Question about Whirlpool Duet GHW9150P Front Load Washer
F-02 My washer displays F02 and is having draing problems. I have cleaned the hose and it still does not drain properly. What else can I do?
  • pcnchik03 Jul 26, 2008
    washer does not do the spin cycle.
  • dmsk Jul 26, 2008
    Error code F 02 also. Will not spin & makes a clicking noise. I removed a safety pin & some lint from clean-out & it worked fine a couple times, now the error code & clicking again. Help!
  • 5,911 Answers
Please read the following link. This explains what to do if you get the "F02" error code.
http://www.fixya.com/support/r615268-f02_error_code_whirlpool_duet_kenmore
If cleaning the drain hose is not clearing the problem for you, then you need to check the drain pump and/or the drain hose from the wash tub to the pump. These areas are notorious for clogging with debris.
Posted on Jul 26, 2008
What does F-02 flashing on the display of my Whirlpool Duet washer mean?
Hello & Welcome to FixYa
F02 is a drain error in your Kenmore washer, if the unit is unable to drain then after 4 minutes it will display suds and then F02. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Jun 11, 2011 | Whirlpool Duet GHW9150P Front Load Washer
F 02 code. washer won't drain properly
F02 is a drain error in your Kenmore washer, if the unit is unable to drain then after 4 minutes it will display sud and then F02. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
May 01, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet flashes F 02
The f02 error code is caused when the unit control thinks there is still water in the tub after it has tried to drain. If the washer is full of soap suds it will also display an f02 error code. You will need to use only name brand HE detergent. If your washer is not draining the water out you will need to clean the pump filter. I have provided the instructions below. Run the washer in a drain and spin to ensure the pump is running. If the washer has no water and no suds the problem will be either the pressure switch or a plugged pressure hose. To check the pressure hose you will need to remove the top and remove the hose from the pressure switch. Ensure the hose is clear by blowing into it. If the hose is clear I recommend replacing the pressure switch.
Jan 30, 2011 | Whirlpool Duet GHW9150P Front Load Washer
F02 Error message
57f1973.jpgUse a nutdriver (1/4th in) to get that bottom panel off.001354b.jpgaab6887.jpg
Jul 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a whirlpool duet HT washer. I keep getting the F 02 code and SUD right after. I have cleaned the filter and drain hose. It didn't fix it. I replaced the pump this afternoon. That didn't fix it. I...
Hi there I have found the code for you and hope this helps?
F/02 Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
Thank you for writing to fix ya
Feb 12, 2010 | Washing Machines
Washer has an F02 code in the middle of the cycle, which has stopped, and I don't have the manual.
F02 = Long Drain
"F/02" is flashed.
The most common cause is a clogged drain filter. Remove your lower front panel. The filter is located in the discharge hose before the pump (often white in color).
Remove the filter and clean out any debris (socks, nails, coins etc..)
If this is not the problem then here is directly fronm the manual.
* Check the drain hose and make sure it is not plugged or kinked.
* Check the electrical connections at the pump and make sure the
pump is running.
* Check the drain pump filter for foreign objects.
* If the above does not correct the problem, replace the pump.
Dec 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F02 Drain problem The drain hose has been checked, it's ok . Keeps showing F02 code. What's wrong?
HI There
Try this and let me know how that goes.
F/02 Long Drain
Thank you for writing to fix ya.
Best regards Richard
Dec 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet washer... code flashes saying 02 F ... Help!
F-02(Long Drain)
HI. This code is an indication of a failed drain cycle(Long Drain Issue). Kindly, follow the steps below to address this issue further.
If the drain time exceeds eight minutes, the water valves are turned off and "F02" is flashed.
Press PAUSE/CANCEL two times to clear the display.
NOTE: After four minutes the "Sud" error will be displayed, then four minutes later the "F02" error code will be displayed..
Possible Causes / Procedure
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Dec 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Fault problem
F02= LONG DRAIN
off and “F/02” is flashed. Press PAUSE/CANCEL two times to clear the
display.
NOTE: After four minutes the “Sud” error will be displayed, then four
minutes later the “F/02” error code will be displayed.
or kinked.
Feb 12, 2008 | KitchenAid KHWS02R Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
98 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
