Question about Canon PIXMA iP2000 InkJet Printer
Waste ink absorber full
I've removed the sponges. Cleaned them out, dried them out completely and replaced them. I still get the warning signs. I then tried to reset the ink counter. I still get the warning sign that the waste ink absorber is full. Please help!
  • 4,041 Answers
Hi there try see if this will work
Reset ip2000
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 13, 2010
Pixma MP150 Waste ink absorber is almost full.
I had a similar issue recently with an Epson printer. I solved it by unplugging all cables and removing the outer casing (there were several screws, easily removed with a philips head screwdriver). You can then get at the waste ink sponges. Caution - wear gloves! dealing with printer ink is messy! Carefully remove the sponges and wash them out. Allow to dry fully before putting back into the printer.
Hope this helps!
Tom
Jul 22, 2011 | Office Equipment & Supplies
Open your printer.
To protect hands from Ink wear thin latex (or similar) gloves
Locate the Waste Ink Pads on the inside of your printer
. They are on the right hand side and are quite small.
You can remove the pads and the holder with a gentle pull
Using a tissue, soak up as much ink as possible and clean the area around the waste ink area
There is one more waste holder in the right back bottom of the printer. A kind of sponge. There are few screws and plastic parts to be removed and this sponge needs to be washed, dried and placed again. Be careful and patient. This is no understatement. Take a photograph (even with your cell phone) so you can trace back your steps. You also need to take care as you lift the slide/carriage. Below this you find 5 little springs.
Carefully replace the holder and the pads
. Close printer.
Whilst printer is disconnected from the mains power, press and hold the power button and reconnect to ac power
Release the power button
Press the power button again
Mar 03, 2011 | Canon PIXMA iP1800 Printer
The waste ink absorber is fll. Can I get one and exchange it?
Ink Counter Reset - Canon IP1000/1500
1st Option
1 Unplug power cord
2 Press and hold power button
3 Plug in power cord and switch on power - still holding power
button
4 Still holding power button press resume button 8 times
5 Release power button
6 Press power button to turn on
2nd Option
1 Turn off printer and disconnect power cable
2 Press and hold power button, reconnect power cable and switch power on
3 The indicator (LED) should be GREEN
4 Press and release resume button, still holding power button, the indicator (LED) should be ORANGE
5 Press and release resume button again, still holding power button, the indicator (LED) should be GREEN
6 Release power button
Oct 12, 2010 | Canon PIXMA iP1500 InkJet Photo Printer
"ink absorber is almost full, contact service center" - what does this mean?
Inkjet printer has waste ink absorber inside, sponge alike. The function of waste ink absorber is to localize and keep waste ink safe inside the printer and does not harm the electrical parts.
Waste ink is produced from print head cleaning process and borderless printing. When capacity of the ink absorber raise to about 90% then warning message appears.
You need to bring your printer to the nearest service center to get waste ink absorber replaced.
Source:
Printer Clinic: Printer Tips,tricks,troubleshooting
E-manualshop: Online source of service manual
Aug 08, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
Spillbläck full? What to do
It means that the pad that absorbs the ink when the heads are cleaned is full and if you use it more it will spill the ink over your desk. The official way to deal with that is to take the printer to a dealer and they will clean the absorbing pad and reset the warning.
You can do both yourself:
1 - to clean the ink pad: remove the cartridges and unplug the combo - the carousel should remain in the middle, leaving the pad in the right side visible; take the printer to your sink and pour water over it thru a pipe (try not to splash it everywhere) until the pad becomes white and the water that flows out colourless; allow it to dry thoroughly (at least 2 days in a hot environment).
2 - Reset the Waste Ink Volume Counter
1) Press Menu + Copy + # to enter SERVICE MODE.
2) Select TEST MODE.
3) Select 8 - PRINTER TEST in TEST MODE.
4) Select 3 - EEPROM CLEAR.
5) Select 0 - INK COUNT.
6) Press the OK key.
7) Press the Stop/Reset key (returning to the state of 3) and then press the ON/OFF key.
May 01, 2010 | Canon SmartBase MP360 All-In-One InkJet...
Cannot print
the waste ink container is full. The printer has a small container internally which has a piece of sponge in it. When the printer goes through a cleaning cycle, the ink used to clean the print heads is discarded into here. When the sponge gets saturated, the printer stops.. Most can be removed through a hatch on the base of the printer and can then be cleaned with warm water but be warned, the sponge will drip everywhere !! Dry the sponge and refit, then turn the printer back on..
Oct 27, 2009 | HP DeskJet F380 All-In-One Printer
Waste full
The waste ink absorber is a piece of sponge that (as its name implies) absorbs waste ink. On many Canon printers it an be removed if you are fairly dextrous. Wash it out and dry it and then refit. It may well be a fiddle but it will go back in.
The difficult bit is resetting the printer so that it knows the absorber is empty.
Do a google on resetting the waste ink warning for your particular printer (it's not the same for every Canon). It's done with various combinations of button pressing and light sequences and generally works first time (though one of mine took 4 or 5 goes before it actually reset).
Jul 26, 2009 | Canon Office Equipment & Supplies
Error code E27
take out long black sponge under print head. wash, dry, replace.
Jul 16, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Waste ink absorber
This is the ink counter reset instructions:
1. Service mode: Menu->Scan->Copy->Scan( one at a time in sequence)
2.Select "test mode"
3.Select "(8) ETC
4.Select "(4) EEPROM CLEAR
5.Select "(1) INK COUNT
6. press the OK button
7. Press the STOP/RESET button(returns you to the TEST MODE sub-menu
8. Press the ON/OFF button (which resets the printer).
There you go.
Mar 01, 2008 | Canon PIXMA MP760 All-In-One InkJet...
Canon ip 1000 waste ink reset
want the software tool to reset the waste ink level for canon inkjet printers
Apr 20, 2006 | HP LaserJet 1020 Printer
Canon PIXMA iP2000 InkJet Printer Logo
120 people viewed this question
old marine
old marine
