Question about Microwave Ovens
Replace light in overrange GE microwave - Microwave Ovens
  • salzburg Jan 25, 2009
    Dear guest, my top front grill cover does not have two screws on top. there are no screws visible anywhere on the top grill cover.
    thanks
  • usfesq Feb 09, 2009
    the light cost 6 bucks from Home Depot (you have to call and order it) - but according to GE, it takes a service call (around $70) to put it in. Help please!
Advantum 120 over range microwave - with burned out interior bulb: Remove top fron grill cover -- held byu 2-3 screws on top. Remove sheetmetal plate that lies parallel to top of unit, just to the right of the square plastic porting on the far left of the unit. The sheet metal plating is about 12" wide and 8" deep and is shaped like 2 overlapping rectangles. It is held in place by 1-2 screws. (I don't recall if you needed to remove other plastic grid on right front -- I did, but I was still searching for the bulb). The bulb is located about 5" from the left side and about 2" in from the front, covered by a small sheetmetal box. THe bulb looks like the little halogen bulbs used in low-voltage outdoor lights - but is slightly larger - DO NOT REPLACE WITH THAT KIND OF BULB). Remove the one screw holding the box, unplug the bulb and find a replacement. Can't tell you where to get a bulb -- that's what I'm doing next. Good luck.
Posted on Sep 10, 2008
  • 93 Answers
Work lights or interior light?
Posted on Jul 26, 2008
3 Suggested Answers
SOURCE: My GE overrange microwave stopped working.
pls help me now my sanyo machine have problem
Posted on Jul 25, 2009
SOURCE: hotpoint overrange microwave, all the lights and
microwave works no heat
Posted on Oct 23, 2010
GE JNM 1851 microwave display panel light is out
The GE Answer Center is telling it like it is. Bet it's touted as a customer-friendly "improvement".
Sep 05, 2017 | GE Microwave Ovens
Hotpoint overrange microwave, all the lights and timers work not heating food. there is also a smell when trying to heat is this a common problem with this microwave?
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 on high resistance range for short circuit, the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Jan 01, 2011 | GE Hotpoint Over-the-Range Microwave
Need to replace lamp in GE Profile microwave model JE1590SH02
PMG!!! I called GE and was told that changing the light bulb is not a consumer replaceable part!!! Are you kidding me!! She told me I had to have a GE tech come out. Makes you want to buy GE appliacnces, right!
Mar 01, 2010 | GE Microwave Ovens
Jul 25, 2009 | GE JVM2050 Microwave Oven
Replacing GE Spacemaker Light Bulb inside Microwave Oven...
Here is the GE download page for your manual. Page 35 of your  manual gives the light bulb replacment instructions.
http://genet.geappliances.com/DocSearch/Dispatcher
Dec 30, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Microwave
maybe the problem is in the door latch switch try to replace the switch going to lights or bulb.
Jun 13, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Replacement cooktop light bulbs
look inside for a removable panel for access to the lamps. consult your instruction manual.
Dec 28, 2007 | GE JVM1650 1000 Watts Microwave Oven
Microwave Ovens Logo
595 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
