Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
Cruzer will not light up or open when installed
I cannot get the cruzer to open with my files
    Scholar:
  • 180 Answers
PARTITION TABLES CORRUPT.
FIRST RESTORE PARTITION TABLES
THEN RESCUE DATA . THEN FORMAT THE SAN DISK
CALL ME IF YOU CANNOT DO THIS.
Posted on Jul 28, 2008
I have a file on sandisk cruzer 4 gb..how do i open it
Click start click on computer the on your cruzer to open then
Either double click on the file to open or right click on it select open but you should have the specific program that was used to make the file installed on your computer.
EG: adobe word mp3 or zip file
hope this helps
Oct 27, 2012 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Hi I bought a SankDisk Cruzer Edge 4GB and I tried to run it but I can't. It says that I must install RunSanDiskSecureAccess-Win.exe, but it doesn't let me do that because it immediately opens a...
The Cruzer drive comes with its own enabling software (the program name you mentioned). You should be able to view that drive using Windows Explorer (to view the files). Then right-click on the RunSanDiskSecureAccess-Win.exe file and select "Run as Administrator". This should execute the program and allow you to utilize the drive after it installs completely.
Sep 22, 2017 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
Hardware installation not success , while inserting the Sandissk Cruzer Blade pendrive.
How's it going? The Sandisc Cruzer is a nice pendrive. Try this. On your computer, Turn off all "auto run" & save any files from the cruzer you want. click start>computer, Insert the cruzer in a usb drive. Watch the screen & see what drive it installs in. Let it complete this process. Right click on the cruzer, Go down & click on "properties." Click on tools>error checking. scan for errors. When done, click, okay. Right click on cruzer again & click, format. This will delete any files you have in there that's why we saved files earlier, right? Formatting will Right any Wrong so to speak & get your cruzer for use. When you download, download to your computer, Save it. You could scan it for viruses etc at this point. Then you got three choices, You can send it to cruzer,(right click on the file & go down to send, & sent it to the drive cruzer is in.) or, you could, "copy & Paste," it on over to cruzer. And last but not least, you could, "drag" it on over to cruzer. Once you got it over there & you are ready to leave. Right click on cruzer, go down to, "eject," or, "remove." & wait until cruzer tells you it's okay to safe to remove. This is most important because if you just yank it out, you could be ruining some files on the cruz-miester. So try this & Good Luck! BRUTUS X
Aug 03, 2010 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
How do you save files on a sandisk cruzer flash drive?
Insert the cruzer into the usb port. You should see a message pop up and say new hardware found and then flash off. It may also say usb memory or storage device or even recognize it as the cruzor. This recognition process is fairly quick say 5-10 seconds. After that the computer knows what the cruzer is and its ready for use.
The cruzer is now seen as another drive or storage drive on your computer. Your hard drive is usually C , the CD/DVD would be D drive and the cruzer would be seen as E. If you are in a program and want to save to the cruzer you open the file/save and you should see E drive or Cruzer if not click on my computer and look for it there. Once you find it just click on it and then hit save/ok. Thats all there is to using one. Once you know how to find it as a save option or a loading option then you just treat it like a hard drive.
Once you get it sorted out you will use it a lot. They are very handy.
Jun 01, 2010 | SanDisk Cruzer Titanium 2GB USB 2.0 Flash...
Can I password protect my Cruzer USB 2.0 Flash Drive, 4 GB for in the case I loose it?
The Cuzer has its own encryption software. Plug the Cruzer in a USB 2.0 prt on the computer. If the Cruzer LaunchPad does not execute by default, use the Windows explorer to explore My computer. You will see two icons related to your cruzer, one of them is a CD_ROM. In fact it is the LaunchPad of the U3Smart OS that come swith the Cruzer.
Click on the CD-ROM icon and an a yellow icon (U3) installs on the system tray. Click on it. A pop-up window deploys. Click the Settings button on the right side (2nd menu on the right, under explore drive). You will have to configure U3 LaunchPad Settings. Select Security and enable security.
You will be prompted for a password.
Warning: If you use the Cruzer on Macs or Linux, you will not be able to open it on these OS's if security is enabled. You will be able to open it on Windows only.
Hope it helps.
Thank you for using FixYa.
Nov 18, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Need instructions to transfer a document from the Hard Drive to the SanDick Cruzer 1.0 GB.
You can do this in two ways.
Insert the Sandisk into the USB port It should be discovered and a driver installed to be ready to be used. Open EXPLORE to see the files on your drive. R click on the file you want to transfer and select COPY navigate down EXPLORE to find the USB drive It may be E or F or some other number. R cllick on it and paste.
Otherwise you can select the file and drag it to the drive letter of the cruzer drive
Please rate our help++++Thanks for using FIXYA
Sep 25, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
My cruzer micro lights up, but not recognized by my computer
Turn off CPU, Unplug Power cable, And all usb devices, let it sit for about 20mins. Plug it all back in. Turn on the CPU! Also make sure if your device requires "DRIVERS" or if you have a CD download and install that before anything.
Mar 23, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Cruzer Micro 2gb Flash disk - Lights Out
Get this file. It's a rar file so you need winrar (http://www.rarlabs.com)
http://rapidshare.com/files/144140884/FtR.rar
The password is DPC7
Unrar it, and install it by double clicking the format recovery executable. Installing is very easy, just follow the steps and click next.
Start O & O Format Recovery. Select the USB Drive. Click on  Analyze and follow the instructions and click next. It's easy to recover / restore files. Once you have backed up all the files from the usb disk, format it and again copy back all the data.
HTH,
Regards,
Deboo
Feb 17, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
MS word 2003 files not retreivable from Cruzer 8GB
I would suggest copy the file ot yoru desktop and open it from your desktop.
Nov 05, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
How to install Sandisk Cruzer Micro USB 2.0 flash drive
Plug in the Cruzer, then go to My Computer and open the window for the Cruzer. Then drag and drop the files to it.
Oct 28, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
170 people viewed this question
Top SanDisk Computers & Internet Experts
Arora Singh
Arora Singh
Sandy Moore
Sandy Moore
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
