-   I have a two inch black line across the top of the tv and a small halh inch line on the left side picture is fine though jus needs moving up to the left how do i do this?-   Guest
Aug 25, 2008
-   The top of my picture is pulled up. The bottom of the screen curves, and the left side pulls the picture that way. If you have a circle in the center of the screen it is pulled towards the top, bottom and left side makeing it very odd looking. Any suggestions?-   melhops
TV keeps going into standby but sometims comes back on again straight away. Picture normally...
(More)
TV keeps going into standby but sometims comes back on again straight away. Picture normally flickers before happends. Doesnt just happen via Scart as originally suspected original fault. Taken out batteries in Remote Contol and pressed all buttons to remove any static and still happends.
i have a toshiba 43vj33 projection ctv with a projection blub broken can you fix it or no anyone can...
(More)
i have a toshiba 43vj33 projection ctv with a projection blub broken can you fix it or no anyone can repair it
sony ptojection tv model KP-FW51....the last day or so tv does not turn straight on with usuall...
(More)
sony ptojection tv model KP-FW51....the last day or so tv does not turn straight on with usuall green light - Once I use the remote to turn on I get picture ....But the red light flashes continually ?
panasonic plasma model TH-C42HD18 just tried to have HD DVR installed, experienced purple &...
(More)
panasonic plasma model TH-C42HD18 just tried to have HD DVR installed, experienced purple & Green Horizontal bands about 3" wide in HD only. Comcast says either my TV or electrical interference.
I have a Sony Vega SXRD, 50-inch (I think), LCD TV, Model No. KDS-R50XBR1, Jan 2006. Typically, the...
(More)
I have a Sony Vega SXRD, 50-inch (I think), LCD TV, Model No. KDS-R50XBR1, Jan 2006. Typically, the TV would turn ''on'' and light at the front panel near the ''on'' switch would blink before the TV screen would light up and the blinking light would be a constant light. But this morning, I turned on the TV and the light would blink and the screen would flash on for less than a second and go black. The front panel light would blink four times and than nothing and than blink another four times. The panel would remain black or off. Only when I initially try to turn on the TV, the panel would flash on for just a second and turn black again. The blinking light would continue to blink all day. Any help would be appreciated. I plan to call a Sony repair man. I called a local guy and he took down the model number and asked what happened, charged me $49 and told me he would look into it or research the problem. He was out the door within 10 minutes. I will not repeat that service again!
