I can not power on my washer. It is as though it is not plugged in. It was working fine and after finishing a wash cycle the next day it would do nothing. It is a GW11 top load'
we had the same **** issue with the lg washer. we fought with the company as it was only 1 year old. do you know they asked us if it was plugged in hello my husband is an electrician. they came out it needed all new brains. to bad i cant give you the brains because now the piece of **** wont finish a wash even when empty reads ue. its going out on the sidewalk for any ****** who wants to pay to fix it .
the OL error is for over load.that is when you over load the clothes in the washing machine.
If your washer doesn't spin or agitate on either the delicate or regular cycle, check these:
Clutch assembly
Many GE®/Hotpoint® washers use a clutch and an automatic shift lever. This assembly is quite complicated. If there's a problem with it, you probably should contact a qualified appliance repair technician.
Drive motor
Many washing machines have multiple-speed drive motors. Though it's uncommon, the drive motor may work fine on one speed but not on another. If the drive motor has failed on one speed, you need to replace the entire motor.
My Maytag® Neptune® washer filled with water, but it won't spin or drain-what now?
Start by making sure the machine is plugged into a live (working)
electrical outlet. Then check the appropriate circuit breaker and reset
it if necessary (or check the fuse if you have a fuse box).
Next, inspect the drain hoses and remove any kinks. Take a look at the
drain, too - if it's clogged, call your usual drain service person.
Then close the washer door and firmly press the START/STOP button. In a
few moments, after the door locks, the washer should begin to spin.
(For your safety, the washer will not tumble or spin unless the door is
closed and locked.)
If this doesn't work, please contact Customer Service at 1-800-688-9900
for toll-free assistance and service scheduling if necessary.
An obstruction in the water-inlet valve may mean that it's no longer able to shut off You can easily open the valve and clean it (from scale or other dirt). Be aware you should disconnect the power cable from machine before doing it !!!!
Good luck !
