Question about Speed Queen CGS68AWF Gas Dryer
Speed queen commerical dryer
The Gas ignits and works for a few minutes. I then have to open the door foir it to restart again. I think the thermostate is over heating.
Try replacing the gas valve coils. they are cheap
Posted on Jul 28, 2008
Speed queen gas dryer, at least 20 yrs old: the igniter begins to glow, then fades out, there doesn't seem to be gas ignition as the chlothes are not drying...so?
Sounds like you may need some coils. Mine would heat up for a minute then go out. The coils were my problem. They are located close to the igniter. They come 2 in a pack and you have to replace both. Probably $20
Oct 07, 2017 | Speed Queen Dryers
Will function the first time then will try to restart burner will not relight
I am a HVAC guy by trade
If it was a furnace which there really isn't too much difference here is what I would check
Ignition Control
Flame Sensor
Could also be the gas valve intermittently not working too
Aug 23, 2013 | Speed Queen AGS28AWF Gas Dryer
Speed Queen gas dryer model #AGM499W. Replaced the igniter but did not fix the problem. Dryer will not heat.
burner may need to be vacuum out or blown out, also could be the thermo coupler. Hope this helps tim
Sep 02, 2010 | Speed Queen AGS28AWF Gas Dryer
Dryer does not heat. Electric ignition does not "spark" lighting
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 04, 2010 | Speed Queen AGS28AWF Gas Dryer
Sounds like something is loose inside the dry drum
Unplug dryer!!
There should be 2 5/16th screws on the bottom panel in front. Then there are 2 more on bottom of top panel. Take off wires to door switch. Take off 4 screws to front bulkhead. Pull it off. Note how belt goes on. Take it off and pull drum.
I would first rotate drum by hand and see where noise is coming from. If inside one of the baffles in drum, you can easily lossen up screws to remove baffle to get things out.
Jan 10, 2010 | Speed Queen AES28AWF Electric Dryer
Maytag Neptune MDG 5500 AWQ heats sporatically
your dryer has a safety feature that it will not run or heat when the door is opened. It is so no gas fumes are exhauseted into your home. Once the safety is engaged, It will not allow the dryer to restart for a short while. It should clear itself after only a few minutes. Hope this helps, good luck.
Apr 18, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Speed Queen dryer does not heat...
you have weak gas valkve coils and they will work when cold but after a few cycles they become electrically open and will not allow the gas to flow.
just replace both gas valve coils and that will fix your problem.
Dec 29, 2008 | Speed Queen AES68AWF Gas Dryers
Speed Queen gas dryer won't heat
probably not most likely bad coils on gas valve the 2 black dohickys with wires
Jul 23, 2008 | Dryers
Speed Queen CGS68AWF Gas Dryer Logo
209 people viewed this question
Top Speed Queen Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
danoyachtcap
danoyachtcap
Are you a Speed Queen Dryer Expert? Answer questions, earn points and help others
