Question about E-Machines eMachines Desktop PC
Won't start My off/on button light is stuck on but the computer won't start
  • lolololol Jul 25, 2008
    My friend's emachine t2895 is having the same problem
    i cant enter BIOS to try and fix it.
    i've tried the following keys/key strokes:
    f1, f2, f3, f4, f5, f6, f7, f8, f9, f10, f11, f12, tab, del(not the num pad one), esc, shift, insert, i tried holding down a key to get a screen that would tell me what to press, but nothing. ive tried holding keys, tapping keys, pressing them once, etc.
    it keeps saying boot from cd, then a blank screen comes, and i dunno what to do. i wanna enter BIOS so i can change it to boot from C:/ first, but i cant open it.
    can u tell me how to open BIOS? if not, any other way i can change the boot devices' order?
As far as answering rebel6's question, try to see if the cables going to the monitor are correct
Posted on Jul 25, 2008
Dvd stuck in computer
push eject button, slap the top of computer sould eject. the rubber type band that turns the wheel to open tray is worn out needs replaced
Apr 10, 2013 | Apple Televison & Video
Kindle Touch won't start
Bad battery, needs changed.
Nov 09, 2017 | Computers & Internet
I have a maytag dishwasher theres a 3 second button to hold in order for it to start but it won't start it's stuck on 3 second lite
hold the heated dry button for till that light goes out. then try to start. it is a child lock that is on
Oct 08, 2011 | Maytag MDB7100AWB Dishwasher
1994 toyota corolla brake lights won't turn off
Thanks for choosing FixYa and welcome. You need to check the brake switch. Your brake pedal contacts the brake switch when it is pressed down. There is a small button on the brake switch that activates the lights. It may be stuck or broke. Try to loosen the button first. If it won't, buy another one. They only cost a few dollars.
Sep 07, 2011 | 1994 Toyota Corolla
My monitor is stuck on a webpage!! The mouse won't move,I turn it off and back on and it is still on the same website?
It's not the monitor that's stuck - it's the PC. Press and hold the power button of your computer for about 10 seconds - this should force the computer to turn off immediately.
When you turn it back on, it will tell you there has been a problem, you can normally skip any errors that come up, and choose "Start Windows Normally". and it will return as normal.
Aug 05, 2011 | Hannspree Computers & Internet
Hi I have a Whirlpool dishwasher ADP5740, Condenser. My grandson pressed the start button before I had set a programme, now the light is stuck on the pre-wash and the start light is flashing and it...
If you have a reset or cancel button try that. Look in your manual for a reset
procedure or troubleshooting section. It is just stuck in a cycle and needs to be reset
or cancelled.
Marty Mouse just a housewife.
Jun 05, 2011 | Whirlpool 24 in. GU3200XTP Built-in...
The dishwasher has been running for 3 hours and seems to be stuck on 1 minute left. Upon opening, there was sudsy water remaining in the bottom, but the dishes looked clean. The washer just won't go to...
SHU 53 MODELS To start test program, press and hold both SCRUB WASH and DELICATE/ECONO program buttons, then turn unit on by pressing ON/OFF button. Initially, control module version # will be displayed (e.g./ ?21? = version 1 with jumper). When wash program buttons are released, lights above them will flash. To end test program, press ON/OFF button. To check each program indicator light, press its button. To check Cycle Countdown display, Refill Rinse Agent light and REGULAR WASH light, press REGULAR WASH button (press Delay Start button to test Cycle Countdown display alone). Cycle Countdown display will show ?88″ when REGULAR WASH button is pressed and ?8h? when Delay Start button is pressed. To start testing, press both the SCRUB WASH and DELICATE/ECONO buttons a second time. When testing has ended, Cycle Countdown display will show a fault using codes below. If more than one fault occurs, code numbers will be added together, (e.g./ ?6? = faults 2 + 4). 0 = No faults detected 2 = Heating fault 8 = NTC (temperature sensor) fault 1 = Aqua Sensor (?Sensotronic?) fault 4 = Filling fault F = Filling fault (display occurs during wash, not test) To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil, measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays at ~ 1.5-2 A, then heater, high limit or flow switch are faulty. If water level switch (f1) has failed (opened), display will show fault code ?4″ and unit will continually fill and drain where testing won?t be completed. If flow switch (e5) has failed (opened), display will show ?0″, water won?t heat (to 150?F) and water won?t stop circulating. If NTC probe (f2/f4) has failed (opened), display will show fault code ?8″ immediately and testing will end shortly after water has started circulating.
Aug 01, 2009 | Bosch SHU5315UC Dishwasher
E-Machines eMachines Desktop PC Logo
21 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
