Cameras Logo
Posted on Jul 25, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
L.How important is it that I update firmware 1.0.4 to 1.08 on my 40D slr? 2. Is there an adapter that will work with FD lenses and the 40D?
old marine
Level 3:
  • Master 2,426 Answers
  • Posted on Jul 25, 2008
old marine
Master
Level 3:
Answers
2426
Questions
0
Helped
950637
Points
10742
The firmware update (Version 1.0.8) incorporates the following improvements and fixes.
1.Fixes a phenomenon in which Image Stabilization operation emits a sound when certain buttons are pressed, with the EF-S 55-250mm f/4-5.6 IS lens attached to the camera.
2.Fixes a phenomenon in which the Image Stabilization operation emits a sound from the lens when IS lenses are attached to the camera.
3.Fixes a phenomenon in which a part of the image looks unnatural when reviewed on the LCD.
4.Corrects errors in the Spanish and Norwegian menu screens.
So if your camera is working properly for your purposes, and you don't use any IS lenses, you don't really need to update the firmware.
In answer to your second question, I don't think so. All EOS cameras communicate with the lenses completely electronically, and so work with any EF or EF-S lens. You may be able to find an adapter which would physically match an FD lens with an EOS camera, but all settings would have to be done manually on both the camera and the lens, and it would definitely be trial and error. The metering function in the camera depends on receiving a lot of information from the lens to get the correct exposure.
2helpful
2answers
Lens mount fit
None directly. The T90 was the last Canon camera to use the older FD lenses. All newer Canon SLRs, film and digital, use the EF mount. However, by using an adapter such as http://www.rakuten.com/prod/adorama-canon-fd-lens-to-eos-body-adapter-with-correction-glass/216466533.html?listingId=120668308, you can use the old lenses on any Canon digital SLR.
Are the lenses from AE-1 slr cameras interchangable with a rebel t1i
No. They use totally different mounting system; FD on the AE-1 and EOS on the later autofocus models.
Adapters are not possible unless you're prepared to lose the ability to focus on distant objects, and even then the lens would only work as a dumb piece of glass as adapters do not transmit any information between the lens and camera and do not operate any of the mechanical lens couplings.
Sep 18, 2011 • Cameras
1helpful
I have a canon Zoom FD 70-210mm 1:4 lens off a SLR camera. Will it work with digital cameras?
No Canon FD lenses cannot be used on Canon EOS system cameras (all autofocus Canons except for the ancient and obsolete Canon T-series 35mm SLR's from the 1980's use the EOS mount).
There are very few cameras which can take them (35mm or digital) without some kind of expensive mounting converter which would include corrective optics.
If in good condition though it's a great lens and can be used on plenty of old Canon classic 35mm SLR models such as the AE1, AT-1 , AV-1 and Canon T-series, all of which are cheap//free and readily available.
Does a "Sigma APO DG
It will fit, but you cannot guarantee that it will be fully compatible.
Third party lens manufacturers have to reverse engineer the patented technology of SLR manufacturers and then arrive at their own alternative and non-infringing solutions. As a result, their lenses are only ever guaranteed compatible with the SLR models available at the time they were manufactured, and if those cameras subsequently have firmware updates then all bets are off.
Sigma do offer an update service on many of their lenses, but it's not free and the lens has to go back to them for modifications.
The only lenses you can be sure of being compatible are the original Canon branded models.
I have Cannon A-1 and F-1 Camera bodies, plus all Cannon FD lens. Can I buy a new Cannon digital camera and use a special adapter and use those older FD lens. I would appreciate any reasonable input. JD
No. The only adapters you can get either lose infinity focus or need corrective optics (expensive and reduce image quality) to preserve infinity focussing. The lenses will need to be manually stopped down for metering purposes and the body will only be able to use manual and aperture priority modes.
Also, with modern computer designed optics, using FD lenses on a modern digital SLR is like screwing an old glass bottle on the front and hoping to get sharp images. An exaggeration, perhaps, but you will get significant edge softness and chromatic aberrations and the contrast will be lower than acceptable and truly dreadful with optically corrected adapters.
Sep 27, 2010 • Cameras
1helpful
Will the lenses off of a t50 fit todays digital cameras
No. I'm assuming that you mean the Canon t50: these were the last Canon SLRs to use the FD mount and you cannot fit them to later models without adapters. Even with adapters they will not focus to infinity on most other SLR bodies and other functions may not work correctly (if at all).
Jul 12, 2009 • Photography
Can sigma lense fit to canon av-1 camera body
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Greetings!
Answer to your question is, ‘Yes’ we can. Use Sigma FD lenses.
As we know Canon AV-1 has electronically controlled AE (Automatic Exposure) & has a Canon Breech-lock lens mount.
Original generation of FD lenses featured a silver locking ring at the base. Only that locking ring turns to lock the lens to the camera body; the lens body remains still.
In the newer lens system which was introduced with this camera, the user has to line up the red dot on the lens, with the red dot on the camera and simply turned the whole lens clockwise until it clicked into place.
Note: FD-mount cameras could use FL lenses in stop-down metering mode.
Thank you & have a nice day.
Warm regards,
William
Will my olmpus lenses fit on a nikon n75 slr 35mm camera
Generally, the lenses used with the Olympus cameras will not be compatible with the Nikon cameras.
However, there are some converter adapters available in the market. You can look for the Olympus to Nikon converter adapters. These adapters will help you in using the Olympus lenses with the Nikon cameras.
2answers
What canon digital camera will use my old Canon AE1 fd lenses?
You can buy an adapter to use FD mount lenses on EOS mount cameras. See this page for more details.
2answers
I have an cannon SLR AE1 that uses film. I would like to know if there is a a digatol SLR body that I can put my lineses on.
No, Canon EOS models use a different type connection for its lenses (EF series) and thus will now work with the "FD" lenses from the AE-1
Dec 16, 2008 • Cameras
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
