Question about Apple 15" PowerBook G4 Aluminum 1.67 GHz LCD Display (p/n 1002587) (661-3749 1002587) Mac Notebook
Screen Assy? what is a Screen Assy?
Screen assembly
Posted on Aug 08, 2008
My Grandson has a compaq presario V6000' When he turns it on ( either by Battery or Ac connection) the screen lights up for a second. then goes dark goes to windows intro then goes and stays dark. He...
hiya:) My opinion: If you can get someone to give you a free/cheap estimate of the cost to repair I would do it just to find out, but that computer is getting old and maybe is not worth spending any money on. Unless of course you want to fix it to give it to a younger grandchild and buy the older child a new one. Keep in mind a decent laptop is gonna be 4-600 dollars U.S. hope that helps and good luck:)
Jul 26, 2011 | Compaq Presario Notebook
Lcd screen lines in sony handycam dcrsr45. when i start camcorder there is vibration type lines in lcd screen,not white lines just picture and horizontal vibrations which are recorded in camera.it was...
The most common problem with this camcorder is the lcd cable assy. It is the cable that comes in from the lcd panel assy to the internal board assy. I have seen possibly 100 of these cameras and different models and this fixes it everytime.
I hope this helps.
Sep 05, 2010 | Sony Handycam® DCRSR45 HDD Camcorder
" " lens pops in & out twice & the screen says access then screen says turn power off and on again. Sony Cybershot dsc w55
this problum is related with optic zoom lenz assy its not work propally so thats why screen shows access problum pleae go to your nearst sony service centre & fix the problum or repair optic zoom assy
Feb 05, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
Service part number for washer arm and screen.
525014 SPRAY ARM ASSY
I suppose the screen you mention is the large round disc that is called the filter plate
527018 FILTER PLATE ASSY WS
Hope these are parts number that you asked for.
Jan 31, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
My JVC-GRd72 camcord - error cap lens error when cap is NOT ON
Replace the CCD base Assy on the optical block assy.
Sep 27, 2009 | JVC GR-D30U Camcorder
Show on the screen to reattach output bin. and i close and open the cover but still show on the screen.
You say you have opened and closed the cover, your error appears to be related to the output bin assy on the left of the printer. Remove and reininstall the output bin assy.
Sep 01, 2009 | HP LaserJet 4345mfp Printer
Screen Removal - Mitsubishi WD-62527
SPEAKER GRILLE Removal
Pull the SPEAKER-GRILLE away from the cabinet to remove.
SCREEN-ASSY Removal
1) Remove 10 screws (a) from the upper cabinet rear cover (3 screws on each side and 4 screws across the
top).
2) Remove screws (b) along the bottom of the SCREEN-ASSY (8 screws on 52 inch models, and 12 screws
on 62 inch models),
3) Unplug the LL connector to the front CONTROL-PANEL.
4) Lift the SCREEN-ASSY up slightly and then pull away from the cabinet.
CABINET FRONT DISASSEMBLY
Aug 01, 2009 | Mitsubishi WD-65735 Television
WHERE TO GET A RELPACEMENT SCREEN
Why not remove the screen assy and see if you can clean it?
Remove the speaker grill assy and remove the screws along the bottom edge of the screen assy. Pull the screen assy up and off and lay it on a clean sheet with the outside of the screen assy face down. Remove the screws that fasten the screen bracket assys in place and remove the screen brackets.
Your TV actually has either 2 or 3 screens. You can carefully lift them off the screen frame. Separate them and clean them using a solution of luke warm water and a few drops of dish washing liquid on a soft cloth towel. Wipe immediately with a dry towel. ( be sure to note the order the screens are in and keep the smae side of each screen as it was originally. By the way, replacing the screens is expensive. The 2 that do the work, the lenticular screen and the fresnel lens can cost up to $300 a piece, the third, a clear, protective screen can cost $100-150.
michtech
Feb 18, 2009 | RCA P52926 52" Rear Projection Television
Ge dishwasher
If your GE dishwasher is between 5-10 years old, you may try replacing the check valve piston & nut assy (about $14). It's located on the inside in the rear of the dishwasher behind a screen which is fastened by about 4 screws. Once the screen is off, you can easily unscrew the check valve assy by hand ... install the new check valve assy ... reinstall the screen with the 4 screws ... and save yourself $400 for a new dishwasher.
Apparently, the rubber cone in the check valve assy deteriorates over time and prevents the pump from fully draining all the water from the bottom of the d/w at the end of a cycle.
GOOD LUCK!!
Feb 02, 2008 | Dishwashers
Zeinth 50 inch screen projection tv
Very difficult to get into this unit. The front bottom metal grill pops off, but it is on very tight and requires some prying to get it off. Then the plastic grill right above it must also be popped off. Once these are both off there are several screws in the bottom of the screen assy. to remove and all of the screws around the back side of the screen assy must be removed. after all of the screws are remove the screen assy can fall right off, so make sure to hold it in place while last screws are removed. Now when removeing the screen assy it is bulky and requires two hanlers. While slowly pullint it forward there are a few plugs that must be disconnected. You now have access to the inside of the screen, the lens, and the mirror for cleaning. This is not an easy job and I reccomend a service professional.
Nov 14, 2007 | Zenith D52WLCD 52" Rear Projection...
Apple 15" PowerBook G4 Aluminum 1.67 GHz LCD Display (p/n 1002587) (661-3749 1002587) Mac Notebook Logo
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
