Question about Canon Office Equipment & Supplies
BJC-85 will not print. Color cartridge will not move stays in parked position. Where is a repair center near Albuquerque NM
  • 3 Answers
Dont even try to fix it, it is cheaper to buy the i80. these portable printers are not cheap to fix, just cheaper to replace
Posted on Jul 25, 2008
I just recived a used BJC-85 its is printing fine in black and white but not color whats wrong
Try some of the following possible problems:
1. Make sure the color cartridges are installed correctly.
2. Make sure the cartridges are not expired. There should be a date on the sticker on them.
3. Make sure that the cartridges are clean. Sometimes the ink can build up on the cartridges and stop ink from coming out.
4. Go to Start -> Control Panel -> Printers and Faxes. Find your printer and right click, then press Printing Preferences. In the options there make sure that color is selected.
Apr 20, 2011 | Canon BJC 85 InkJet Printer
BJC-85 canon printer.....brand new cartridges both b&w and color. Error light chimes 8 times and won't print
1: Unplug Power Cord
2: Hold POWER and RESUME buttons
3: Plug in Power Cord
4: Release buttons after the printer starts up
5: Hold CARTRIDGE and RESUME
6: Press POWER
7: Release all buttons after the beep
8: Press CARTRIDGE 16 times
9: Press RESUME
10: Unplug the Power cord
Aug 07, 2010 | Canon BJC-85 InkJet Printer
BJC 85 not printing after head replacement
I have similar problem. Print head won't print, then I clean with alcohol, and get rid of old ink inside. But then head seems to just shut down. I have several print heads and printers that have plenty of ink, but head won't work. I refuse to think the print head will break so easily. I used my BJC 85 for YEARS with no problem whatsoever, and suddenly, since last winter, I have 4 printers that have stopped printing.
I usually end up just buying another used printer on ebay until that one stops printing.
Terry tlworkroom@lycos.com
Feb 28, 2010 | Canon BJC 85 InkJet Printer
Will not print
Check on Canon.com, for the users manual, When you install cartridges you hold the resume button for the number of beeps to identify which cartridge is installed. You can install one black ink or one each black and color but you have to tell the printer which is installed.
Dec 28, 2009 | Canon BJC 85 InkJet Printer
No yellow printing from my color cartridges
The nozzles that the yellow ink flows thru are clogged. Try the print head cleaning utility. Right click on the printer, select PROPERTIES, select the MAINTENANCE TAB and press the PRINTHEAD CLEANING button. If that doesnt work, turn off printer, open front cover and move the ink carriage toward the center. You should see a small rectangular cotton sponge pad thats covered with old inks. Put several drops of Windex on it so that its nicely soaked and return ink carriage. Turn on printer and run the print head cleaning utility again. Then let it sit overnight. The next day, try printing a test page.
Jun 17, 2009 | Canon BJC 1000 InkJet Printer
Beeps 3 times and power light flashes
I have not solved the problem. I just changed to a different printer. I had a bj50 printer and it use to do this and would change the printhead but they are expense and I have 3 different ones so believe it is something else that is wrong with this one.
Apr 18, 2009 | Canon BJC 85 InkJet Printer
Canon Bubble Jet Printer BJC85 will not respond at all
Three beeps means one of two things:
1. Your cartridge (print head, not the tank) is defective.
2. The printer main board or the cable between it and the cartridge is defective.
Nov 27, 2008 | Canon BJC-85 InkJet Printer
Canon printer bjc 85
you need a new printhead, either bc10 for black or bc-11 for color, you also need to check your owners manual to set the printer for the correct printhead type.
Dec 17, 2007 | Canon BJC-85 InkJet Printer
99 people viewed this question
old marine
old marine
