Question about Sony Playstation 3 (PS3) Console
PS3 tuning problem
I used to use my PS3 on a non HD TV. I then changed to an HD TV and it works fine but it will no longer work on a non HD TV - I just get a blank screen. Do I have to re-tune it? Can anybody help?
  • 344 Answers
Hello. This is what you need to do.
1. Reset the Video Output Settings. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings. Once you turn it back on, it should work fine.
I hope this helps. Good luck to you.
Posted on Jul 26, 2008
WILL NOT POWER ON
4 things:
try checking the power plug is in the socket properly
try checking tv is plugged in properly (hdmi cablewill not work with non hd tv)
your ps3 is ruined or just try and hold don the power button to get it to the new tv graphics if you had it on hd and ur trying to get on a non hd...or other way around. ifyou have any more problems send me a message on this site (if you can lol).
any way i probly had the same problem causei bought a ps3 from ebay it use to be on hd tv but i put it on non hd tv. i helddown the power button and it came back to life.
ps you can buy non hd tv cables on ebaay for cheap prices...it's what i did lol
Feb 13, 2013 | Sony Playstation 3 (PS3) Console
Tip
Chances are ur trying to use a HD tv but u have the settings wrong on ur ps3. so...
Hi there
The no display problem is very annoying as you check all your cables and everything is fine but still nothing shows up on the screen,
What is the no display error
Again this problem is pretty much what it say's, you know you have this when you have no display on the tv when the PS3 is all set up correctly
The Causes
The basic causes are cables not connected correctly or you have a cable that is not compatible with your Tv/PS3
It can also be PS3 settings that are not correct.
The bigger problem is the Display chip internally or hardware failure.
The Solutions
Solution 1
Ok so you can send the console off to sony they will collect it, repair it and send it back, this will usually cost you $150
Solution 2
My favourite solution is the PS3 repair guide, you can fix the problem within the hour, costs are below $40 and you don't need to be technical at all.
Solution 3
Buy a new PS3 console over $200 this is the last resort.
What is PS3 repair guide
Ok so this is how i learned so much about PS3 and got me into the job today of fixing PS3's
The basic PS3 repair guide: is a high quality Pictured ebook, with the most basic step by step instructions that will fix your PS3
A good PS3 repair guide: This will contain the above mentioned and will also have a website which you can get 24/7 tech suppot to help with the fix, A forum with over 60,000 user's who have been in you position and can help you. Also some have great step by step video's.
The PS3 repair guide Comparison site
Ok i want to introduce the PS3 Problems gone Website this will be pivital in helping you choose the best repair guide, to get the best head start in fixing your PS3 you need to see the best repair guides on the Web today.
Conclusion
Ok so get your ps3 fixed get back to gaming and if anything else happens to fail you have your back up with the PS3 repair guide as its your's for life.
Good luck and happy gaming
on Jul 08, 2010 | Sony Playstation 3 (PS3) Console
Will not tune in to my non-hd tv
You need to reset the A/V out settings.
Have your PS32_bing.gif in standby mode (solid red light). Press and hold the power button, you will hear one beep (power on), then you will hear another beep (reset). Release the button at this point and the video should reset and work on your standard TV using the red/white/yellow RCA cord.
Thank you!!
Apr 12, 2010 | Sony Playstation 3 (PS3) Console
Was playing my PS3 on an HD Tv but cant get it to work on a non hd tV
go to
settings>display settings>video output settings
and then you change it to
AV MULTI/SCART and it should work :-)
Nov 28, 2009 | Sony Playstation 3 (PS3) Console
PS3 not working on reg tv's after HDMI use on LCD HD tv
Shelley,  the fix for this is simple! Hold down the power button for about 5 seconds and the system will beep. This resets the video setting for your ps3 from HD too whatever the current cables are that you are using too hook up too the tv. This works on my PS3 which I just bought about 3 months ago and should work with the older ones.
Jun 05, 2009 | LG 37LC2D Television
How do we change PS3 settings from HDMI back to non HD?
switch it to standby then hold the power button for three beeps(not including the first power on beep)this should open a troubleshooting menu,pick option 2.If it doesnt give you the menu first time,switch it off at the back and repeat the steps again.Good luck.
Apr 21, 2009 | Sony Playstation 3 (PS3) Console
Acoustic Solutions 26'' HD TV cannot play PS3 blue ray films
I have recently brought the same TV and had the same problem but I've mangaed to find a soultion.
The automatic setting for Blu Ray on PS3 is Full HD (1080p) but the Acoustic Solutions TV is HD ready (720p). For PS3 games it will automattically change settings for you to 720p. This is why this works straight away but Blu Ray doesn't.
Solution
You need to plug in your PS3 using the scart contection, then on the ps3 menu go to settings > display settings > HDMI. You will then need to attach the HDMI cable and manually set up
HDMI by checking the 720p option and deselect 1080p.
That should then play Blu Rays too. You don't lose too much quality as 720p works nearly as well as 1080p on smaller TVs.
Rich
Feb 18, 2009 | Televison & Video
Having trouble playing my Ps3 on a non HD tv after already using it on a HD tv
Hey bro try going down to circuit city, best buy and get the HDMI cord that converts to a Component cable on the opposite end. You can do this as long as the back of the non H/D tv has the Component Inputs on the back of the TV. If that does not work get the HDMI cable that converts on the opposite end to a S Video signal and connect that end to the S Video input on the back of your tv. I have seen these cables at circuit city in the playstation section. Again on one end of the cable it has your HDMI input to connect to your ps3 and on the opposite end of the cable it has the S video plug to run to the back of your tv and plug it into the S Video input. Same thing can be said for the HDMI on one end of the cable and the Component cables on the opposite end to run to the back of your tv. This will work if you find those cables. Good Luck.
Sep 16, 2008 | Sony Playstation 3 (PS3) Console
Ps3
hold down your power button when you turn it on, for 5 seconds, it runs the screen settings menu and puts it in the best possible option for the leads fitted. hope this helps
Jan 22, 2008 | Sony Playstation 3 (PS3) Console
PS3
You need to reset your video settings when you move to a regular TV. Just hold down the power button, it will beep twice and go back to stand by mode. They boot up again and your video setting should be back to normal ( for standard TV).
Bimmerhp
Dec 07, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
120 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
