Question about Microsoft Xbox 360 Console
Xbox 360 ethernet port -not working usb??
I had a lightning strike near my home,while my son was on "live"
after putting the pieces back,seems the ethernet port is shot.
Question, Can I use a "usb to ethernet" adapter,in the front usb
ports to connect to my wired hub?
thanks
briang
  • stokeyboyo Apr 18, 2009
    hi,
    my ehternet cablee is plugged in but it keeps coming up disconected, i dont think nothing is wrong with the ethernet port
    have u got a solution
No the xbox doesnt work with the usb to ethernet adapter. i thought it would work also. and it turns out it does. this would be because you have to install the device drive for it to work, and you cant do this on your xbox. but radioshack sells ethernet ports for about $6 if you know how to switch them out.
Posted on Jun 17, 2009
NOPE JUST BUY ANOTHER ONE AT RADIO SHACK
Posted on Jul 26, 2008
What does E73 error mean?
E73 is the problem with your Ethernet port, that normally caused when a lightning strike and damages your Ethernet port but in stead from the power supply its through the Ethernet port.
Thanks
www.1RepairStop.com
Aug 28, 2011 | Microsoft Xbox 360 Console
How to setup xbox live
To set up the connection via a router unplug the router and the modem and turn off the 360. Connect an Ethernet cable to one of the out ports of the preexisting router then connect the cord to the back of your 360. Plug everything back in and turn and give the modem and router about 3 minutes to reboot.
Once you have given everything a few minutes to reboot you can turn the 360 back on. If you have already set up a gamer profile you will see the Xbox Live screen. If you have not set up an account you will be prompted to do so. All you need to do is follow the on screen instructions. It is a pretty cut and dry process and should not take more than 10 minutes of your time.
If you want to go wireless or you must go wireless you will need to get the Xbox360 wireless network adapter. The adapters are available at most stores that sell 360 games or you can order it online. Once you have the adapter unplug any Ethernet cable you might have plugged into the 360 then clip the Network adapter to the back of the 360. It is really easy to see where it belongs, but just in case, the adapter will sit right alongside the USB port which is right above the Ethernet port. Once you have clipped it in plug the USB cable that is attached to the adapter into the port on the Xbox 360. Flip up the antenna that is laying flat against the adapter and you are set, well almost set.
Turn on the 360 and head into the System tray. You will see Network options, go ahead into that screen and follow it through to the "Edit Settings" subcategory. The Network name should appear on a list of available networks. Select your network and enter the password, if there is a password. Exit out and you should be ready to play.
Nov 27, 2010 | Microsoft Xbox 360 Elite Console
I dont know how to set up my xbox live with an eathernet cable can you help?
Hi there
Turn off the Xbox 360 by pressing the power button on the front of the console. Afterward, shut off your modem by unplugging its power cord.
  • 2 Insert one end of the Ethernet cable into the Ethernet port located at the back of your Xbox 360 console. After that, insert the other end of the cable into your modem.
  • 3 Replug the power cord into your modem to turn it back on. Once it is active, press the power button on your Xbox 360 to turn it on.
  • 4 Navigate to "My Xbox" then "System Settings." Afterwards, select "Network Settings" then "Test Xbox LIVE Connection." You will be notified on-screen if the connection is successful.
  • Read more: How to Set Up Xbox LIVE with an Ethernet Cable | eHow.com http://www.ehow.com/how_6714462_set-xbox-live-ethernet-cable.html#ixzz0xBK8Zctz
    GOODLUCK!!
    Aug 20, 2010 | Microsoft Xbox 360 Console
    I have a Cayman 3347w wireless router and I am trying to use one of the wired slots to connect my xbox 360 to the internet. the xbox will not connect. is this router xbox compatable?
    Please try the following steps below;
    To make a router connection to Xbox LIVE:
    1. Before you connect any cables, turn off your router, modem, PC, and Xbox 360 console. (Unplug your modem from its power source to turn it off.)
    2. Connect one end of an Ethernet cable to the Ethernet port on your modem and the other end to the Ethernet input port on the back of your router.
    3. With another Ethernet cable, connect one end to one of the router's Ethernet output ports. Connect the other end to your PC's Ethernet port.
    4. With the third Ethernet cable, connect one end to another of the router's Ethernet output ports. Connect the other end to the Ethernet port on the back of the Xbox 360 console.
    5. Turn on your modem, then your router, then your PC.
    6. Make sure your PC can access the Internet. If not, you may need to configure the router for Internet access. For help configuring the router using your PC, check the instructions that came with the router.
    7. Turn on your Xbox 360 console and sign in with your profile.
    8. If this is the first time you've turned on your Xbox 360 console, see Create Your Gamer Profile to get started with both the Xbox 360 system and Xbox LIVE play.
    If you're unable to connect to Xbox LIVE, you can try to diagnose the problem right on your console. Go to My Xbox and open System Settings, then select Network Settings (setup XBOX using Automatic Configuration DHCP), Test Xbox LIVE Connection.
    Hope this helps!
    Mar 28, 2010 | Netopia Cayman 3347W-Ent Wireless Router
    Usb replacement for the xbox 360
    To save you all the bother of replacing the usb ports, did you know that there is another usb port on the back of the console above the ethernet port, I would just use that one.
    Remember thumbs up if this helps.
    Feb 12, 2010 | Microsoft Xbox 360 Console
    Have one ethernet for computer want to use xbox live so i take out the ethernet from computer and put it in xbox unplug wait plug back in turn still will not connect red x for modem
    You should get a cable/dsl router/switch or wireless cable/dsl router/switch and put it between your Modem and network nodes (IE your computer and xbox 360)
    So it is modem to router wan port
    Xbox 360 to router lan port
    Computer to router lan port
    You can purchase one cheaply at best buy
    look at this link
    http://www.bestbuy.com/site/olspage.jsp?skuId=8741365&type=product&id=1202648529130
    Jul 29, 2009 | Microsoft Xbox 360 Console
    Trying to hook up xbox360 to my internet to play online
    if your using a modem its possible that it doesnt have a Ethernet port....Check the back of your modem and you should see a port that says ethernet near it. Plug your ethernet cable to the port in the back of the modem where it says ethernet. With the other end you plug it into the back of your Xbox 360 (its located in back to the far left....it looks like a phone line jack). You should then have xbox live
    Jun 13, 2009 | Microsoft Xbox 360 Console
    Blackout in my house, Xbox 360 ethernet port broken!
    All the message means is it can't find the internet, so your internet must have went down.. your systems should still be working fine. I don't know much about using usb for ethernet, but that sounds like it would work no problem.
    Apr 04, 2009 | Microsoft Xbox 360 Console
    Why isnt my xbox connecting? i plugged the cble into the rouder and then put the other cable into the xbox and its not letting me connect.
    To make a router connection to Xbox Live:
    7. Turn on your Xbox 360 console with no disc in the disc tray.
    8. If you've already used your Xbox 360 system for offline play, the Xbox Dashboard will open to the Xbox Live area. Select the Xbox Live banner. When you see the Xbox Live Marketplace you'll know you're connected to Xbox Live.
    Jul 02, 2008 | Video Game Consoles & Games
    Xbox live connection problem ?
    is there an Ethernet Cable plugged in the back, or a USB Wi-fi adapter right below the Ethernet Port, or the 2 front USB adapters?
    Jun 02, 2008 | Microsoft Xbox 360 Console
    Microsoft Xbox 360 Console Logo
    4,316 people viewed this question
    Top Microsoft Video Game Consoles & Games Experts
    marley mcelhinney
    Tre Elkins
    Martin Murray
    Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
