Question about Gateway FPD2275W LCD Monitor
Monitor why are some flat screens full size and others aren't? having a 12" viewing area on a 17" flat screen is false advertising. right?
  • 3,940 Answers
Monitor sizes are measured on the diagonal from corner to corner.
A 17" LCD may have a screen width of 12 inches measured from side to side.
If you are measuring a old style CRT monitor (Cathode Ray tube) the visible screen area will be about an inch less as there is about 1/2 inch of plastic frame holding the CRT in the chassis. The manufacturer can advertise the actual size of the screen regardless of how much is actually visible to display information.
If you are talking about software not utilizing all the available screen area to display the image, that is an issue with the people writing the software code not keeping up with the changes in hardware.
In the past year or two, most displays have switched to the 16:9 and 16:10 wide aspect ratios while most web content is still written for the 4:3 old style aspect ratio. Eventually, software developers will catch up with cusrrent hardware.
Posted on Jul 26, 2008
  • IQUIT Jul 26, 2008
    Oh yeah, what do some show more area and others don't? LCD screens are hard wired for the aspect ratio they are designed to show.
    There are lower resolution LCDs WXGA for example is 1280 x 800 pixels and will show a larger image across the screen
    The higher the resolution, the closer the pixels and the smaller the icon and the narrower the web page will display. On a high resolution WUXGA LCD 1920 x 1200 pixel LCD, a standard web page will use less than half the screen width is the page is designed for 800 x 600 pixels.
A spot developed in center of screen next day black lines across screen from the original spot
it sounds like you have a small crack on your screen that has gotten worse over time, these black areas are where the lcd crystals aren't active anymore, unfortunately there isn't allot you can do apart from buy a new screen or put up with the black lines.
May 02, 2011 | Gateway FPD 1730 17" Flat Panel LCD...
Screen image size
Try Resizing The View Of The Screen With The Buttons On The Front Hit The Menu Button Then Re-size Buttons This May Help Try Both Width And Height
Jun 07, 2010 | LG Flatron L1750S 17" LCD Monitor
How do I adjust the 22 in. rectangular screen to prevent images from appearing wider than normal. For example, pictures of persons make them look fat and wide.
You can use any other image viewing software such as Picasa. It will open images at 100% size but you can change the size of images
Jan 02, 2010 | Dell E172FP 17" LCD Flat Panel Monitor
I woul like to have a bigger monitor? where to buy and how much?
I just purchased the Acer X233h widescreen monitor. I picked it up at Staples for 139. They had a sale on it. Not sure what normal price is. Anyway I couldn't be happier with the monitor. 40,000:1 contrast ratio and can run in full HD, 1920x1080. I will be using a Xbox 360 with the hdmi to dvi conversion to take full advantage of the HD. Regardless of not being in HD. The monitor is great for a lot of computing needs. Also I went from the Samsung Syncmaster 740N. Which is a 17" monitor. Going from that size to a 23" widescreen is a huge difference and watching movies is a better experience. Check it out for sure. Hope this helps!!
Dec 19, 2009 | Hanns.G Corporation HW173D Monitor
Problem with LG 700B
can u tell me alittle more of your issue,,
cos non flat screen would not just run half as its sync to all cant have 1 half without the other,,
can u see the whole screen just very small?
Sep 27, 2009 | LG Studioworks 700S 17" CRT Monitor
Envision EN 7100si LCD 17" flat screen
First try auto-adjust with the auto button on the screen
if not worked
Make sure she installed the envision driver. I jus saw it's a discontinued product. Also this product has a maximum resolution of 1280 x 1024.
If installed check her resolution. Right mouse click on desktop>properties>screen. Try alternate resolutions and see what happens but don't set it higher then 1280 x 1024 if possible.
Nov 28, 2007 | Envision EN-7100e 17" Flat Panel LCD...
Compaq Monitor Model 7600
There are usually controls, button or knobs, to "Stretch" "Move" "Pincusion" and others... have you tried this, as this is what it "Sounds" like to me from ya description? If there are NO controls on the front to accomplish this task, at the REAR of the unit there should be controls marked to show the function. Below is a link where ya will find a Manual that may help ya. http://www.retrevo.com/s/HP-7600-Monitors-review-manual/id/281ci552/t/1-2/
Aug 06, 2007 | Compaq FS7600 17" Flat Glass Monitor
Monitor problem
Replace video filter capacitor supplying voltage to RGB driver transistors like 47uf 160v.
Aug 05, 2007 | HP Compaq FS7600 17" CRT Monitor
Screen does not maximise automatically
reinstall the driver for your monitor or adjust the resolution in the desktop properties
May 14, 2007 | LG Studioworks 700S 17" CRT Monitor
Gateway FPD2275W LCD Monitor Logo
121 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
