Ever sence I have received my Model926 Printer service tag # 692tsd1 serv.code 13609638613 I have had trouble with the display not giving me the English language. I talked to the service department by telephone, for seems like a couple of hours and we got cut off. I didnot try to contact him again as I didnot know his name. Pleas help me if you can. Seems we did everythins he had to recomend. Thank you. I can't remember the day I received this unit. Edwin F. Greathouse
  • 1 more comment
  • hiyu Jul 26, 2008
    I trid running driver disc again but it didnot help to get the english to appier on the display.
    E F Greathouse
  • hiyu Jul 26, 2008
    The Printer is a DELL Photo all in one Printer 926
    E.F. Great5house
  • hiyu Jul 26, 2008
    When running the driver disc I didnot find anywhere to request a language
  • 1,183 Answers
Kindly try the following steps to solve your problem , with the language setting on the printer. If the same did not fix the issue , get the printer replaced from Dell, because if the solution below did fix your issue there nothing much that can be done.
Restore the Dell™All-In-One 926 printer to factory default settings.
To restore the Dell™All-In-One 926 printer to factory default settings, follow these steps:
Ever sence I have received - new_note.jpg Note: Restoring the printer to factory default settings will erase any data added into printer memory, such as fax phone numbers.
  1. Turn off the printer power.
  2. Disconnect the printer power brick and wait for 10 seconds.
  3. While holding down the Start and Cancel buttons, re-insert the printer power brick.
  4. Hold the Start and Cancel buttons until the power LED begins blinking and the printer shuts itself off.
  5. Turn on the printer power
Thanks
proton
Posted on Jul 26, 2008
  • Mandeep  Singh
    Mandeep Singh Jul 26, 2008
    Just an update , the driver CD doesnot have anything to change the language settings
  • Mandeep  Singh
    Mandeep Singh Aug 01, 2008
    Was, the problem with the printer resolved.
    Sergeant:
    Champion:
  • 221 Answers
If you uninstall the Printer from your PC and reinstall it back, you can solve this Problem. If this fails, you should get a Software like Iolo System Mechanic or Registry Cleaner and remove all the references concerning your Printer. After rebooting the System, Carefully run its Setup again and most probably the First Option should be Language.
Posted on Jul 27, 2008
  • 813 Answers
U have to uninstall the software of printer the remove it from the regsitory then reset your pc then after you choose the language as English while installing the drivers with a software
    Master:
  • 382 Answers
HEllo Greathouse,
Did you choose the language as English while installing the drivers??..If you had choosen so then you must not have any problem with it..Please try it!..Thank you..
Regards!!..
  • 6,487 Answers
What is the brand of this printer?
Posted on Jul 25, 2008
  • Mark Gil
    Mark Gil Jul 25, 2008
    You can just try to run again the setup CD for the printer and don't forget to select "english" for the language that should fix that problem...
    Hope that helps.........
  • Mark Gil
    Mark Gil Jul 26, 2008
    Try this one:
    To change the language on the Dell 922's display, turn on the printer, then press and hold the Power and Cancel buttons at the same time for about 10 seconds. The language choices will then scroll across the LCD.
I've got a yamaha 125/abs 2015 model and my right hand side display is indicating serv oil what does that mean? Is it normal my bike is not even a year old?
Hi, Anonymous ahhh modern technology your service indicator light means it's time for maintenance, oil change, inspection, lube cables, etc. you can do it yourself or take it to a shop. Most SIL's go by time or miles some go by engine hrs. if you want your bike to give your trouble free riding you have to give it some TLC from time to time. For more information about your question and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have a nice day.
HowTo R125 Oil Change
1st service MT125
12 Standard reset procedure for service warning light
http://www.automotivespartsshop.com/file-download/YAMAHA-YZF-R125-SERVICE-MANUAL.pdf
Download Manual 2015 Yamaha MT125 Owner Manual
Mar 28, 2016 | Yamaha Motorcycles
My printer is giving me this error message "Batch
That's a batch error, more than likely due to a communication issue between the pc and the printer. If you reboot the printer, THEN reboot the pc you should clear that error.
