Question about Xerox WorkCentre XD100 All-In-One Laser Printer
Broken fuser gear
Do you have instructions on how to get the fuser out and replace the broken gear and then reassemble the fuser and replace it in the XD100? I don't know how to get it all the way out with the wires attached.
Thanks the pictures you posted are exactly what mine looks like!
  • 42 Answers
To access wires/connectors
remove back cover 4 screws
open and remove right door 2 screws on back frame one with small spring attached
remove fuser unit with 2 screws unplug 3 connectors
on back of copier.
remove one screw on wire end of fuser/cut ty wrap with wire cutters be careful not to cut wires!!
pull off cover
remove heat lamp by pulling on copper end piece
slide lamp up and out
remve small c shaped retainer ring from end of roll with 2 small flatblade screwdrivers
take off old gear and install new one-lubricate bushings with a few drops of fuser oil on both ends
re-assemble in reverse order.
any questions just ask!!
Posted on Aug 20, 2008
I am sorry to say that I don't have any additional information. I was asked to look at the broken copier by a friend, and after using this site for additional information, I suggested that he call for repair. I was not present for the actual repair, although I took a picture to try to help those in a similar situation.
I suggest using a copier repair service, provided you can find a reasonable estimate. From what I gathered, it's a delicate replacement.
Best of luck!
Posted on Jul 26, 2008
149.05 c782 error
Not a very fast job if you end up having to replace the motor itself. But thats the fuser motor PN = 40X1661. You can pull the fuser out look to the right side and see a white gear find. A lot of time that gear or the ones around it are worn out. Every now and then its just the fuser itself has broken gears or something is stuck in the gear.
Jul 15, 2014 | Lexmark C772dn Laser Printer
Missfeed 010B canon ir7105
Your fuser assembly is not rotating, the drive gear is broken, the bushings inside the bearing is broken or worn out.worst case fuser drive motor. those fusers are rated at 500k. Take the front cover of the fuser assembly off and inspect that area for the problem. look for broken gear.
May 22, 2014 | Canon Office Equipment & Supplies
Fuser open message not a broken gear
the fuser unit got a thermal fuse on need to replace. it over heat and the the power do not go throgh
Dec 02, 2011 | Brother MFC-8640D Printer
Fuser drive gear is broken
Here in Pakistan the cost of fuser gear is just 700 Rupees.You have to replace it.There is no other cannot repair will not work properly.
Nov 14, 2011 | Minolta EP4000/5000 CS/PRO Copier
My HP Laser Jet 4 makes noise when I turn it on, but it indicates Ready. What could be causing this?
This sounds like you have a broken part called a fixing coupler. To check this unplug the printer, now turn the printer around so you can see the back side. Open the fold down cover. You will be looking at the fuser assembly. There are 2 screws that hold the fuser in place, remove them and pull out the fuser assembly. Now look inside the printer on the left side behind where the fuser was located. You should see a gear assembly. This is the fixing coupler. The small gear that is closest to the rear of the printer is the one that breaks and caused the issues you are having. Look over the gear and check if it has broken teeth. You can turn the gear by hand to look all the way around and see all the teeth. If you do find the gear is broken then you will need to replace the assembly. The procedure is fairly simple, if you can use a screwdriver then you can do the repair. We carry this part in stock and you can contact us at if you need more information.
I hope this helps, if so please rate our solution.
Corporate Computer
Nov 24, 2010 | HP LaserJet 4 plus Printer
Panasonic UF-9000 Laser Printer/ Fax, E04-01 Error Already Replaced Fuser Assy. for Grinding noise & broken fuser gear.
Hmm, that is still a fuser error for sure, was that the same error you had before you replaced the fuser assembly? You did replace the fuser itself with the assembly, correct?
Let me know
Sep 24, 2010 | Panasonic Panafax UF-9000 All-In-One Laser...
My printer keeps jamming. I have replaced the
The most common cause for jamming every copy on this model is a broken fuser drive gear. If you open the right side door you have a gate that flips open with a bunch of "teeth" on it. This gate is part of the fusing unit. If the paper always stops in this area when entering the fuser it is a broken drive gear. Your Xerox is made by Sharp. The part number for the gear is NGERH0540FCZ3
Perhaps you can find a local repair person who can replace it for you.
Good Luck
Nov 24, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
How to change the fuser gear in Brother MFC 8660DN Printer
I recently changed the fuser gear on my MFC-8840DN (a similar machine) and type up detailed information. The pdf file of the instructions has been posted at:
Hope you find this helpful.
Sep 07, 2009 | Brother MFC-8860DN Printer
Schematic of the Xerox XC865
Usually you can find the place to put the part by noticing the location of mounting holes or an obvious space on the fuser where it should go. Otherwise you might check with some of the places that sell replacement fuser assemblies. They might be able to send you an exploded view of the fuser.
Mar 10, 2009 | Office Equipment & Supplies
Here is a picture of the aforementioned broken gear, with a replacement gear visible for comparison:
From a different angle:
The printer repairman said that the plastic gear found in this and similar models can fail after as early as a few months of use. Best of luck!
May 08, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
Xerox WorkCentre XD100 All-In-One Laser Printer Logo
193 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
