will instruct you when it is ok to connect the printer. You may have to go into the printer and faxes (control panel) and delete the current default printer.
Just one of the joys of having Vista
Posted on Jul 30, 2008
I dont have the installation disk and i downloaded it from hp off of the internet. My scanner works (and prints from the scanner)but it will not print from the computer. I keep tryin to send a Word...
Click Start > Printer and Faxes> if you find any printer in the window then Delete the printer. Open Add printer form "Printer and Faxes" window, and search for Printers. Select the Printer. and make it Defalt Printer. and Restart the Computer. Try printing. if no Results. try replacing the Cables. best of luck
Feb 01, 2011 | HP PhotoSmart C3140 All-In-One InkJet...
Printer error
Here a few common problems that your Epson printer and ink cartridge can suffer from.
Improper Installation of Cartridges
A common Epson printer and ink cartridge problem! If you have changed the ink cartridges then you might just receive this error message. The message might state that the cartridge is not installed correctly in the printers. In such cases, re-install the cartridge in the correct manner. If the problem persists then it is advisable that you replace the cartridge as it might be defective. If you still get the same error message on installation of the replacement cartridge then its time that you clean the print head. You could do this yourself or could take it to a repair facility.
Printing Failure
Failure to print documents is yet another common problem with respect to Epson printers. The print heads of Epson printers are sensitive and this sensitiveness is the culprit behind such problems. If the print head is clogged or blocked you will have to unclog or unblock them. This can be done by using a special fluid that is available for just this purpose only. This fluid flushes the print head, and your printer is once again ready to print.
Communication Error
'Communication Problems' are yet another one of the common problems surrounding Epson printers. Once you give the print command you might be shown the message that there is a communication error between the printer and the computer. This means that there is the occurrence of a minor problem. One of the reasons for this problem could be the inappropriate selection of printers from the print options menu. Cable connections should also be checked. Another solution could be the re-installation of the driver of the printer.
Print Jobs that are Slow or Incomplete
These are problems that occur during an ongoing process. The printing might stop midway and then start again after some time. At times, the printing process will repeat itself several times and then finish printing the page. There are times when the page will finish printing, but you will find that it is an incomplete print. More often than not, this is not a printer related problem.
What might have happened is that the driver might have corrupted or a virus might have infected the computer; or a spyware might be affecting the working of the printing process. If such a problem occurs, the best solution would be to scan the computer for viruses and spyware. As can be seen these common Epson printers and Epson ink cartridge problems can be sorted out quite easily.
hope it helps..
Thanks for using fixya...
Dec 04, 2010 | Epson Office Equipment & Supplies
Dell 924 printer. Stopped working - when try to
The problem could be because of ONE out of FIVE problems listed below. Try the steps recommended and it should fix the problem.
Thanks,
Abhishek
Mar 10, 2010 | Dell 924 All-in-One InkJet Printer
Will not print or communicate with computer/vista.
Have you tried re-installing the drivers?Try removing the software you originall installed on the computer,and re-installing them again.Check as well installed printers delete all the additional hps that may be there as well.
Good luck
Jan 17, 2010 | HP Photosmart C4180 All-In-One InkJet...
My computer will not print what im tryin to print nd my printer isnt printing any thing nd it takes n paper nd sends it bac out the way it was "blank"
try to unsinstall the CD installer of your printer and install it again. you must configure the setting of ur printer in order to connect on the system of your computer. make sure that the printer device driver set us default printer driver. if it not possible you better check the hardware if you do not know you can check it for the authorize technician if your printer covered for warranty. thanks
May 11, 2009 | HP Ruggedized DC Car Adapter for HP...
Can't scan from HP psc 2400 to iMac computer
You need to set up the software on the iMac. The reason it gives you that error message is because it can't communicate with the computer and imaging software as the computer doesn't see the scanner and can't communicate with the printer's control interface. The iMac may see the printer and be able to print without any additional software because the driver package for the printer portion may already be installed with the OS X HP printer driver support. You didn't mention whether or not you could print from OS X. I am assuming you can. Faxing and copying from the unit doesn't use the computer at all and doesn't need to communicate with it. Scanning and printing do. If you can't print either then none of the driver or support software is installed and you have to set it up. You can get the instructions for setting the printer up in OS X 10.5 from HP. Just click here and it will take you to the page with the instructions.
Best wishes and cheers
Jan 04, 2009 | HP PSC 2410 All-In-One InkJet Printer
Unable to print
With the Lexmark printers communication subsystem you MUST let the driver ask for you to plug in the printer. DO NOT plug the printer into the USB port until told to do so.
To fix a fouled install :
(1) Uninstall the Lexmark drivers in Add Remove Programs
(2) Shutdown the computer
(3) Disconnect the printer from the USB port
(4) Restart the computer
(5) Run the Driver Installation software
(6) Cancel ALL attempts by windows to auto install the printer
(7) When the sofware asks for the printer connect it and continue
Sep 07, 2008 | Lexmark X73 All-In-One InkJet Printer
LEXMARK X1270 NOT COMMUNICATIN WITH MY COMPUTER
i do not have its disk and I want to download it, so I need help in order to be able to install it without its disk
please send me email that how I can set up it.'
thank you for your nice cooperation at this matter.
yours turly
karim shah
k_shahrniya@yahoo.com
Jul 25, 2008 | Lexmark X1270 All-In-One InkJet Printer
Lexmark X1270 All-In-One InkJet Printer Logo
211 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
