Question about Vivitar ViviCam 4345 Digital Camera
Batteries Cam was working perfectly until I changed the batteries, now nothing not even any flashing lights or any thing. Steve
  • 3 Answers
This may sound silly, but you did put KNOWN good new batteries in? I have had several problems with my 4345 and they are all battery related. My theory is that when the camera is first turned on there is a lot of juice drawn from the batteries (electronics, lens cover). Unless you use really topgrade batteries (=expensive) they just can't supply the peak current. The bargain 8 for a quid packs are very variable - some are fine, others give up the ghost within minutes :-(
About the only good news is that "old" batteries, discarded from the camera, go on to provide good service in radios, clocks, CD players etc.!
Posted on Aug 25, 2009
Tail lights and dash board is not working
if its just the cluster flashing chanses are it needs to be sent out for repair but try diconecting the battery for a bit then reconect it and see if any thing changes also check and see if teh battery is good low voltage can cause strange things to hapen
Feb 11, 2014 | 2007 Chrysler Sebring 2.4
Tcs light flashes and p0340 code
P0340 code means "Something" is wrong in the timing...
from CMP (Camshaft Position sensor) to the crankshaft bolt.
Very first thing, verify connectors are clean and shiny.
clear all codes, even hard codes.
Nov 23, 2013 | 2005 Mazda 6
99 manual escort loses power going up inclines/runs hard at times/check engine light flashing even though oil change recent and fluids appear ok
Hi Steve, Take the vehicle for a diagnostic scan. The engine check light is indicating a fault and has nothing to do with service requirements. Regards John
Oct 27, 2013 | 1999 Ford Escort
Suzuki wagon r+gl check engine light keeps flashing and wont start after battery change
the engine (there are more than one engine)
has a distributor.
"have spark at coil down to dizzy but no spark at plugs"
this can mean only 2 things.
1: spark wires are dead. all 4, kinda hard to believe huh?
2: the dizzy is way off time. so time the dizzy and now spark
lands on each wire term.
if not a dizzy engine, post exact version of engine and country.
Apr 14, 2013 | Suzuki SX4 Cars & Trucks
03 JEEP wrangler Rubicon 4.0L missfire on cylinders 1,2, and 3!
bad fuel pump can cause this or plugged fuel filter but i believe they are one unit
Jul 30, 2009 | 1998 Jeep Wrangler
I Can`t switch my headset on, and it stops charging after 20 secs
Move the call control button up or down, the indicator light will flash blue if it's paired or blue and red. If it flashes blue and red you need to pair phone with the headset. the passkey is 0000.
Jun 17, 2009 | Plantronics Explorer 340 Wireless Headset
Red light continually flashes, and won't take picture
Set the camera to anything except no flash. Turn it off. Take out the battery. Wait 5-10 seconds. Put the battery back in. The flash should now work until you turn the camera off again (and then you must remove/replace the battery to get the flash working again).
The flash requires some kind of "master reset" to work. Haven't found a permanent solution to this.
Mar 05, 2008 | Casio EXILIM ZOOM EX-Z850 Digital Camera
Red light flashing
I had the same problem last night. It went away when I recharged the AA batteries.
Jul 23, 2007 | HP Photosmart 945 Digital Camera
RCA 52" HD Widescreen
Only thing can suggest is try the bulb itself to see if it got damaged in transit.
May 22, 2007 | RCA HD52W56 52" Rear Projection HDTV
Vivitar ViviCam 4345 Digital Camera Logo
42 people viewed this question
Top Vivitar Cameras Experts
Tony
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
