Question about Frigidaire PLEF398AC Electric Kitchen Range
Fridgedaire range f7 22 error
F 7 22 or 20 error keeps coming up
  • 639 Answers
Hi Van,
Happy to help you!
Go online to www.Frigidaire .com and you can enter your model #
and download the manual.
But I think that this problem will be solved only by service!
A & E factory service is good and nation wide!
1-800-905-9505
They answer 24/7
Thank you Neil
PS.Please do not forget to give me a problem solved rating
Posted on Aug 24, 2008
How do I clear a f 11 fridgedaire oven
Good Afternoon Friend, this is Z. I appreciate your post!
If you are receiving an error code F11 on your Frigidaire range, it typically indicates that your range has detected an issue with the runaway temperature (overheating). One of the best ways to determine if this is a false error code is to reset the power to the appliance by either unplugging it or flipping off the breaker for about ten minutes. If the error code persists, at this moment I would suggest connecting a professional to proceed further. Most likely the EOC (Electronic Oven Control) or RTD Probe (Resistance Temperature Detector) will need replacing. I hope this information helps to some degree.
Jul 31, 2014 | Frigidaire Ovens
Fridgedaire CFEF372EC range, right front surface element (dual) wont come on
This is from AppliancePartsPros.com:
"Take off the cover to your terminal block (where the plug wire connects) and use a multimeter to check for the correct voltage to the unit. Red to white and black to white should be 120vac. Black to red should be 240vac. Your L1 circuit (the black one) is dead so when you turn on one of the burners, the L2 circuit feeds into the L1 illuminating the display. It may be a loose connection at the block or inside the outlet. Sometimes it is the breaker that is bad. Try tripping them closed then back on a few times in case one has stuck open. Your range should work fine, once it has the proper voltage."
Can't vouch for it but, if you've already checked the control and the element, this sounds reasonable. Hope it helps.
Nov 23, 2013 | Kitchen Ranges
Igniters always on with a fridgedaire duel fuel range?
You should have a professional diagnose this. This unit should not have any clicking or ignitors on while not in use.
Dec 28, 2012 | Frigidaire FPGS3085KF Stainless Steel Gas...
Oven won't turn on
Most likely you ignitor went bad. Very common problem and it's normal corrosion wear and tear type of deal.
oven repair in orange county, ca
appliance repair orange county, ca
Feb 08, 2010 | Frigidaire FGF337BC Gas Kitchen Range
How to unlock the frigidaire oven range door and remove error F3?
How do you adjust the oven door on a Fridgedaire Gallery Series gas stove?
Jul 13, 2009 | Frigidaire 30 in. Electric Gallery Series...
Fridgedaire stove fgf337ebd f10 code
It is the board that has the digital clock. You may also have a key/membrane pad that is separate but connected to it with a ribbon cable. This connection is many times the source of the problem. The conector is sensitive to being loose and oxidation. Many times you can wiggle/clean and/or make sure the connection is good and it will clear up the error code. (Do All this with the Unit Unplugged), If that doesnt work than it would seem you have a defective ERC board,...Electronic Range Control. When you replace the board you should also replace the membrane/touchpad associated with it. This is what most brands/repair centers suggested
May 12, 2009 | Frigidaire FGF337 Dual Fuel (Electric and...
Fridgedaire oven element replaced and still no cookies?
If the surface elements work your ERC is bad.(clock).
If the surface elements do not work check the circuit for 220 volts.
Mar 14, 2009 | Frigidaire FEF336BC Electric Kitchen Range
I have an F5 error message..What does this mean....Fridgedaire es300
The failure code list says to replace your Electronic Oven Controll. Contact a Frigidaire parts dealer and check the price and availability.
You will need to give them your make and model number.
Buckle up! It may get expensive!
Jan 28, 2009 | Frigidaire PLEF398AC Electric Kitchen...
Fridgedaire frontloader error code E10
I think you still have the factory warranty, please connect the company which you bought your wash machine.
Jul 03, 2008 | Washing Machines
Frigidaire PLEF398AC Electric Kitchen Range Logo
466 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
