Question about Canon imageCLASS MF8170C All-In-One Laser Printer
Canon imageclass MF8170C, error "insert Y cartridge"
The MF8170C keeps alternating between "insert Y cartridge" and insert all 4 c,m,y,k cartridge.
The cartridges are in the printer. Does this mean that all four toners are low or out?
thank you
  • jocelynilla Aug 29, 2008
    I've got the same problem--it keeps flashing the "Insert Y Cartridge" message even though all the cartridges are there. I've tried resetting it and reinserting the Y cartridge, but nothing's working.
  • lfis492aa Dec 16, 2008
    I have the same problem. first it was just the Y catridge message now all do it.
jackboy
  • 2985 Answers
SOURCE: cartridge jammed
Cartridges are usually simple click into place.
Refer to your manual.
I suspect none of us here can help further without actually examining your printer.
you could also try - www,fixyourownprinter.com
type your printer model in the field.
Also Canon customer support will may be able to point a way
Posted on Nov 26, 2007
SOURCE: toner not set insert toner message
The problem is with the paper tray not the toner, believe it or not. Take all of the paper out of the tray and then reinsert the paper into the tray. It should then work fine.
Posted on Mar 19, 2008
  • 3 Answers
SOURCE: Canon imageclass MF8170c print problem
I found that everytime my mf8170 would print only half the page it was because I was printing on the wrong size paper... try checking your properties and making sure that you are printing on the same size paper as what is in the tray you are pulling from.
Posted on Apr 22, 2008
  • 32 Answers
SOURCE: minolta 2430dl X toner not installed
If you are lucky you can just clean the contacts on the cartridges themselves and the "crum reader" and the printer will recognize the toner again.
The weakest part of this printer's design is the crum reader(part name "pushbutton switch" part number "4139630602").It isn't robust and you can easily bend the spring loaded contact through trying to clean it or with normal usage. Once bent or stuck it will no longer make contact.
The part is located in a white housing on the left hand side of the printer below the drum. To get at the part, remove two toner cartridges. Rotate the toner cartridge assembly around (push the recessed release button in the beige plastic right hand side under the main door) until the empty slots are by the crum reader (black piece with three spring loaded copper wires extending fromthe flat surface). You can now access the crum reader. It is held in by two clips one on the left and one on the right. Use a small screwdriver to pop it out, disconnect the ribbon cable and replace it. The hardest part is putting the ribbon cable back on the new part. The whole procedure takes about 5 minutes. Order extra crum readers so you have them on hand.
The normal Konica Minolta parts line can’t order this part. In Aug. 07, I called 800-622-5546 [2] [3] (orderadministration section) and ordered the part. It was $5.
Posted on Aug 02, 2008
SOURCE: no toner cartridge
same problem!
Posted on Oct 23, 2008
How do I clean a MF8170C laser printer
Canon web site down load user manual, unless you talking cleaning inside that might require service technician.
Mar 01, 2015 | Canon imageCLASS MF8170C All-In-One Laser...
Red alarm light flashes..Reads ...prepare a new drum
your drum unit is near end of life.
you will have to buy something like this
http://www.dura-toner.com/canon-ep87-drum-unit-cartridge-imageclass-mf8170c-mf8180c-drum-ep87dr.html?AdID=352--EP87DR-R
i am showing you just for example, search local stores for cheaper.
you can also give it for recycle, just find some toner refilling company near you.
Sep 19, 2011 | Canon imageCLASS MF8180C All-In-One Laser...
E021 error
hello,
this is error for the faulty developing rotary mechanism ( the mechanism that rotates the toner units ).
As remedy, you can try to check for broken parts, check if the motor turns the rotary assy, ... or call service!
Hope that helps!
Apr 27, 2011 | Canon imageCLASS MF8170C All-In-One Laser...
I am getting an error message - E071 on the MF8170C. I have no idea what it is.
I also had this error message. Cleaning contacts and restarting made me able to copy/print.
Aug 18, 2010 | Canon imageCLASS MF8170C All-In-One Laser...
Imageclass mf8170c - not printing clear
My friend, you have a good Tech Guy. I would suggest you speak with him before you speak to the guy that sells parts for your printer.
There might be stuff that can be done with your printer if you continued to fiddle around with it in your basement or garage, but alas, this is your office (your business?) ... can you afford to mess with it any more?
Be happy, listen to your Tech Guy, cut the loss, get a new printer. You might be able to recover part of your cost if you put your printer on Craig's list, e-bay or sell it for parts elsewhere or, donate it. Did I mention Be Happy?
Thanks for your question at FixYa.com
Jan 01, 2010 | Canon imageCLASS MF8170C All-In-One Laser...
Color imageclass mf8170c
You Cyan cartridge is getting low. Buy one now because there is no warning to when it decides to up and quit and you wont be able to print anything!!!!
Jan 23, 2008 | Canon imageCLASS MF8170C All-In-One Laser...
i have Image class MF 8170 c Just printing blank pages.no erro code
apear on display.
Jan 11, 2008 | Canon imageCLASS MF8170C All-In-One Laser...
System Error E197
I get that error sometimes, i called Canon they don't know any solution for that error code, i always fix it by turning off the machine and turn it back on, and it work just fine, but i keep getting it once every two week, its something has to do with the Voltage on the machine, it may not get enough power, or is getting more power.
Yara
Sep 19, 2007 | Canon imageCLASS MF8170C All-In-One Laser...
Canon imageCLASS MF8170C All-In-One Laser Printer Logo
580 people viewed this question
old marine
old marine
