Question about Whirlpool Washing Machines
Cabrio washing maching f40 error code. Tried to replace mother board twice still getting error code.
    Genius:
  • 1,028 Answers
Problem is most likely the the motor position sensolean washer back remove motor rotor by turning big torx screw counterclockwise screw does not come all the way out ..remove 4 bolts holding stator assembly in place on the side of stator is a small connector with 405 wires pull the connector off and on 8-10 times ..there is a coating on the connector that prevents good connection on sensor reassemble and ck let me know how it turns out thanks
Posted on Jul 26, 2008
What does error code F40 mean on my Cabrio top loading washer?
F then 40 flashes when the ATC Thermistor is detected to be open or shorted.
Dec 07, 2012 | Washing Machines
F1_Code on a whirlpool washer
washers have had several common repair issues since day one. If your Cabrio or Oasis washing machine has the dread error code F1, you can fix it. The F1 error code on you're washing machine means the mother board is bad. The repair is simple and straight forward if you are the adventurous type. The washers control panel needs to be removed to gain access to the mother board. The three screws on the back side hold the washers control panel to the cabinet. The screws are 1/4 size and a nut driver works best to remove them.
The washers main control board is held down with one small screw in the front. Removing the screw and lifting the board up is all that needs to be done to remove the control. The wire connections are all plug and play. The washers pressure switch hose also plugs into the main board. The pressure hose also simply lifts up and off the control board. Need more help? Post your question below i would be happy to assist.
Oct 27, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Keep getting the lf code. I have had this washer almost three years - I have had four mother boards replaced!
F1 is a fatal error in the machine control. The only remedy is replacing the control. Four board failures is abnormal, check your outlet voltage and especially your house ground. You may need to hire and electrician to inspect. New board available HERE.
Jan 13, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
My Kenmore Oasis Dryer will not run and has an F 40 code. What is wrong with it?
Get the model number and go to:
http://www.searspartsdirect.com/partsdirect/modelHelp.pd?pop=flush&modelNumberId=18
The F40 code can mean a thermal interrupt or a loss of connection between the control circuit board and the motor circuit board.
Perito posted this on askmehelpdesk.com:
I found two possibilities for an F40 code.
1) Error Code F40 is that the thermal fuse has blown.
2) The F40 error code is a communication problem between the machine control board and motor control board. A bad connection might or might not cause this.
If you post your model number, or download the owner's manual from the above link, you'll probably find out what it means, at least.
Dec 12, 2009 | Kenmore Dryers
F1 error code replaced mother board twice but still have issues
HE Top Load Washers
Models:
F1 Error Code
WTW6200S WTW6300S WTW6400S WTW6600S WTW6700T
MTW6300T MTW6400T MTW6500T MTW6600T MTW6700T
Serial Numbers: CT01 - CU52
There are four areas of concern that can cause the F1 Error Code. Each area must be sequentially addressed to ensure
that the diagnosis is correct and the proper repair is completed.
A) Air leaks in the air pressure (switch/sensor) hose.
a. Inspect the hose for cracks, pin-holes or loose connection.
b. Replace the hose and harness assembly (W10058730) if it is compromised.
B) Moisture in the air pressure (switch/sensor) hose.
a. Inspect the hose for evidence of water.
b. Replace the hose and harness assembly (W10058730) if water is detected.
C) Lint or flashing in the air dome hose connection port.
a. Inspect the air dome hose connection port for lint or flashing.
b. Use a small round device (small screwdriver) to ensure that there is nothing blocking the air dome outlet on
the tub.
D) The control needs to be replaced.
a. Replace the control only after you have completed steps A - C above, and verified that there are no issues
with the air pressure system.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 25, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
F50 error code and Whirlpool Cabrio
this code would indicate rps sensor at motor. whirlpools are very bad with electronics and control boards. New rps sensor requires new harness as well.
Feb 21, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Kenmore Oasis dryer F40 error code
I had this same issue. My dryer would run and heat up but then stop and give me the f40. I measured all thermisters and everything was in range. The tech sheet stated that I needed to buy a new control board and I did. Same problem.
The solution was a loose connection on for p4. I took needle nose pliers and squeezed the connector to make it fit tight on the board and everything is working now.
Bottom line, expensive dryer with cheap connectors.
Nov 16, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Whirlpool Cabrio Washer Error message code F1
The following list of codes indicates a possible electronics communication problem with the washer:
Cabrio washer - F1, F2, F40, F41, F42, F50, F51, F52, F53, F54, F72
To remove the error display, press Pause/Cancel twice.
PLACEHOLDER FOR ART
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Please do not forget to rate and comment about your experience with fixya today.
Aug 17, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
F40 code on Oasis HE washer
ocindy, F-40 has to do with the automatic temp control. The thermistor is either shorted or opened. Tell the service tech to check the connections at the water valve and at the board. If ok, change the water valve. If that doesn't solve the problem, replace the main board. Catriver...post back.
Jan 20, 2007 | Kenmore Oasis HE 27082 Top Load Washer
Washing Machines Logo
182 people viewed this question
Dan Webster
Dan Webster
Sal De
