Question about Philips Magnavox 20MC4304 20 in. TV/VCR/DVD Combo
Magnavox MWD 2206A vcr/dvd combo
My dvd is fine on my unit. However, when i play a tape in the vcr all I get is a black screen. Can anyone out there help me with this ??? The dvd plays fine as I said>>
David M
You probable have a dirty video head...you can try a tape head cleaner tape/// they sometimes work.... if not you need to get to the video head and clean it with a liquid cleaning solution---
one of your tapes may have a bad spot on it causing the problem...if you clean it and use the same bad tape again you can cause the same problem again
Posted on Sep 24, 2008
When playing back vcr tapes on my magnavox ZV427MG9 A, i have a tracking problem with tapes recorded on slp. i get white streaks on the playback, and manual tracking does not help. tapes recorded on s
The VCR has at least four "heads" two are for 2 hr and two for 6 hour (sp and slp)
It is most likely one of the heads used in the SLP mode is slightly blocked with tape debris--heads need to be manually cleaned in the right way.
Jun 16, 2012 | Magnavox ZV427MG9 DVD Recorder VCR
Magnavox vcr/dvd combo the vcr part only plays for 8 seconds
What you have is called a transport problem in the VCR unit--the mechanism is either jammed or something in it that loads the tape is bad.
Every time it is used it cycles to self check the mechanism--if it fails it is usually a belt bad or a gear assembly not working.
Someone would have to open unit to see what is happening.
May 28, 2012 | Philips Magnavox MWR20V6 DVD Recorder/VCR
I record a DVD from VCR tape and try to play on another device
In my research, I learned about finalizing the DVD, which was a new concept to me. I looked that process up in the manual and it did the trick.
Nov 16, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Have a Magnavox DVD/VCR player Model MWD 2206A,
units like DVD's, have the tendency of malfunctioning if not used for quite sometimes.corrrect me if i'm wrong.but like automobiles needs tune-up, right?try power it on for some time, but not using it.if still not call a tech
May 13, 2009 | Philips Magnavox DVD/VCR Dual Player
Lost manual, can't get VCR to play
There are several Philips and Magnavox DVD/VCR combos that have sepearate video connectors for the DVD and VCR side. Double-check the yellow composite cable that is plugged into the back of your Magnavox - it should be plugged into an area that says either "DVD/VCR" or "VCR". If you are currently using red, green, and blue video cables, you will need to add a second video cable - a yellow composite would be easiest. The reason for this change is that red/green/blue cables will only operate the DVD side on most Philips/Magnavox players - that is just the way they decided to design them. If you happen to find a model number listed on the back of your combo unit, and have the model number of your television, I can take a second look at it, and tell you exactly which connections to make. Good luck!
-Tha Mp3 Doctor
Feb 14, 2009 | Philips Magnavox DVD/VCR Dual Player
Magnavox mwd2205 - VCR Function
grace0308, Many of the combo units have multiple video outputs and some, like the SVHS and RGB Component outputs, are for DVD only. Make sure that you are plugged into the proper video output. Play a tape and try them all.
Mar 08, 2008 | Philips Magnavox DVD/VCR Dual Player
My vcr won't play back
I have a Magnavox zv457mg9 DVD&VCR combo ,and the vcr records for a short period(10minutes) and then cuts off. This happens each time I try to record on the VCR. Any suggestions??
Feb 26, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Magnavox mwd 2206 dvd vcr player....shuts off with eject word across screen.
On a unit I checked with this same symptom, removing the top cover allows the unit to stay on and operate normally. There is some sort of sensor at the left middle of the chassis, which, when unblocked by any opaque object, allows the unit to remain on. A temporary fix (not advisable) would be to replace the top cover with a piece of clear plastic or taut saran wrap (no vent holes needed). It's unclear exactly where/what that sensor is from a cursory test. This is a work in progress on someone else's machine that I lack full access to.
Oct 27, 2007 | Audiovox VE1020 10.2 in. TV/DVD Combo
Philips Magnavox 20MC4304 20 in. TV/VCR/DVD Combo Logo
224 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
