Question about Sharp AR-M160 Laser Printer
Changing toner getting U2 40 code
The repair guy was here servicing the machine and told me that it was a chip communication error. Is this true? If it is, how can I fix it? Does it mean I have a faulty toner cartridge? I put the old toner cartridge in and it is working fine.
If the toner is faulty, how can I prove to the person who sold it to me that the cartridge is bad?
Jayne
    New Friend:
  • 28 Answers
The cartridge is faulty, in most cases not a genuine cartridge. If the copier works with the old one that means the "new" cartridge in defective.
If you brought a original Sharp cartridge you should return that and ask for a new one.
Posted on Feb 05, 2010
F2-04 error on sharp machine AR-M205
The code you have indicates there is a problem with the communication chip within the toner cartridge. The only solution I can think of is to replace the toner cartridge with a new one. Make sure you turn off the machine first, then swap out the toner cartridge then power back on.
Hope this helps.
Dave.
Jan 30, 2017 | Sharp Office Equipment & Supplies
Call for Service ...... C710
Hi there
I have found various documents which may help you with this problem and possible future problems. This page:
Error Codes Kyocera Mita KM1530 Code C710
can find any code connected with Kyocera mita machines by changing the machine and the error code in the appropriate drop down menus. C710 is identified as:
Description Toner sensor problem
• The sensor output voltage is outside the range of 0.5 to 4.5 V during toner control.
• The toner sensor control voltage cannot be set within the setting range when maintenance item U130 is run. Causes Defective toner sensor. Poor contact of the toner sensor connector terminals. Developer problem.
Another page showing error codes and their meanings is here;
Kyocera Mita Error Code Messages
and this confirms the above.
Also the link below takes you to a Kyocera web page where you can download various manuals for this machine (KM-1530). By changing the product in the drop down menu to KN-2030 you can get similar manuals for this machine.
Download Center
In your question you mention "Compatible KP23153 Black Toner Cartridge 106153" and that led me to wonder if the compatible cartridge is the cause of your C710 error since that is toner related.
Might be worth trying an original cartridge to see if the error goes away.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 24, 2014 | Kyocera Mita KM 1530/ 2030 Copier Machines...
Code erreur U2-40
U2-40, mostly appears in sharp copiers when you installing new toner cartridge.the reason of this code is faulty CRUM chip because of different type of toner manufacture .
you cane this problem by replace the chip in the new toner cartridge by the chip in old toner cartridge
- the chip is located in the rear toner cartridge -
I hope this help!
Feb 14, 2011 | Sharp AR-5316 Advanced Digital Imager...
Fatal error 231 on oki c5800 after changing toner, tried power off/on still doesn't work
From the service manual, doesn't look good.
A technicain will have to look at the printer.
RFID Reader I/F Error
An interface error was detected with the RFID reader device.
01 : communication error between the RFID reader and the engine PCB.
02 : the transceiver circuit error of the RFID reader.
03 : communication error between the RFID reader and the Tag chip.
04 : the RFID Tag detection error (more than 4 chips).
If rebooting the machine does not improve the symptom, you need to
check the device.
Mar 08, 2010 | OKI C5800Ldn Led Printer
Solution for SHARP AR 5127 error U2-40 call for service
This means that the cartridge's sensor is miscommunicating with the copier memory thus the code U2 -40. You should clean the inner sensor connector and the toner sensor of the spilled toner by low blower. Perform this code ;# , interrupt , C, Interrupt keys in that order and press 16 then Print key and the code will be cleared.
Feb 02, 2010 | Sharp AR-5316 Advanced Digital Imager...
SHARP AR 275 PROBLEM E1 15 ERROR AFTER SOLVING THE U2 40 PROMLEM
Porfavor ayudenme necesito su ayuda urgentemente. este problema ya lleva 2 semanas asi y no me permite ni scanear ni imprimir ni nada.
Aug 06, 2009 | Sharp AR-275 Copier
ERROR CODE U2-40: SHARP AR 5127
ERROR CODE U2-4 COULD BE RELATED TO THE MEMORY BATTERY BEING DEAD ON TEH MAIN BOSRD IF IT IS AN OLD MACHINE SO YOU COULD CHECK THSI OR REPLACE AND TRY WITH NEW
Jun 12, 2009 | Sharp AR-5316 Advanced Digital Imager...
Just purchased M1522nf laser jet printer. LCD panel reads ''10.1000 Supply Memory error. Do you accept? press OK'' I have yet to install software in my laptop, which is next step in Getting Started Guide....
If you get suppy memory error than replace the Toner cartridge.
On toner cartridge there is a copper connecting chip, that particular chip communicates with the printer.
However the chip on ptinter (EPM) which communicate with cartridge chip if that is faulty than you need to get printer repaired.
However first replace the cartridge.
Chip on cartridge may be faulty.
Jun 09, 2009 | HP LaserJet M1522nf Multifunction Printer...
Error Code U2-40 on Sharp FO-DC550 fax machine.
That is a CRUM communication error. The CRUM is a chip that resides on the toner cartridge that keeps track of the toner usage and resets when a new toner is installed. If you replaced the toner recently it may be corrupt. If you got a refurbidhed toner they may have reprogrammed the CRUM incorrectly. Power supply problems often cause this error so check your outlet to make sure it is withinn the proper voltage range and also that it is not on the same circuit as other devices. Get a "real" surge protector designed for office equipment such as a smartpower. Try changing toners and using genuine supplies.
Jun 03, 2008 | Sharp AR-5316 Advanced Digital Imager...
Black toner low Epson Aculaser CX11NF
Try powering the unit off and on. The toner indicator does not always reset immediately in my experience
Nov 02, 2007 | Epson ACULASER CX11NF All-In-One Printer
Sharp AR-M160 Laser Printer Logo
224 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
