Help!!! My son ripped out the power cord to my Acer laptop and messed up the power source inside the laptop itself. Now my computer will not charge and it will not turn on because the battery is dead. I don't know what to do at this point. Needless to say, I am so furious. The AC Adapter is fine but I need to find a way to fix my computer so I can continue my education online.
  • Melanie Tumbleston Jul 26, 2008
    Thank you for your help. I think its just the jack. I will have one of my computer guru friends look at it and go from there. Again, thank you very much.
    Genius:
  • 2,028 Answers
There's not going to be a simple fix for this. First check the jack on the computer to see if it's loose or broken. If so then the jack will need replaced. If not, then the problem will be with a power management system chip on the motherboard. Either way, the motherboard is going to have to come out in order to fix the problem. Hope for the broken jack, this is repairable and will run approx $100. If it's the power management system, then the board will have to be replaced, and that's expensive.
Posted on Jul 25, 2008
The battery on my laptop stopped charging, but was working for a over a week, then it was acting funny and slow.. I shut down moved to another room and it won't boot up! The light doesn't come on...
I think your power cord is bad. It probably was not charging the battery at all and so now all your battery power has drained since you were running on it. Once the battery power is drained and if the AC Adapter Power Cord is not working the computer will not boot because it has no power source.
Some AC Adapter & Power Cords have lights on them to let you know when it is plugged in if it is working. Normally when you plug the power cord in the laptop somewhere on the laptop lights up to let you know it is receiving power. Sometimes the light is where you plug it in, sometimes at the front of the laptop or right above the keyboard area.
I thing you need a power cord. And don't settle for one of the one size fits all (with a removable tip designed to fit any laptop) that the big box stores will sell you.
If your power cord is good and the laptop is not receiving power then the problem could be your DC Power Jack where the power cord plugs into the computer.
Maybe your DC Power Jack which is where the power cord plugs into the computer is bad. Take an ink pen and push the tip inside the jack and see if the little pin wiggles, if so the jack is bad. You'll have to take the laptop apart to fix it. Most times it is soldered onto the motherboard, so you will have to desolder the old and solder a new one.
Apr 03, 2012 | Acer Computers & Internet
I have an acer aspire 5734z-4836 is is plugged in but says not charging. also if i unplug the power cord from the computer it shuts off.
Remove your battery pack, and plug in the live power source, and switch on your laptop, just to test if the if your laptop turn on. If it does, your battery had reached end life usage, so you need to replace the battery pack.
Hope it helps.
Jun 30, 2011 | Acer Aspire 5520-5908 Notebook
Acer Aspire 5520 Power Problems! :(
1. Actually the problem is not with the charger / adapter!
2. The plug-in port / jack of the laptop has become loose.
3. Don't try to work out the charging by adjusting the adapter plug with different angles. It will just damage the plug-in port (the wire inside the port will become loose and unaligned)!
4. Contact the Acer authorised service center for repair / replacement of that plug-in port / jack in the laptop! It'll just cost some bucks!
please rate this advice if it helps....tc! :)
Jan 14, 2010 | Acer Aspire 5520-5156 Laptop
Son ran battery to zero after he broke power cord, now won't boot
Couple of things
First is to let it charge with the lid down for a few hours.
If that does not fix it then check that your son did not use the alternate display option FN F5 or FN F6 on the acers I think
If you still have no luck you might want to ask questions of your son before you take it to a repair shop
Aug 08, 2009 | Acer Aspire One PC Notebook
Power cord cuts in and out
There are two places the trouble can be happening, at the adapter plug or at the power jack in the laptop. To determine which one is causing the power loss, hold the plug in the computer steady with your fingers while you wiggle the adapter cable. (If you have access to a voltmeter you can measure the voltage at the plug while you wiggle the cable to see if remains steady.)
If the charge light flickers it's the adapter cord that's bad. Because the wire flexes so much at the plug, it can break inside the insulation and cause the power loss. You either need to replace the adapter or repair it by cutting off the bad end and installing a new plug.
If the charge light remains on with the plug held steady but flickers when you wiggle the plug itself, the trouble is on the main board in the computer. The solder connections at the power jack have broken from the plug flexing and need to be repaired. This involves opening up the computer and getting at the solder side of the main board. It's tedious but relatively simple. If you are not experienced with soldering on small electronics, leave this to a professional shop.
Apr 23, 2009 | Acer (56.04145.901) (5604145901) Power...
Battery will not charge nor is able to use AC power to stay on.
Hi everyone it seems to me that the DC connector is loose inside your laptops,try wiggling it about gently at the charger to laptop cord nearer to the dc socket to verify this.Only solution is resolder or new dc socket.
Dec 27, 2008 | Acer Aspire 3680 Laptop
Problem with battery or power cord?
it could be a short in the power cord or a lose dc jack in the back. what model acer is this for as power packs for them dont cost to bad.
Nov 29, 2008 | Acer (56.04145.901) (5604145901) Power...
Possibly powerplug!
The poor design of the power pin is a major source of problems on almost all laptops. Do a google search for power pin problems and you'll see what I mean.
Problem stems from jerking or tugging on the cable. Every laptop should come with a cable retention device to keep from damaging the fragile power pin.
This video has some pretty good information about it. . .
Dec 27, 2007 | Acer Aspire 3680 Laptop
Computers & Internet Logo
152 people viewed this question
David Payne
David Payne
