Question about Sony KP-51HW40 51" Rear Projection Television
Red screen with thin red lines
What can I do about this?
  • Sony Master
  • 8,617 Answers
That model has been known for the CRts being bad. If the lines are kind of running on an angle and slightly arched that could either be the red CRT or the Red CRT drive circuit board. If you remove the front speaker grille and access panel you will see a small control block with 6 dials on it, and 3 dials will have screen or G2 stamped on the box. Adjust the red down a little and see if that has any effect on the red lines. then let me know
Posted on Jul 25, 2008
2 Suggested Answers
SOURCE: LCD TV - RED LINE
I have a thin red vertical line on the left side of my Philips LCD TV
Posted on Mar 07, 2008
Thin red line running from top to bottom of screen
What is this thin red line that is on my screen whenever my ...
https://answers.yahoo.com/question/index?qid...
Sep 23, 2010 - There is a very thin red line going from the top of my computer screento the bottom, ... If it's a single-pixel-wide red line from top to bottom it's a failure in ....have thin red lines running down the screen??some are thicker than ...
Thin Vertical Red Line [Solved] - Acer - Displays - Tom's Hardware
www.tomshardware.com > Forum > Displays
Tom's Hardware Guide
Jul 12, 2013 - 5 posts - ‎2 authors
hi all i am having a Thin Vertical Red Line on my Acer LED moniter ... the screen is having a part fail(cable or the screen/control board it self.).
Why is there a straight vertical line going from top to bottom on ...
forums.androidcentral.com > ... > Samsung Galaxy S6 edge
Apr 15, 2015 - 7 posts - ‎4 authors
Just bought the Samsung Galaxy s6 edge yesterday. After I charged the cellphone for the first time and turned it back on there was this straight.
Jan 26, 2016 | Samsung UN60ES6100 60-inch LED TV
Horizontal Band of Thin Red and Blue Lines on Screen
Sound like your Y-Sustain board has one foot in the grave. The Y upper buffer and Y lower buffer boards go when the Y Sus Goes too...
Mar 22, 2014 | Panasonic TCP46C2 46 in Plasma TV
Samsung LE32C450E1W there's a red thin line going
try tapping your finger on edge of the screen where the line starts/ends... it works for me... its a lose connection normally with the rubber seals that have connections in them that lead to the circuit boards inside.... try it and let me know...
Feb 10, 2012 | Samsung Televison & Video
I have thin red line in the center of screen fron
If the line is present on all inputs, it is most likely a bad panel (screen). The screens are either not available or cost more than a new TV.
Not good news I know but at least you can save the $100 estimate fee.
Best of luck
Roety
Mar 29, 2010 | Sharp AQUOS LC-45D40U 45 in. LCD...
Red static in black background ~ thin line running down center
Robjrpena,
Did you find a solution to your "red dot" problem? I'm having the same issue :(
Thanks John
Jun 17, 2009 | Hitachi 50HDA39 50 in. Plasma HDTV
Desktop computer monitor (flat screen) has a thin red vertical li
Detach the monitor from the cpu and turn it on. If the same vertical line appears then take it to the repair centre.
Dec 17, 2008 | IBM NetVista PC Desktop
LCD TV - RED LINE
Feb 25, 2008 | Televison & Video
Red Line across Screen
sounds like you have a vertical sweep problem. Where the fault lies cpuld be the vertical output IC the verticle b+ feed, could be the capacitors in the vertical circuit?? Your gonna need to troubleshoot thr vrtical circuit if your not a tech thin my advise is to take the set to a pro for sn est. Good Luck
May 22, 2006 | Hitachi 36UX01S 36" TV
Sony KP-51HW40 51" Rear Projection Television Logo
53 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
