Question about HP Pavilion ze5000 30 GB Hard Drive
Hp ze5400 lp power problem
When i power on it shows the black screen with all the f1 f2 f10 and sits for a sec and it just shuts off and it will not turn back unless you take the battery out.................this is done with cord pluged in thanks in advance
    Sergeant:
    Champion:
  • 212 Answers
It is a hard drive issue. try putting a windows restore disc in and restore it. If now get a new hard drive
Posted on Jan 23, 2010
  • Robert Lekfield Jan 23, 2010
    sonic 12323. the batteries go real fast on this model. make shure you always have a power cord
Mine cant hold power on the battery
Posted on Aug 26, 2009
Try to pull the ram cards one at a time try with one card and then try with the other is sounds like a bad ram.
Posted on Apr 09, 2009
My hp laptop TPN-C126 has power but its screen was totally blackout
that TPN-c126 is not the model number
In fact its the EPA/EU, power (sleep )and energystar
regulations RMN:TPN-C126 (the R means gov. regs)
proof here:
http://h22235.www2.hp.com/hpinfo/globalcitizenship/environment/productdata/Countries/_MultiCountry/europe_erplot3_notebo_201542919128520.pdf
if you look again at the back of pc. base.
on the right side of where you where looking
is a SERIAL.(I dont want that)
then below that, is model
"HP 255 - G5" (or very close)
when posting use real names and models
as seen here
http://partsurfer.hp.com/search.aspx
click Hierarchy
then notebooks
then hp notebook PCs
behold. photo below.
one is yours, matching words on bottom of your PC.
LT black screens
http://pcdied.com/black-screen.html#Laptop
below is your pc if you knew its real name.15cdf60c-9764-4e4a-a480-66af380fe0ab.jpg255-g5-hmzm4reoidw0tx1unypabkrd-3-2.jpg
Jul 21, 2017 | HP Computers & Internet
I have dell latitude d610. when turned on screen shows "manufacturing mode level 67" & system halts
Hi, I have done some research on this issue, I would suggest giving the following a try:
Plug the charger in.
On start up keep tapping either F1, F2, F10,(Be Aware that some manufacturers use F10 for system recovery!) Esc, or Del, to enter the BIOS set-up. Look for "Factory Default" or similar, and return the settings to default. Save settings and exit.
Unplug, remove the battery and press the power button for 10 seconds.
Restart.
Mar 20, 2014 | HP Compaq nc6220 Notebook
Cannot start even charger is already pluged
restart computer keep pushing f2 f2 f2 f2 sec. screen pops up change your boot for f12 f10 exsept the boot format then restart push f12 go to sec. optsion then it will ask to run windows click on that then see if your windows will come up.
Feb 05, 2011 | HP Pavilion dv6000z Notebook
Whenever I turn my Compaq on, the power button light comes on, the wireless button light comes on and the light beside the caps lock and pg up key flashes on and off however nothing is happening on screen....
deads'ville.
my old PC CQ60-220us, thanks for full number !!!
what os? VISTA?
those are called flash codes and have meaning!
the screen never once shows TEXT or HP /Compaq logos. right?
nothing to me means just the the TEXT IS GONE
"hit ESC to enter setup" or F2,F10,,etc....
carbon14 dated by me at 2008, ? (MY HP has F1 info page shows day made, a BIOS page F1) The year mATTERS.
steps below. for dead pc. means screen dead, and BIOS keys dead.
  1. take the battery main out, they short, remove it ;after all you can run like that for ever on the line pack, a fact. so do so now.
  2. does it power on, seems yes, does it stay on? (heard and seen)
  3. does the fan blow< spin and not packed solid in lint?
  4. use flash light pointed at screen , turn PC on the use the flashlight see data now? yes, bad black lamps CCFL, ask
  5. beep codes or caps lock flash codes,? write them down and tell the helper what the are? its code. like Morse code.
  6. there are more tests. does the CD eject button work?
my wild guess, (unseen by me) is the CCFL lamps are dead.
the LCD on this PC has lamps for the back lamp that all burn out
at 20k hours of usage. (short lived, if used constantly)
other tests are: ask
  • boot from free linux disk see of screen works?
  • replace coin cell battery they usually don't last 10 years. 7 max.
  • power pack bad and is weak, some fail weak
  • keep in mind black screen failures have many causes.
  • bad power, bad screen, shorts inside the pc, bad RAM.
  • also the GPU chips in 2008 were bad, defective, solder ball failures. making the screen dead or very odd.
here is a black screen page.
HP is the best maker of PC.s (not custom made as I do)
but has best docs.
but they do have 1 weakness, BIOS docs and Beep/blink codes
horrible support there, due to changing the rules 20 times. or more.
HP also modified the BIOS to their needs, making generic lookups
on say Award BIOS useless.. ouch.
The older the PC the worse this gets, books covering that.
Sep 10, 2017 | Compaq Presario CQ60-220US PC Laptop
My hp pavilion slimline went to the blue screen today that said an error occurred and I should shut down and restart and run the harddrive diagnotics. But when I shut it down, it will turn on, but not...