This error sometimes occurs when the printer has been shut down whil logged into your software, which disables communications between pc and printer. The error indicates that the printer didn't receive enough data to properly print the batch of labels/tags.
Sep 14, 2011 | Paxar Monarch 9825 Thermal Label Printer
I have a HP C5180, receiving error message 0xc18a0206 Ink System Has Failed. I have replaced all cartridges, unplugged power supply and USB cable for reset and am still receiving error message. Help! ...
Issue An 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution
  1. Press the On button to turn the printer off.
  2. Unplug the power cord from the back of the printer.
  3. Remove all the ink cartridges.
  4. Wait two minutes.
  5. Plug the power cord into the back of the printer.
  6. Press the On button to turn the printer on.
  7. Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved. If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
Mar 09, 2011 | HP Photosmart C5180 All-In-One InkJet...
The service brake system light comes on and the 4 wheel drive selector switch works sometimes and sometimes doesnt
i had same problem ...i changed frt brks washed underbody service 4wd and then dissconnected - batt wait 5 min then road trip no more problems
.gm glitch computer doesnt sence original perameters so it send trouble codes
Feb 15, 2010 | 2003 GMC Sierra
This err number whit ist
hello there here is some information that may help you solve this problem ok?
best regards michael
  1. Printer Repair And Service Tools: Ir3200 error code e000677-0004 Canon Multi-Pass Fax C855 waste tank reset code ... Canon Error Code, E000, E001,E002,E003,E004,E005. Ir3200 error code e000677-0004 ...indoresetter.blogspot.com/2009/02/ir3200-error-code-e000677-0004.html - 82k - Cached
  2. C3200 Problem Solving at FixYa how do I reset this code? canon ir 3300. 1 Solution. after pressing *28 it come download mode ... e005 an error canon 6330. the quality of four colour is very ...www.fixya.com/tags/c3200 - 89k - Cached
  3. E004 Problem Solving at FixYa along with e001 and e005... HP Pavilion dv2000t PC... Problem Event Name: APPCRASH ... codes with this model np 7161 e004 iwant to know how to get in reset program...www.fixya.com/tags/e004 - 92k - Cached
  4. The Copier Network - Canon 6085 E5 ... what this code means or how to reset it any suggestions? ... E005 is fuser web out. clear web counter. techla. I replaced the web just coundn't reset the code. ...www.thecopiernetwork.com/printthread.cfm?Forum=87&Topic=18014 - Cached
Sep 14, 2009 | Office Equipment & Supplies
I purchased a Dell Lattitude D630 on eBay a couple of months back. I am now having a problem with a blue screen comin up and the system freezes up. The service tag and express service code has been...
Dell's web-site has a "automatically detect my system" which will determine the Dell Service Tag, and display it. Or, start your computer, and enter BIOS SETUP. Browse through the various menu items, and the Dell Service Tag will be displayed.
Jun 04, 2009 | Computers & Internet
Hp photosmart 3200 all in one ink system failure
I know this sounds crazy but I did this and others have too, it worked. Hold down four buttons at the same time ( OK, Cancel, Black , Color ) and turn the power off. Note: I figured out how to hold the 4 keys down with one hand and push the on/off switch at the same time. Once you power the printer back up is will take a few minutes to go through maintenance. Then it will “hopefully” go back to normal. I did this 2x’s. HP gives you a procedure that doesn't work! They just want to make money off fixing it every 6 months. They are in the service, repair and “ink business” not printer manufacturing.
Nov 05, 2008 | HP PhotoSmart 1215 InkJet Printer
Zebra tlp 2844 trouble
Verify that the ribbon fits into position, back and forth. You can also calibrate the label by pressing the button while powering up the printer and release the button.
Aug 02, 2008 | Zebra R2844-Z Label Printer
Canon 1140 trouble shooting
Been a while ago on the Canon but if memory serves me Error E005 means the cleaning web has run out. Needs replacing and resetting (replace then code 28 i think).
Oct 09, 2007 | Office Equipment & Supplies
278 people viewed this question
k24674
jasbo
jasbo
