Question about Canon PIXMA MP470 All-in-One Printer
Printing blank paper
When i connect my canon mp470 to my apple laptop, and print out a page, it simply prints a blank sheet of paper! My ink is full and my printer is connected correctly, please help! thanks!
  • 1 more comment
  • amberfix Jan 06, 2009
    printer only prints blank pages
  • Anonymous Mar 12, 2014
    when trying to print from computer or photocopy a sheet on the printer alone the paper comes out completely blank.The ink cartridges are full and no errors are displayed.
  • Anonymous Mar 21, 2014
    Help me please
  • 3 Answers
Try a few things, your printer maintenance my need to be adjusted, such as settings. i have one at work and i hate it, canon printers are so non-user friendly. do you have both a black and a color cartridge in it, if so you will have to tell it in the maintenance settings, if you only have one or the other installed you have to put both in it wont print with only one cartridge. if you just bought it and still have everything that it came with...take it back and buy a lexmark.
Posted on Jul 25, 2008
Canon pixma ip1000 black ink stop printing suddenly
Based on your explanation I will try to help.
Your ink tank had run out. You can refill it through the bottom of the tank or just simply replace your ink tank.
Aug 11, 2017 | Canon PIXMA iP1000
Reading no paper paper tray is full
Instructions
  1. Check the display for an error message. If the display reads "Clearing paper from printer," the engine has detected a jam and is attempting to eject the jammed pages automatically. These pages will often be blank.
  2. Check the display for "Performing PRINT/STOP TEST" or "Performing SERVICE TEST." Either of these messages indicates that the printer is going through a test procedure that may eject blank pages.
  3. Reduce the amount of paper in the input tray if the printer is feeding multiple blank sheets at a time. The printer will pull extra pages through if the input tray is overfilled.
  4. Replace the paper in the input tray with the correct size if needed. If the 4600 printer detects the paper as an incorrect size for the print job, it may eject the paper without printing anything on it.
  5. Replace the ink cartridges if certain colors are blank on the page. Replace the black cartridge if printing a black text document that is coming out blank. The printer may attempt to print even if the ink level is low or empty, but will unable to print anything on the page, causing it to come out blank.
  6. Remove the sealing tape from newly installed cartridges. The tape covers the print heads and should be removed before installing the cartridges. If the tape is left on, it will prevent ink from getting on the pages as they print.
  7. Press the "Check mark" button on the control panel to enter the printer menu. Run a diagnostic so the printer can attempt to determine the cause of the blank pages printing. Press the up or down arrow to select "Diagnostics." Press the "Check mark" button. Press the "Down" arrow to highlight "PQ Troubleshooting." Press the "Check mark" button. The printer runs a diagnostic and returns to a ready state when done.
Jan 08, 2011 | HP LaserJet 4600 Printer
I have a Canon MP470 that pulls 1/2 sheet paper and then jams
Paper feed roller
cleaning
When paper does not feed
properly.
To clean the paper feed
Machine button
Oct 07, 2009 | Canon PIXMA MP470 All-in-One Printer
Won't print black when set for plain paper
Try removing all ink bins except black then you won't have any problems. You should also be able to go into your printer settings and select "Black and White" or "No Color" and it will print ok. Removing the ink trays is the easiest way though.
May 28, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Prints Blank Pages...even though ink is full.
problem is likely to be the print head, the ink can dry up inside the print head and block fresh ink from flowing.
you can get print head cleaning solution from ebay, which sometimes works, or else go here to get your replacement print head
www.kodak.com/gb/en/consumer/products/printing-supplies/printhead.../default.htm
the one i have is a clip in clip out part
May 03, 2017 | Kodak EASYSHARE 5500 All-In-One InkJet...
Canon MP600 not printing on full page - in upper left corner
I went to the Canon website and downloaded the drivers for the printer and it printed out right--on a full page.
Feb 14, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Blank pages
You might want to start by doing some general print quality troubleshooting, including printing a test page. The test page should give you an indication if you have issues with print cartridges. Also, some printers may not print at all if even one of their cartridges is empty:
Correcting Print Quality Problems
The other thing that occurred to me is that your document feeder could be pulling in more than one sheet of paper at a time, this means it would output blank sheets as well. Here's a web page that describes the problem and what to do about it:
Automatic Document Feeder Error
Hopefully the answer to your problem is available in those web pages. Good luck.
Sep 07, 2008 | HP OfficeJet 4215 All-In-One InkJet...
Lines on page
The effecds like 'banding' very often this happens when the ink is running low.
When you say 'full color' do you mean at the 'best' [i.e. most ink used] setting or the you are printing the image on a full sheet of paper?
How do your images appear when you print small, say wallet sized, single image only on the page? draft mode? Gray scale?
Jul 16, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Stops printing a full page picture half-way through and prints the rest on the next page in some random place. I have also had some problems printing text in the same way. The picture I am trying to print...
I noticed that when I restart Windows, I can print one sheet fine, the second sheet prints only half. Restart again, and I can print one more sheet.
My local Canon helpdesk proves as unhelpful as all helpdesks these days.
Dec 07, 2007 | Canon PIXMA MP600 all-In-One InkJet...
Printer won't print
I have had a similar problem to this: I have had a BJC 80 for nearly 5 years and carried it around with my laptop using Win 98 and a par - par cable. It worked beautifully and successfully - so much so that when i saw a number of ink tanks going at very cheap volume prices in PC World i picked up a lot of them. Changing to an XP meant that i had to keep on using the par to par cable via a docking station but prevented my use of it with my new laptop - so when i brought it out of retirement it gave the blank printing problems yoiu described. By checking some error messages that it expected a black cartridge (which is what was installed) i found that inthe setup the software indicated it defaulted to colour cartridges. By changing this on the computer, it still printed blank pages but by changing the cartridge to colour it sprang into life when the set up asked for colour. I tried 2 other print heads which i had (3-4 years old) but still blank paper when printing to a black cartridge. I am now awaiting a new black print head carrier to see if it makes a difference. When trying with my laptop using XP and a par - usb cable it does not work at all. I have removed the sware driver for the Canon 80 and manually installed the one for the Canon 85 but no luck in printing to par - usb at this time
S Ranson
Nov 13, 2006 | Canon BJC 80 InkJet Printer
Canon PIXMA MP470 All-in-One Printer Logo
330 people viewed this question
old marine
old marine
