Back to:
Tags:
Air Conditioners
Generic problem for all Whirlpool Air Conditioners
Why the air conditioner unit
posted by Daishalyric8 on Jul 25, 2008
why the air conditioner unit does not want to kick the compressor on?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jul 25, 2008
Not Rated (0)
hillbuck29
Rank:Guru Guru
Rating: 85%, 33 votes
It could be either mechanical,high voltage electrical or low voltage control issue.You may need a pro to find out for sure.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on why the air conditioner unit:
I don't want to Accept this solution
Can you Help with these Air Conditioners problems?
Air Conditioners
Failure of my ITT McDONNELL & MILLER UNI MATCH...
Air Conditioners
noises coming from the central heating pump which appears...
Friedrich SL24J30 Air Conditioner
In order to start the fan, I have to remove it form it's...
Air Conditioners
I have recently installed a Zoneline GE airconditioner in...
Air Conditioners
Bunn Ultra slushy machine has black goo leaking out of...
Loading problems.
Repair Service
Find Air Conditioner Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
