Question about Canon imageRUNNER 5000 Copier
The Cannon Imagepass L1 cannot connect to Imagerunner
We went into service mode & cleared a bunch of things out & now the imagepass displays the message "please connect imagerunner". How can we get the machines to "see" each other?
  • 47 Answers
Set service mode->copier->option->int-face->img-cont = 1
Posted on Jul 26, 2008
How to fix error e000001-0000 for canon ir6000
You can try to reset error code in service mode, but if the error persist after clear, you need to rectify the problem and replace fault component which is fairly fixing easy to do.
The problem can be in thermistor, sub thermistor or dc controller pcb, or ... call service!
To reset error code:
while ready to copy/showing the error code:
1) Press the user mode key ( * ) on the control panel.
2) Press the 2 and 8 keys at the same time.
3) Press the user mode key ( * ).
Choose: COPIER>FUNCTION>CLEAR>ERR
Turn off and back on the copier.
Jul 30, 2014 | Canon Imagepass L1 Print Controller For...
ImagePass-C1 Not Printing the Pantone Colors
you need a set of kodak cards to run full colour set up on your fiery print controller then you just follow the intructions
Oct 29, 2009 | Canon imageRUNNER C3200 Copier
I have a canon imagerunner 4080. how do it get screen where i can have the machine to test print solid color?
There is not a feature like that in user mode. If it exists, it would be in service mode. I do not recommend going into service mode as you can brick your copier.
If you can print to it, make a print job of a solid color using your PC. Otherwise make a copy of colored construction paper.
If you have a Fiery imagePASS controller, you can print color calibration pages. On the touchscreen use the -> arrow in the upper right and then select the printer tab. press the printer status button, press functions. use the menu from there to print calibration or configuration pages.
May 06, 2009 | Office Equipment & Supplies
Printing speed slow
Try to run a clear server on your imagepass. (unless that is what you meant by clearing RAM)
You also may wish to restart the M3.
If you have a support contract, ask your dealer to upgrade or reinstall your fiery system software.
Mar 27, 2009 | Canon imageRUNNER 105 Copier
Input IP address on IR C3220 with ImagePass-C2
go to printer tab then function then print pages then configuration page. and you'll see the ip address
Feb 11, 2009 | Canon imageRUNNER C3220 Printer
Printing problem on Canon IR3200
this is a common prob.. most of my users know wahat programs shift images and they adjust it accordingly... you may want to try some different drivers you may be using a pcl driver try a ps driver load accouple drivers up you can try the different ones go to imagerunner.com by the way if you have a print server on the back of the copier you should use the imagepass C1 or C2 driver
Dec 11, 2008 | Canon imageRUNNER C3200 Copier
Manual/Drivers and software for a Fiery on a Canon IRC3200
ok the driver for the printer is at imagerunner.com support/ drivers/ office-production then look for imagepass E-1 im assuming you have a print controller attached to the copier. i think you can also get the guides there also for the fiery... Not sure about manuals for the copier never looked
Dec 10, 2008 | Canon imageRUNNER C3200 Copier
Installation of printer fiery
Depending on the model of the imagePass controller attached to your 5000(L-1?), the drivers can be found here:
http://www.usa.canon.com/html/download/imagepass.html
Nov 01, 2008 | Canon imageRUNNER 5000 Copier
Connecting pre-networked ir5000s to imagepass L1
Hello copierhelp. I could have sworn I responded to your request before but "fixya's" records don't seem to reflect that. So here we go. Your controller should be able to have its firmware (ver 20.01 changed to 50.04) updated as opposed to replacing the controller. This does however require a tech that is recognized by Canon as being trained,certified and currently working for a certified service dealership. If that is so then the tech will have access to the unique tool required to upgrade your firmware. And the tech will have access to the web site that has the library of firmware available for your machine, which the "ServiceSupportTool" will use to complete the upgrade. Additionally, the tech will have to go into service mode on the copier and change the settings which tell the copier that it no longer in charge of its network interface and the L1 is in control. This answer may cause more questions and angst than you wanted, and I am sorry for that, but I truly hope to help you out. let me know if I was any help and if you need anything. good luck.
Oct 24, 2007 | Canon imageRUNNER 5000 Copier
Canon imageRUNNER 5000 Copier Logo
461 people viewed this question
old marine
old marine
