Question about Tomtom GO 910 GPS Receiver
Flashing red cross on starting up
Hi i have the above fault on my go910. whole thing just crashed one day while using, the flashing red cross came on and havent been able to reset by hidden button underneath or get rid of red cross....please help
  • 515 Answers
My ps3 wont turn on and flashes red press once stops flashing pressed again and it starts to turn on (green light) then stops and beeps then flashes red
Hello
This is due to a hard drive fault.Try removing the hard drive and reinstalling it.
Also while it is out, use a can of compressed air to blow all dust from your ps3.
If the above does not work your going to need a new hard drive.
Oct 12, 2011 | Sony Playstation 3 (PS3) Console
Gps shows a blue screen with a picture of the tom tom with a red X on the screen flashing. what do i need to do?
Assuming that your Tomtom is a Go910 or similar:
The normal solution for this problem is to reset your device.
This is done by pressing the reset button (usually found at the rear of the device) for a at least 15 seconds.
Once you have done this, turn your machine on and the red cross should have gone.
Feb 11, 2011 | Tomtom GPS
Hi, My 3 year old (ish) ps3 has just crashed. The thing just shut down mid game and now when you turn on, the green light comes on for about 10 seconds and then it flashes red and switches off. Touch the...
I've recently had this problem with mine but more than likely it was my own fault. In the process of trying to figure out my problem I completely removed the internal fans, once I put it back together the problem that you just described occurred. I just put the fans back in about 20 minutes ago and now I'm back to my original problem. I know this doesnt solve your problem but atleast it might give you an area of interest to start with. By the way unless your an airhead you can take the system apart rather easily just remember the top cover slides off dont pry it off like I did lol other than that it might take a minute to figure everything out but its fairly simple. I wouldnt recommend taking it apart unless its out of warranty or your seal has already been broke.
Feb 10, 2011 | Sony Playstation 3 (PS3) Console
Will not start. i get a pulsating cross that will not go away
i had this same exact issue, i tried restoring and got a copying error, uninstalled every third party thing i ever installed, and i reset the device many times. alternatley i thought to manually reformat and reinstall the software but i dont have rights permission apparently. i no longer have the flashing "X" i have what looks to be a harddisk in the bottom left corner flashing?
Jan 21, 2010 | Tomtom GO 910 GPS Receiver
Is my tv broken? its flashing blue red green... blue red green.... remote wont work ive tried everything..... only thing is this happened about a month ago aswell i tried it after a couple of days and it...
It could be the video board but fist try disconnecting the TV from the mains (unplug it) leave unplugged for 20 minutes and plug in again and switch on, if you haven't tried this already. There are a multitude of faults that can occur when they crash (just like a computer). Otherwise if that doesn't work then it's a trip to the TV repair man. Good Luck. Mike.
Oct 27, 2017 | Televison & Video
Camera Crashes
hi
best is to use rechargable NIMH batteries of atleast 2200MAh or above
the red flashing light is a low batt indicator
cheers
pls rate if it was any help
Jul 05, 2009 | Kodak EasyShare C533 Digital Camera
My playstation 3 stays in the "standby mode" and does not turn on
its a power failure inside the ps3!!! You have to call sony to replace the system it will cost u 150.00 dollars unless ur still under warrenty goodluck because i had to get 3 systems from sony before i got one that worked just right
Mar 24, 2009 | Sony Playstation 3 (PS3) Console
Covergence out of alignment on 1/4 Vertical left side of screen
You need to manually adjust the alignment:
On remote, press Menu to get to the main menu
Then arrow down to "ADVANCED FEATURES"
Then press "enter"
Then Arrow down to "CONVERGENCE" and press "enter"
"Red Convergence" should be highlighted
Press "enter"
You now have Green, Red, and Blue overlapping crosses.
If Red is out of whack, use arrows to align
To toggle to blue (and back to red), press "VIDEO"
Then align blue cross
Once the crosses look aligned, and nice and white, press "AUDIO"
This will bring up the Advanced Convergence screen
This is a grid of the same overlapping colors
You have control over the Red and Blue
If Green is very out of whack, you'll need a repairman…
While the "target" is flashing, you can move it around the screen with the arrows
Place it over an intersection to adjust, then press "enter"
Now the "target" is steady (not flashing), and you can use the arrows move your color
When it's aligned, press "enter" again
Now "target is flashing, and you can go to the next square.
You cannot adjust every intersection.
Some areas need to be adjusted via the adjacent intersection
When you're happy with color you're working on,
Press "video" while target is flashing to change to the other color
Repeat the above (blue is much harder to see and adjust for me…)
When you're happy with the entire grid, start hitting "Menu"
Each press brings you back out one menu level, until you are out of them
Once you're used to the process, it should take no more than a minute or two.
Mar 02, 2009 | Mitsubishi WT-46805 46" Rear Projection...
My tom tom go910 will not activate? It will only show a piture of
The red cross means its been wiped usually. Connect it to your pc and go to my computer. Click on the tom tom logo and see what is on your device. The maps should be there in yellow folders. Copy and paste these in to a folder. Then reformat the device by right clicking on the logo and selecting fat 32. When done reset the device for 30 sec and connect back to your pc and install the latest version of tom tom home. You can then get all the fee updates, thhen go to add maps where you can put your maps back on from the folder you made
Nov 20, 2008 | Tomtom GO 910
Camera Turns off and flashes light soon after turning on then freezes
I have exactly the same problem and I found, that it is probably related to rechargable batteries. If I use normal batteries, everything works fine. Confusing is, that I used to use rechargable ones all the time, but errors started few days ago. I also have two sets of rechargable batteries, but both are useless now. Maybe that camera is getting old and it needs fresh 4x1,5V from normal batteries instead of 4x1,2V from rechargable ones.
Oct 01, 2006 | Olympus Camedia C-725 Digital Camera
Tomtom GO 910 GPS Receiver Logo
347 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
