My lap top turns off *** soon as i remove the power cord.... its like my battery will not take charge at all.. the battery light flashes 2 green and one orange... its a dell 9100
    Scholar:
  • 162 Answers
Dell has problems with that motherboard not recognizing the battery or the adapter. If you get error messages about the battery not being correct or recognized, the board has issues.
If this notebook is always plugged in then the battery has shorted and won't hold a charge.
Best option is to try another battery. Another thing, if your system is more than a year old, the battery needs replacing anyway.
If you are going to use this plugged in, get another battery, charge it up and remove it.
Posted on Jul 25, 2008
Lap top will not turn on. receives power from the cord and power supply, but has no indicating lights on the lower left part of laptop. was able to get the lap top to operate after removing and...
Measure the voltage at the terminals of the battery in the laptop. If there is no supply then the power section in the lap tops main board is faulty and needs a check.
However if there is voltage then the battery must be checked if this has failed to charge and is defective. check if the cord from the adapter is not short as it will result in DC power cut off.
Mar 24, 2011 | HP Computers & Internet
MD781 battery wont charge...will run with the power cord plugged in, I replace the battery first thinking that may be the trouble. Still wont charge...it would run for a short while on the battery when...
Hi
Can you please try to leave laptop switched off
plug in laptop and leave until the light on front goes green or at least 2/3 hrs
then unplug power cord
switch on laptop and use it or leave it until it looses all power and switches off
then recharge until green
when battery is fully charged always un plug and use on battery power
until it reaches about 10% before recharging
some people even remove their battery to preserve it if they always use power cord
if this does not sort the problem please come back to us
many thanks
Feb 23, 2011 | Gateway MD7818u Notebook
My acer laptop will not charge, if the ic port connector is moved then sporadically the lap top will charge. But then dies soon after
start the machine up with the power cord in it, and after it starts remove the battery, the pc should stay on, and be usable. if not then the port is bad. if it does, then its the battery that will not charge.
Jan 06, 2011 | Computers & Internet
Plugged into rental mini van; powered up converter; light turned green; plugged in 2 different Dell laptops and both times light on converter went from green to red and lap top confirmed not receiving...
Try to measure the input voltage. If the Vans battery falls to less than 10.5 V it may stop converting. The battery should be charged well before using converter.
Jun 10, 2010 | Black & Decker 200 Watt Power Inverter
My dog chewed through the power cord on my dell D600 lap top and killed it, i bought a new power supply but it still wont start up, thinking that it may have shorted some thing out i put in a new power...
Verify that the light on the power block is green with the cable only connected to the wall. If the light goes out when it's connected to the PC the your motherboard is bad.
Nov 22, 2009 | Dell Latitude D600 Notebook
I have an acer 5920 laptop will not turn on. when i plug the charger into the wall socket the charger has a constant green light. when i plug the charger into the computer the green light flashes the...
sounds like the power jack at back of computer has gone bad, check voltage of battery and see if it has good power if not then it is dead and not getting charged through port the jack at rear generally requires MB replacement and is very expensive and cheaper to get new laptop, u can remove HD from old lap top and copy data over. another choice is to get stand alone charger for laptop battery and use battery mode,
if battery tested good them there is slight chance power switch is bad
Jul 07, 2009 | Computers & Internet
I have a gateway ma7 laptop and press power and get nothing
When the computer is off, unplug the power cord from the laptop and then plug it back in. See if the charge light (lightning bolt symbol next to the led) comes on or turns green/blue. If it doesn't your power supply may not be working, even if the light on the supply is on. Second is the battery may be damaged. Remove the battery and see if you can power on at all.
If it boots with only the cord, the battery is bad/shorted forcing shutdown.
Apr 11, 2009 | Gateway MT3705 Notebook
My lap topwill not turn on.
Try to check if your AC adapter has a light itself. If it the light is off. Then try a known good adapter. If the AC light is green, then try to wiggle the cord from the port and see if it ain't loose. Try to also check if the AC pin is not bent or broken.
Nov 25, 2008 | Dell Inspiron 6000 Notebook
Acer extensa 4620Z laptop computer will not re-charge battery. The cord going to the outlet has power...green light...but no lights are on lap top and it is securely pluged into lap top. - When I...
It could be one of three things. It could be a bad battery, a bad ac adapter, or the recharging circuitry could be bad. I would try pulling the battery out, and see if the laptop will startup and run strictly off of the ac adapter. If that does not work, you have a bad ac adapter. If that works, and the battery has any charge left, try running it strictly on the battery. If it doesnt work, you have a bad battery. If it does work, the circuitry is bad and you will probably need new motherboard. One other thing you can check is where the ac adapter and battery plug into the laptop, and make sure there is no corrosion that could be causing a short.
May 10, 2008 | Computers & Internet
Computers & Internet Logo
77 people viewed this question
David Payne
David Payne
