Look for a button that looks like a satelite dish. Its usually flashing when you're connected through wireless. It's probably close to the power button. Push it.
You can manually disable the Wireless connection on mostly all laptops/tablet pc's. Check either on the left or on the bottom. It is a button (Picture: it has a tower with waves coming from it) that you can either slide forward and backward, or a button that you press to turn on and off. Why do they have these on laptops???? Well that's for another time! It will NEVER connect if this button is turned off, or disabled. Again, you have to make sure that it is NOT manually disabled first, sometimes you might not ever know that you "accidentally" turned it off with you fingers, but trust me if you can not connect at all, than that is what is wrong.
are you trying to use or get internet by wireless connection, make sure that your radio button is enabled, in order for you to get the internet connection signal.
By default the wireless adapter is enabled on your HP PC. However there are many ways to disable your wireless adapter. It can happen by turning it off in windows or some application may disable it due to execution errors.
Most of the time, when a wireless adapter is disabled on a machine it is very often because someone has pressed the wirless button by mistake. If it has been pushed by mistake, turn the wireless back on by finding the wirless button on your machine and pressing it. Check for button location on the top of the keyboard or the side or front of the PC. Thanks
1. Turn off both the linksys and your modem 2. Turn on your and wait for the usual lights to turn solid 3. Turn on the Linksys and wait 30 secs 4. Press the button on the front to the left. It does not look like a button but flashes while it is finding an ip address 5. Now connect with an Ethernet Network Cable and make sure the internet is working 6. Disconnect the cable and Connect Wirelessly
First, check to see if there is a button on the keyboard that looks like an antenna. It usually hasF a blue light on if it is enabled. If not, press it. If you are using Windows XP Click Start, then select Control Panel. Click Network and Internet Connections. The Network and Internet Connections Click window opens. Network Connections. The Network Connections window opens. Right-click Wireless Network Connection. Select Enable to turn on wireless Ethernet or Disable to turn off wireless Ethernet.
First, check to see if there is a button on the keyboard that looks like an antenna. It usually has a blue light on if it is enabled. If not, press it. If you are using Windows XP Click
Start,
then select
Control Panel.
Click
Network and
window opens.
Click
Right-click
Wireless Network
Connection.
