Question about Back to Basics 600 Smoothie Plus Work Top Blender
I have an old commercial blender and I took it apart to clean it, the washers fell apart and I bought new rubber ones I had to cut to fit but I can't remember the order of rubber washers and metal one. I think-1 rubber 1metal outside and 1 metal, 1 rubber & 1 metal inside. dose that sound correct? Maj-Lis
    Problem Solver:
  • 16 Answers
Plz cont -- 23051554 \ 23095757
Posted on Aug 05, 2008
The piece thaat makes my vitamix turn fell off
Sounds like your drive socket broke. Use a small allen wrench to loosen set screw under arrow on drive socket. You will have to order a new socket from Vitamix. Hope this helps.
Apr 29, 2012 | Vitamix 5000 Work Top Blender
My blender appears to be leaking from the bottom. Is it likely to be the jug or the coupling to the motor?
It is likely to be the rubber washer on the jug. You will need to disassemble the mixing blades and remove the rubber washer(s) from the jug and take it with you to a Target, Walmart or kitchen store. They usually carry a varity of the washers and you should be able to compare yours to get the right size. Some actually tell you exactly what mixers they fit.
Nov 25, 2010 | Waring 6000CG 60th Anniversary Blender
Rubber washer for Model TSK-9368AP Blender
I just fixed mine with a rubber hose washer. I had to cut the washer in half because it was too thick, but it stopped the leak!
Mar 29, 2010 | Blenders
Osterizer Blender
You can replace the Osterizer "Standard Blade Assembly" (which includes a new rubber gasket) without buying a new and expensive glass jar. See http://www.householdappliance.com/blenderparts.html or one of the other appliance repair parts websites. After 20 years of use, it's time for a new blade and bearing.
Feb 27, 2008 | Blenders
How to install replacement part
You need the remove the old gray rubber knob. I did it in a barbaric way just hacking at it with scissors. Once you've removed all the rubber, you can use pliers to remove the remaining metal base. Once that's removed, place the new piece on the post and spin it on. Most important, spin clockwise to loosen, not counter clockwise like most items.
Oct 25, 2007 | Blenders
Kitchen Aid Blender Rubber Coupling replacement
Someone else suggested a link that explains exactly how to unthread the old coupling... and it works. It took me about 90 seconds to fix my blender. But in case that link is dead, here's a summary:
(1) Note that the coupling (the round part with teeth) is threaded to the blender motor in reverse to a standard threading. So it screws off just like a bottle top, but in a clockwise direction.
(2) place the blender base on a tabletop, facing you. You should probably unplug it.
(3) take a punch or a flathead screwdriver, and place it against one of the coupling teeth that is furtherest away from you.
(4) strike the back of the screwdriver with a small hammer or maillot. The result will spin coupling clockwise. It may take several tries, but the coupling will eventually spin clockwise faster than the motor, and it will begin to unthread.
(5) unscrew the old coupling, and screw the new coupling into place (counterclockwise). Note that the new coupling will tighten itself every time you use your blender, so no need to worry about tightening it too much.
(6) Make a smoothie to celebrate your success!
Aug 13, 2007 | KitchenAid KSB5 Professional Stainless...
How to replace the rubber drive in Krups 572?
it's not easy. you will need a set of pliers, a flathead screwdriver, and a phillips screwdriver. first, remove the 4 rubber plugs from the bottom of the blender (just work them out with your fingers). second, use the phillips screwdriver to unscrew the 4 screws that were under the ruber plugs. the blender should come apart. right in the bottom center on the inside of the blender you should see a steel rod with a groove in it. this rod will run all the way to the top and be connected to the rubber gear drive on top. get a firm grip on the rubber gear drive with your pliers. place the flathead screwdriver into the groove of the steel rod and unscrew. it will be very tight, but eventually, it will give. you will most likely destroy the old rubber gear drive in the process, but the idea is to replace that one anyway. good luck!
Q. Mosley
Jun 09, 2007 | Krups 572 Power Xtreme VI Work Top Blender
Back to Basics 600 Smoothie Plus Work Top Blender Logo
81 people viewed this question
Top Back to Basics Blenders Experts
Mike
Are you a Back to Basics Blender Expert? Answer questions, earn points and help others
