Canon LASER SHOT LBP-2900 Printer Logo
Posted on Feb 18, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Paper jam - Canon LASER SHOT LBP-2900 Printer
Anonymous
Level 3:
  • Master 844 Answers
  • Posted on Feb 18, 2011
Anonymous
Master
Level 3:
Answers
844
Questions
Helped
418742
Points
2542
1. Disconnect the power printer power cable.
2. Open the panel of the toner and take out toner.
3. You should be able to see the paper. Take it out slowly and be careful not to tear the paper.
4. Clean it with a dry cloth.
5. Return back the toner, close the panel and connect back the power cable.
It should work fine now.
Paper jams at toner cartridge, printer service maintenance kit installed
Paper Jam clearing: copy and paste the link in your web browser...I used to work with these printer's..when they work great, when they don't, not so great..
https://www.manualslib.com/manual/949165/Hp-Laserjet-5000.html?page=84
Clearing Paper Jams If the printer's control panel displays a paper jam message, look for paper in the locations indicated in Figure 22, then see the procedure for clearing the paper jam. You might need to look for paper in other locations than indicated in the paper jam message. If the location of the paper jam is not obvious, look first in the top cover area.When clearing paper jams, be very careful not to tear the paper. If a small piece of paper is left in the printer, it could cause additional jams. If paper jams are a recurring problem, see page 78.(A paper jam message might also display if the rear door is open.)
The top cover of the printer must be opened and then closed to clear a paper jam message.Paper jams can occur at the following locations:Output areas(top and rear)Go to page 75.
Loose toner might remain in the printer after a paper jam, but thetoner should clear after a few sheets are printed.
When i switch on my photocopier tohiba 2860, it asks for service and gives an error code 08221-918100. what could be the problem?
Hi tkasirye,
Welcome to Fixya.
You may need to check again the error code. According to the manufacturer's checklist for error codes, only the following are documented;
  1. Error Codes - Toshiba 2860
  1. "E01" Paper jam inside machine. "E02" Paper jam near the fuser. "E03" Paper jammed inside machine when power supply is switched on. "E04" Front cover open while copying. "E05" Paper jam near the aligning roller "E08" Paper jam at stacking area in the ADU "E11" Paper feeding jam at the ADU "E12" Manual feeding jam "E13" Paper jam from cassette 1 "E14" Paper jam from cassette 2 "E15" Paper jam from cassette 3 "E16" Paper jam from cassette 4 "E17" Paper jam from cassette 5 "E19" Paper jam from the LCF "E21" Paper jam in transport route 1 (LCF) "E22" Paper jam in transport route 2 (COPIER) "E23" Paper jam in transport route 3 (ALIGNING) "E25" Paper jam in transport route 4 (PFP) "E71" Original feed jam in ADF "E72" Original transporting jam in ADF "E73" Original exiting jam in ADF "E75" 2nd original feeding jam "E81" Paper jam before sorter "E82" Paper jam in sorter "E83" Sorter early arrival jam "E84" Paper in sorter when power is turned on "E85" Joint open jam while copying "E88" Paper jam outside the sorter bin "C01" Abnormal operation of the copier main motor "C04" Abnormal operation of the PFP main motor "C05" Abnormal operation of the ADU main motor "C11" Abnormal operation of the ADU side motor "C12" Abnormal operation of the ADU end motor "C13" Abnormal operation of the upper cassette tray "C14" Abnormal operation of the lower cassette tray "C15" Abnormal operation of the PFP upper cassette tray "C16" Abnormal operation of the PFP middle cassette tray "C17" Abnormal operation of the PFP lower cassette tray "C18" Abnormal operation of the LCF tray "C21" Optics carriage initialize error "C22" Lens initialize error "C23" Mirror initialize error "C26" Faulty exposure lamp "C33" Easy set-up is failed "C35" Developer material exists at the transfer separation adjustment "C41" Faulty thermistor or heater "C43" Faulty thermistor "C44" Faulty heater "C45" Sub thermistor is open
Shoulg you not find any of these mentioned error codes, I suggest you contact the tech support especially if the machine is still under warranty.
Hope this helps.
Takasashi
1helpful
2answers
Error e03, but there is no jammed paper
E, 0, 3
Paper Output Tray is closed / Paper jam
Summary
If the Paper Output Tray is closed, open it. The machine resumes printing.
If opening the Paper Output Tray does not resolve the problem, or if the tray was open to begin with, the paper may be jammed. Remove the jammed paper, reload paper properly in the printer, then press the Black or Color button.
E, 0, 3
Summary
E, 0, 3
Summary
Techbelkin
1helpful
2answers
I have a Epson stylus CX9400fax a piece of paper is jammed way inside the machine, I can't even see it to try and get it out! I've tried turing the machine on/off numerous time (still not expelling the...
If paper is jammed, a Paper jam message will appear on the control panel display.
Follow these steps to clear the jam:
  1. Gently pull any jammed paper out of the output tray or sheet feeder.
  2. If the paper is stuck inside, turn off the Epson Stylus CX.
  3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
    alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
If paper jams inside the Automatic Document Feeder, clear the jam as follows:
  1. Open the Automatic Document Feeder cover and remove any jammed paper.
  2. If necessary, lift the document cover and remove any paper that has jammed inside.
  3. Press OK to clear any messages on the display screen.
4helpful
2answers
Stylus CX9400 Photo Printer: paper jammed inside printer...
1helpful
2answers
My canon MP620 Paper Jam Pull out the Jam Paper Al
There are pieces of paper stock on the sensor, when the paper jam happened then you pull out the paper did you get the whole page of the paper or have missing pieces? open the paper guide, turn off and on the printer and observe the unusual objects in the roller, this error is caused by objects in the sensor.
Getting the error on my HP 4345mfp - TOP OUTPUT BIN, PAPER LATE JAM. 5017-Oct-2009 02:02 PM18209913.09.0048.081.2TOP OUTPUT BIN, PAPER LATE JAM 4917-Oct-2009 02:00 PM18209613.09.0048.081.2TOP OUTPUT BIN,...
my experience says jamming in duplex area using card stock. this may occur if default is duplexing. set default to single side and / or try same job using plain a4 80gm2
2helpful
Paper Jam
Good day, Check the table below about the problem of paper jams.
Display and Meaning
[Paper Jam 0] - Paper has Jammed in the feeding area of the paper input tray.
[Paper Jam 1] - Paper has jammed in the fuser area or in the manual feeder.
[Paper Jam 2] - Paper has jammed in the paper exit area.
hope it will help you.
old marine
old marine
ZJ Limited
ZJ Limited
