Cannot print to cannon imagerunner 1023. got an a message on the print log NG(#0853)
  • nboti2000 Oct 31, 2008
    ImageRunner 1023iF
    Networked, WEB interface works, ping works, will not print.
    Error message in log:
    1009
    Test Page
    user
    0 x 0
    10/31/2008 17:02:53
    NG(#0853)
I found a solution for this problem on an Canon IR 1022 in a russian forum (thanks Google language tools)
The solution was, not to use the PCL5 driver, but to download and install the UFR / UFRII drivers from the Canon support site. With this drivers, everything works fine.
Olli
Posted on May 14, 2009
How to fix NG in the log list of canon ir3225 that prevent it from printing document from pc
there was no code after NG.The print command is working from the pc but the canon machine ir3225 on the log list it shows the job no and all but in the result section it shows NG without any code.This Makes me headache ,please can any one solve this
May 23, 2014 | Canon imageRUNNER 3225 Black and White...
Cannon ir 1023 will not scan in windows 7 64bit
For the scanning you have to use the USB port and load the Tool Box 4.9 scanning software on the CD or from the Canon site. If you have commercial scanning software you will have to use the Scan Gear software as an interface between the scanning software and the copier.. Good Luck.
Aug 20, 2012 | Canon imageRUNNER 1023iF Black and White...
I buy this model plz tel me the funcatiion of this model ir 1023
Canon imageRUNNER 1023 Basic Operation Guide
IR 1023 is capable of copying, printing, scanning and faxing.
Please visit the above link and download/ save the Basic Operation Guide for ready reference in future.
Hope it helps! Good Luck!
CreativeTECH
Feb 18, 2011 | Canon imageRUNNER 1023 Black and White...
I have a Cannon 1023 IF machine and I am trying to send a fax and all i get is a NG message error..Coul you please tell me what can I do to resolve the problem?
Hi the first thing to do is check the fax line use a standard telephone plug it in to the fax line and see if you get a ring tone if you dont then there is an issue with the phone socket or line if you get a ring tone then you know it is an issue with the machine Now check the fax line cable from the machine to the fax line socket try a different fax line cable is the number you are calling a correct fax number if yes then you can try another number to fax and see if you get the same problem if you do then there could be an issue with the fax board .
As a last resort you will need to replace the internal fax board but it would need to be checked by a certified engineer
Feb 14, 2011 | Canon imageRUNNER 1023iF Black and White...
IR3025 can not print, Status NG
Try to enter service mode: * 2 8 *
COPIER
FUNCTION
CLEAR
ALL
OK
TURN OFF AND ON
NOTICE: WHEN YOU CLEAR ALL THAT MEANS THAT YOU WILL HAVE TO INSERT ALL SETTINGS THAT YOU MADE, LIKE IP, GATEWAY, EMAIL FOR SCANN...
May 06, 2010 | Canon ImageRunner 3025 Black and White...
Describe your canon imagerunner 1023 how to
1) on copier you have a button add. functions-something like *
2) with + or - trough the menu press OK at FAX sett. or under report sett.- If I recall its under Fax sett.
3) try to find report sett. then OK
4) you must enable the RX REPORT than OK
For transmision report you must enable TX REPORT
Jan 13, 2010 | Canon imageRUNNER 1023iF Black and White...
Canon IR2022i Error E744 003. Help.
The BootROM on the main controller PCB and the system software are for different models or are of different types. The BootROM is not mounted correctly, or a fault occurred during downloading or when downloading the system software.
Jun 04, 2009 | Canon CLC 1140 Copier
Cannon Image writer 2870 -trying to retrieve a confirmation log for the past week (todays date 5/22/09)
At machine you can select 'monitor'from the bottom of the screen and select the log for copy or print. If you have network access to the machine you can use the RUI, it's much clearer. Just type in the IP address of your machine and the RUI interface will be displayed. You'll find print, scan and copy logs easy to find there and print.
May 22, 2009 | Canon imageRUNNER 2870 Copier
IR 1023 iF goed on - doen not print
re-installed the driver after deleting as administrator - power user does not seem to allow certian vista installations.deletions - geez
Jan 26, 2009 | Canon imageRUNNER 1023iF Black and White...
6,648 people viewed this question
k24674
jasbo
jasbo