You can try to do a Power drain of the system ie disconnect all the cables from the pc and press and hold the power button of the tower for 30 to 40 sec. than reconnect only the keyboard the mouse and the monitor and turn it on. try to enter the BIOS page ( keep on tabbing the F10 key to enter BIOS is Windows Vista during the start up and F1 in Windows XP) and from their you can run a Smart test on the Hard drive. You can also try to boot the Pc to the safe mode and check whether the windows loads or not. From the Advanced boot option try to do a Start up repair.
Jul 06, 2010 | HP Pavilion Slimline s3620f Desktop
Laptop hp nx6320 keyboard f2 key is only working. f1 and f10 key is not responding so that I can't save memory upgradation option nor open the setup.
Have you tried "Delete" to enter the "Bios Settings"? If not this must be the shortcut for your laptop, since most compaqs' Bios settings are accessed with "del" key. Actually for Hp compaq laptops, F1, F2, F10 and Delete keys are the shortcuts. (varies with series/models).
If this doesn't help, try Fn+F1, Fn+F2, Fn+F10 etc..
Good luck.
Thanks for using FixYa.
Jul 01, 2010 | HP 413670-001 - HP Compaq nc6320, nx6310,...
Ho do I enter bios setup
Hello
From HP website - hit F1 or F10
F1 if the PC was built before 2006
F10 if the PC was built in or after 2006
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph07110&lc=en&cc=sg&dlc=en&product=68089
May 01, 2010 | HP Pavilion 7955 PC Desktop
Toshiba Satellite 1400
To Access the Bios Setup Utility Here Is A List Of Key Commands And The Make/Model They Are For..
Acer - Aspire, Power, Veriton, Extensa, Ferrari, TravelMate, Altos
  • Press Del or F2 immediately after powering on.
  • The BIOS on the Acer Altos 600 server uses the Ctrl+Alt+Esc key and the F1 key for advanced options.
  • Older Acer computers may use also use the F1 or Ctrl+Alt+Esc keys to access BIOS.
Compaq - Presario, Prolinea, Deskpro, Systempro, Portable
  • Press F10 while the cursor in the top right corner of the screen is blinking.
  • Older Compaq computers may use the F1, F2, F10, or Del key to give access to BIOS.
Dell - XPS, Dimension, Inspiron, Latitude. OptiPlex, Precision, Vostro
  • Press F2 when the Dell logo appears. Press every few seconds until the message Entering Setup appears.
  • Older Dell desktops and laptops may instead use Ctrl+Alt+Enter or Del to enter BIOS.
  • Older Dell laptops may use Fn+Esc or Fn+F1.
eMachines - eMonster, eTower, eOne, S-Series, T-Series
  • Press Tab or Del while the eMachine logo displays on screen.
  • Other eMachine computers may use F2 to enter BIOS.
Fujitsu - LifeBook, Esprimo, Amilo, Tablet, DeskPower
  • Press F2 once the Fujitsu logo appears.
Gateway - DX, FX, One, GM, GT, GX, Profile, Astro
  • Press the F1 key repeatedly after restarting the computer.
  • Some older Gateway computers use F2 to access the BIOS Setup utility.
Hewlett-Packard (HP) - Pavilion, TouchSmart, Vectra, OmniBook, Tablet
  • Press the F1 key after restarting the computer.
  • HP Tablet PCs may use F10 or F12.
  • Other HP computers may allow access to BIOS using the F2 or Esc keys.
IBM - PC, XT, AT
  • Press F1 immediately after powering on the computer.
  • Older IBM computers (including some laptops) may utilize the F2 key for BIOS entry.
Lenovo (formerly IBM) - ThinkPad, IdeaPad, 3000 Series, ThinkCentre, ThinkStation
  • Press F1 or F2 after powering on the computer.
  • Older Lenovo products allow access to BIOS using Ctrl+Alt+F3, Ctrl+Alt+Ins, or Fn+F1.
Micron (MPC Computers) - ClientPro, TransPort
  • Press F1, F2 or Del immediately after powering on the PC.
NEC - PowerMate, Versa, W-Series
  • Press F2 to enter the BIOS Setup.
Packard Bell - 8900 Series, 9000 Series, Pulsar, Platinum, EasyNote, imedia, iextreme
  • Press F1, F2, or Del to enter BIOS.
Sharp - Notebook Laptops, Actius UltraLite
  • Press F2 after the computer starts.
  • Some very old Sharp PCs require a Setup Diagnostics Disk to access BIOS.
Shuttle - Glamor G-Series, D'vo, Prima P2-Series, Workstation, X Mini XPC, Surveillance
  • Press F2 or Del on startup.
Sony - VAIO, PCG-Series, VGN-Series
  • Press F1, F2 or F3 after turning on the computer.
Toshiba - Portégé, Satellite, Tecra
  • Press F1 or Esc after powering on to access BIOS.
The following companies are either closed for business or no longer manufacture or support mainstream computers systems so verifying the following BIOS access information is nearly impossible. I have included what I could dig up for anyone who might be interested:
ARI / ALR / AST (Advantage) - Press the Ctrl+Alt+Esc or Ctrl+Alt+Del keys.
Cybermax - Press the Esc key.
Tandon - Press the Ctrl+Shift+Esc keys.
Good Luck and Hope it helps...
http://www.wnycomputerpro.com
Jun 12, 2008 | Toshiba Satellite A35-S159 Notebook
HP Pavilion ze5000 30 GB Hard Drive Logo
261 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
