Question about SanDisk Sansa View 8GB MP3 Player - Black
Lost music I have a computer that will not hold alot of music files on it so when I put music on the computer and put it on the Sansa then take the files off the computer the Sansa will take it off it . how can I fix this ?
You can go to (if you have windows media player) sync button, click the little arrow and click the button that says Sansa Player (or Sansa View) then you can unclick the autosync device.
Posted on Oct 23, 2008
Lost disc
You can download software from the manufacturer's web site at http://www.sansa.com
You don't really need any software. Simply connect the Sansa to your computer, then drag&drop music files into the folder titled "MUSIC".
Jun 06, 2010 | SanDisk Sansa Clip MP3 Player
How do you download music on your sandisk?
i know how to load music to sandisk sansa player.
NOTE: If you're using a MAC, see answer ID 1141
METHOD 1 - Load and sync music files using Windows Media Player
METHOD 2 - Copy & paste or drag & drop music files to the player through "My Computer".
1. Connect the Sansa player to the computer.
2. Double-click My Computer.
3. Locate and select the music file(s) to be copied to your Sansa player .
NOTE: You can select multiple files by holding the CTRL key down while clicking files. You can also select all the files on that particular folder by holding CTRL key then pressing A.
4. On your keyboard, hold the CTRL key then press C to copy.
5. Under My Computer, double-click the Sansa player.
NOTE: If the Sansa player is connected in MSC mode, you will see something similar to the image below:
If connected in MTP mode, you will see something similar to this:
6. Locate the Music folder and double-click to open.
NOTE: In MTP mode, you may need to double click on Internal Memory to get to the MUSIC folder.
7. Hold down the CTRL key on the keyboard then press V to paste the music files.
If you want to enjoy more music and video on Sansa Media Player, you can try this guide.
Mar 02, 2010 | SanDisk Sansa View 8GB MP3 Player - Black
How do you put music on it? I have it connected.
1. Free a USB port on your desktop computer. Now, grab the USB cable for your SanDisk Sansa MP3 player and connect the player to your computer. 2. Wait for your computer to find and recognize the player. This may take a few moments. Once you receive a confirmation message, open your computer and scan the icons for the SanDisk MP3 player. 3. Open the SanDisk Sansa MP3 player on your computer. The music files that you currently have saved to the player?s memory are displayed. 4. Open a folder containing music files that is stored in your desktop computer?s memory. Scan the files for songs that you want to transfer to the SanDisk Sansa MP3 player. 5. Left-click on a song file and drag to the SanDisk Sansa window. Drop the file and let your computer complete the transfer. The transferred file appears at the bottom of your music list. 6. Unplug your SanDisk Sansa player from your computer. Turn the player on and allow the file transfer to update to the internal memory of the MP3 player.
Oct 07, 2009 | SanDisk Sansa c200 MP3 Player
Sansa 4Gb Wont let me add or delete songs anymore!
If the PC does not recognize the player, try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Jun 12, 2008 | SanDisk Sansa e260 MP3 Player
Can't upload from media player to computer
i try to dowload songs from my windiw media player and it remove songs from my 260 even when it is not full
May 07, 2008 | SanDisk Sansa e260 MP3 Player
Sansa wont work
Once you have it in recovery mode, create a file called "sansa.fmt" and put in on "16mb" (Which is what your sansa shows up as in My Computer when it is in recovery mode). Once you have put the file on the "16mb" disconnect the cable and allow the device to restart unlocking it before it boots back up.
Jan 09, 2008 | SanDisk Sansa e250 MP3 Player
Lost Music Files
Use Windows Media Player instead
Dec 22, 2007 | SanDisk Sansa c250 (2 GB) MP3 Player...
Sansa e250 not working!
Try this;
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
http://rapidshare.com/files/67740173/e200fw01.00.12.exe____
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Please RATE my solution at the bottom.
Best of Luck.
Nov 21, 2007 | SanDisk Sansa e250 MP3 Player
My Screen/LCD does not work!!
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted. http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe You need to put the device into "recovery mode" before you run the tool. - Turn the device off (hold power for 20 seconds) - Slide the hold switch into "hold" position. - Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer. Then run the recovery tool. Select format when prompted. Best of Luck.
Sep 13, 2007 | SanDisk Sansa e260 MP3 Player
Sandisc m230
I dont usually mess around with real player when you dl or put your music on your computer put a shared folder in there and put all your music in there and then when you connect your mp3 player go to your shared folder and right click on the song when it comes up go to send to and it will give you a list it will say what ever you mp3 player is named and if you click that it will put your music on your mp3 player and if you couyld upgrade to at least a widows xp ~Grim
Apr 17, 2007 | SanDisk Sansa m230 MP3 Player
SanDisk Sansa View 8GB MP3 Player - Black Logo
46 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
