Question about Motorola Mobility MD481 Cordless Phone
Handset says out of range
How can i reset my handset so that it can work ...
  • jasonjia Jul 28, 2008
    My headset used to work well but it started to say 'out of range' a couple of days ago and i tried to register by pressing the 'page' button for a long time, but the message said that registration failed. How can I register the headset again?
  • Anonymous Aug 26, 2008
    One phone (we have two handsets) says "out of range" and when I I hold the page button down it tries to register and then says "too many handsets." Is there a way to get this phone to register again?
Download the PDF file 516538-002-a (Google it) look at PG 60 for instructions to deregistrer it.
Posted on Aug 14, 2008
What is meant when screen says out of range
You will need to take your handset closer to the base because the signal is weak and out of range. Try locating the charging base in a more central location. If this doesn't work try this.
You can first try a Basic Reset.
A reset is done by following the below steps:
1. Disconnect the battery from handset(s)
2. Disconnect Phone Cord from wall jack
3. Disconnect Phone cord from base unit
4. Disconnect AC adapter from wall outlet
5. Allow to sit for 30 min
6. Reconnect Phone Cord to base
7. Reconnect Phone cord to wall jack
8. Reconnect AC Adapter to wall outlet
9. Reconnect battery into handset until you click or feel the plug snap into place
10. Re-Register Handset by placing on main base
For more info go to this site
Customer Support
Feb 27, 2015 | Uniden Dect6.0 Digital Answering Syst W...
GE handset 28101 will not sync with base-GE 28129
Unplug power cord from the base for ten or fifteen minutes, this is the only user level operation that you can do to try fixing the problem.
If after resetting the base still do not find the handset, then either the base or the handset is faulty.
If the base works fine with a different handset, then it is the handset.
Sep 14, 2008 | Lands Phones
I have a D1680 system with one accessory handset. The hand set on the base is showing Searching although it is on the Base. It rings when a call comes in but when picked up it says out of range. The...
1. Press & hold End and # at the same time until you see the System Reset menu.
2. If you still have the base the handset is registered to, select Deregister HS, then select the handset you want to reset. If you don't have that base anymore, select Base Unavailable.
3. To confirm, select Yes. The handset displays "Handset not registered"
Now you want to register the phone again.
1. Place the handset in the base; the display should say Handset
Registering.
2. Wait until the display says Registration Complete (about 30
seconds), then pick up the handset and press Talk/flash.
You should now have a dial tone
Oct 16, 2013 | Uniden D1680 Cordless Phone
Hand set out of range disply is on. How do I reset.
here are some tips from my manual for out of range problems
hope they help
• Only one handset can be used to make or answer a call anytime.
If another handset attempt to do so, the screen will display OTHER
HANDSET ON and then OR OUT OF RANGE. You might press PHONE
or SPEAKER again until no other handset is using the line. Use the call
transfer feature to transfer a call to another system handset
or use the speakerphone feature so multiple members of your
house can be on an active call at the same time.
• Move the cordless handset closer to the base. You might have moved
out of range.
• Ensure that the base is powered up.
• Place the cordless handset in base cradle for 1 minute to allow the
cordless handset and base to resynchronize channels.
• If the cordless handset is in its base and the charging light does not
come on, refer to the charge light is off in troubleshooting guide.
• Reset the base. Unplug the unit’s electrical power. Wait for 15 seconds
then plug it back in. Allow up to one minute for the cordless handset
and base to reset.
• Other electronic products can cause interference with your cordless
phone. Try installing your phone as far away from these types of elec
tronic devices as possible: wireless routers, radios, radio towers, page
towers, cell phones, intercoms, room monitors, televisions, personal
computers, kitchen appliances and cordless phones.
Jul 16, 2009 | GE 29897GE1 Corded Phone
Handset out of range - message
We totally unplugged the phone, made sure the battery was charged and reset the phone as though it was brand new, in other words started from scratch. It seemed to work and the phone is O.K. now
Jan 16, 2009 | Uniden TRU9585 Cordless Phone
Handsets wont work at all
it may be that the handset is registred to another base unit-
we had one base and one handset replaced by uniden, but the second (old) handset was still registred to the old base, therefore everytime we tried to deregister the handset it was looking for the old (replaced) base and of course could not connect and therefore wouldnt deregister. still havent figured out what to do yet
Dec 20, 2008 | Lands Phones
Handset has message Out of Range even though it is fully charged on on the handset.
The handsets are reading out of range because they have lost connection with the base. This happens mostly during peak power demands or power outages, but can also happen when the phone is unplugged for any amount of time. This can also cause, at times, the answering machine to stop picking up calls. To remedy this issue, reset the phone system. Please follow the instructions below:
To reset the phone:
1. Disconnect the power adapter, phone line, and remove all batteries from the base and all handsets. Leave it disconnected for 30 seconds to reset the base.
2. Place the batteries in the handsets first and then plug in the power adapter and phone line. Do not place the batteries back in the base yet.
3. Put the handset in the charge cradle.
4. It may take up to 1 minute for the "Out of Range" to clear from the display.
5. Once the "Out of Range" is cleared from the handset place the back up batteries back into the base.
Sep 08, 2008 | Motorola Mobility SD4502 Cordless...
Uniden 2645 out of range
The problem of phone not registering is sorted, I simply put that hand piece(2) into base station and it registered straight away, as for the "out of range" problem, we have not had a long enough call today to know yet , hopefully resetting to factory settings helped.
Jul 16, 2008 | Uniden Cordless Phone
Out of range shows on main handset of cordless phone
Unplug the battery. Hold down The * (star) and the #(hash) keys simultaneously. Re-connect the battery, phone will beep and screen will be blank. Press the voicemail (righthand silver key under the lcd screen). As above EEPROM/RAM message will appear. Place handset on base and your problem is solved.
Jan 13, 2008 | Uniden 5.8GHz Cordless Phone
Motorola Mobility MD481 Cordless Phone Logo
311 people viewed this question
Top Motorola Mobility Lands Phones Experts
john h
Eric Sutherland
Are you a Motorola Mobility Lands Phone Expert? Answer questions, earn points and help others
