Question about Malber TD700 Electric Dryer
Opening the Malber TD700 dryer
How do I open the Malber Dryer?
  • Anonymous Apr 01, 2014
    Light will not come on checked for power at outlet 120volts present
    Power at outlier 120volts
Remove the two top screws on the back center (plastic part) with a Torx 20 screwdriver and the top will come off.
Posted on Jul 23, 2009
I HAVE A MALBER TD700 AND IT WONT START.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 10, 2010 | Malber Dryers
DRYER VERY NOISY AND VIBRATES
does it complete all cycles?
and how old is this unit?
Jul 25, 2008 | Malber TD700 Electric Dryer
I need a 220 volt timer for Malber TD700 drier.
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Sep 02, 2010 | Malber TD700 Electric Dryer
Where do I download manual for malber td700 dryer
You can download the manual for your device at;www.manualsonline.com or www.manualnguide.com.
Thanks and take care
May 02, 2010 | Malber TD700 Electric Dryer
Malber TD700 sensor tumbles but no heat
Common faults -
1 The heating elements can fail (meaning open circuit)
2 There are cut-outs (T.O.C's) that might need resetting
3 The thermostats (stats) can trip out or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehave programs that can fail and circuitry although most should produce an errorcode showing you were the fault is.
5 Faultyconnections and burned wires may also be the fault.
Free tumble dryer repair videos
We have a Free full video library on appliance repair video’s
Jan 05, 2010 | Malber TD700 Electric Dryer
The door handle has fallen off -I can't open the dryer
For now, take a wire clothes hanger and bend a small 90 degree hook on the end. Poke the hook in one of the holes where the handle went and pull the door open. Then maybe you can find a replacement handle.
Jul 11, 2009 | Malber TD700 Electric Dryer
Malber td 700
need to no where to get belt for malber td 700?
Mar 05, 2009 | Malber TD700 Electric Dryer
Dryer stopped working after working w/door open or closed
Sounds as if the door switch/latch had stuck.the smell was probably a small short. try unplugging unit. But I would imagine you need door latch/switch replaced
Feb 06, 2009 | Malber TD700 Electric Dryer
Malber Company - Italy. Address
need to find a manual for Malber WD8008
Oct 25, 2008 | Malber TD700 Electric Dryer
Malber dryer 2 years old
move the dial to the "off" position first; wait for beep; then move to the drying setting you want, and wait for another beep.
Jan 06, 2008 | Malber TD700 Electric Dryer
Malber TD700 Electric Dryer Logo
226 people viewed this question
Top Malber Dryers Experts
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Tim Whalen
Are you a Malber Dryer Expert? Answer questions, earn points and help others
