Samsung UN40C5000 TV Logo
Posted on Feb 18, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to turn off display on bottom - Samsung UN40C5000 TV
Basuki Jrobenk
Level 2:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
  • Samsung Expert 177 Answers
  • Posted on Mar 18, 2011
Basuki Jrobenk
Samsung Expert
Level 2:
Mentor:
Answers
177
Questions
0
Helped
69445
Points
522
Hi, try this :
1. Switch on your TV set
2. Open menu, choose setup - plug and play
3. select language
4. enter pass code (0-0-0-0)
5. follow instruction until " home use and store demo" appear.
6. Choose "home use".
7. Follow the instruction agian untill plug and play setting finished.
Change from lcd moniter to view finder
Try this, in your manual at the bottom of pg. 229 that says, "If you turn off the power while the 'shooting settings display' screen is displayed, the same screen will be displayed when you turn on the power again. To avoid this, press the <INFO> button to turn off the display on the LCD monitor, then turn off the power switch."
The converse also applies. Get into the shooting settings display with the INFO button and power down. The display will come on when you power up again.
It also solved my problem of getting the mode selection button selections to show on the LCD when needed.
1helpful
Posiflex jiva tp5800 screen turned red on the bottom and now its black
This is related to the backlight of the lcd screen. It could be the light itself or the inverter. The parts are available: http://www.posiflexusa.com/SP_LCDRepairKit.php
Proton pltv- 3250 32 "lcd tv a friend gave me
To turn on the TV:
Turning the Display On and Off
There is a power switch on the bottom of the display and a power button on top. The power switch is used to cut off power completely, whereas the power button turns the screen off but
allows the remote to continue working.
To turn the display on:
1. If the power light on the front of the display is off, turn on the power switch on the bottom of the display.
2. Press the POWER button.
To turn the display off:
1. Press the POWER button.
2. If the display will be unused for an extended period of time, turn off the power switch on the bottom of the display and disconnect the power.
Please make sure you rate my answer 4 thumbs up! Thanks so much for understanding, it would be a huge help to me. I would be forever grateful if you could do this for me. If you still have a question or concern about this problem please just respond / reply to my answer here before rating my answer.
Thanks
Tim
I can find nowhere on the tv that has an on off button, just got this tv
of the display.
Allso go here for full manual:
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Display went blank during the self cleaning cycle
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
uiitu
2helpful
Nokia E66: Display issue (lining errors, turn on issues)
there is stripe inside the phone which is damaged , and has to be changed look for nokia care around
When I turn the camera on the display does not light up. I have tried a new battery and it still won't light. It is model EX-Z1050
You have to find the bottom in your camera that enables the screen display on. Try from the menu/setting bottoms. It is not because of the battery. The screen display option needs to be trun on.
Artgirl
Jul 20, 2008 • Cameras
How to turn off alternating display.
turn off the unit and push the entertainment button or the display button it will beep once flashing stops lol i had the same problome im not sure what button it is thought doesent hurt to try them all its the second one on the bottom of the unit under the display but the unit has to be off
3answers
Display Problem for Philips FR951PBK01 receiver
hey i own it too mine same thing but when i turn mine on i use the selector and the display comes back on so push power then spin the selector knoby thing it should work
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
