posted by alfredw1 on Jul 25, 2008
Whirlpool LSW9750PW3. The washer has an intermittent problem. When it works it works great. When it malfunctions (using permanent press cycle), the washer will fill up and then the timer will stop working, a smell of over heated electical wiring can be detected. The washer will not work at any cycle setting. After turning off the washer for about 15 minutes, the washer will work properly again.
Best Solution
posted on Jul 26, 2008
sounds like motor contacts in timer may not be closing properly motor is trying to start but with contacts not right it overheats and shuts off ..also may be motor start switch that is where the wires connect to motor also ckd motor connector closely to may sure there is no loose connection between it and motor connections
Rating Locked! (?) alfredw1 has rated this solution as Helpful
This Problem Also Relates To:
Whirlpool LTE6234D Top Load Stacked Washer / Dryer
Whirlpool LSQ8000 Top Load Washer
Whirlpool GHW9200L Front Load Washer
Whirlpool 3.2 cu. ft. Super Capacity Plus Top Load Washer
Whirlpool GST9679P Top Load Washer
Whirlpool AWM8123 Front Load Washer
Whirlpool AWM8143 Front Load Washer
Can you Help with these Washing Machines problems?
Frigidaire Affinity ATF7000E Front Load...
LOC message on display -...
Three beeps and periodically... Answer This...
Kenmore 3.2 cu. ft. Super Capacity Plus Top...
Kenmore Washer problem with...
Agitator spins very very slowly... Answer This...
Repair Service
Find Washing Machine Repairman Near You:
Find Parts
