Question about Honeywell Programmable Thermostat Heater
Honeywell ST6400C programmer
The boiler does not fire when hot water is selected although the red light is on. However, the boiler fires OK when central heating is switched on and this does then heat the water. Is the problem in the programmer?
  • fairfordmick May 11, 2010
    sounds like a wiring problem what type of motorised valve have you 3port or two 2ports
  • Honeywell Master
  • 3,238 Answers
Hi yes sound like it not working on hot water only it would check ou the wiring on this side
Posted on Feb 18, 2010
  • Steven Robinson Jun 13, 2013
    the red light comes on when hot water is selected and the boiler does as well, just the pump does not come on
Boiler ok for hot water but no heating
What boiler do you have and is the controller a radio controlled thermostsat
Dec 14, 2014 | Water Water Heaters
Failure of my Honeywell CM61ng wireless thermostat. Replacement advice
Probably not. There are replacement models available.
The T6661B programmable room thermostat is also known as CM61.
CM61 1 day wireless programmable thermostat is replaced by CM921.
CM61 1 day wired programmable thermostat is replaced by CM901.
Oct 21, 2017 | Heating & Cooling
Hi, I have a drayton lp522 programmer with a
go to boiler Disconnect red line and jump out White and red line at boiler if the fires reconnect red line and replace thermostat
Sep 23, 2013 | Heating & Cooling
ST6400C programmer, heating switched off. Switch hot water on only, tank full of hot water but pump runs and radiators get hot. Wall stat is set at zero. When programmer is touched and the flap dropped to...
Have had a lot of these programmers with this fault.Integral fault with electronics.Programmer will need to be replace as unrepairable.You should be able to find a straight replacement version from your heating supplier.
May 11, 2011 | Honeywell Programmable Thermostat Heater
The boiler does not fire when hot water is selected although the red light is on. However the boiler fires ok when central heating is switched on and this does then heat the water. Is the problem in the...
Hi. and you are correct, if the boiler fires when the controller is set for central heating to come on, but does not fire when calling for hot water, the controller is either faulty, or not programmed properly. This is what tells the boiler to do on command, so, this is all that it could be.If you no anything about this controller as far as how it is set up, is it a programmable one, voltage on it, does it have wiring terminals on it that are labeled and can you get to them? If you can, and the wires are labeled, you can jumper them out to see if you can bypass the circuitry and get it to fire up on a call for hot water. This is the way to test it, very easy. You have to look at the wiring schematics to find the wires that are 1-hot and 2- hot water control. Jump across the 2 wires and if it fires, the controller is faulty. Careful if this is a high voltage controller as 120/208/230 volt. Check this out first. It can still be done, you just have to be careful not to ground yourself out. It maybe 24 volts. If it is higher voltage, you can kill power and get a insulated lead/jumper wire with clips on each end. Clip them to the terminals you want to jump out and turn on power. This way you are not touching anything. Please let me know the outcome on this and please when rating me as being helpful to you, be kind. I thank you. I will be here if you have more questions or need my help.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor
Jun 17, 2010 | Heating & Cooling
Have hot water but no radiators. Checked pilot
sounds like your circulating pump is bad or electronic zone valves
Oct 26, 2009 | Honeywell Programmable Thermostat Heater
Honeywell ST6400C - hot water not working
some digital thermostats do no not work with zone valves is this a new thermostat that you had installed
May 08, 2009 | Honeywell Programmable Thermostat Heater
Oil fired boiler
Check how all three "on/off" sequences are programmed firsrt, then all other programmable options. Make sure sliders are in the sliders are in the correct possition. If it becomes more complicated than launching a space shuttle, reset it. Unless your house is a mansion keep it simple with just day and night modes. the money you save wont even cover the cost to fix the hole you punch in the wall trying to do fancy programming ;-D
Nov 24, 2017 | Honeywell Programmable Thermostat Heater
No hot water honeywell st6400c
HW valve was stuck in the open posiion and the micro-switch was not working so thats why boiler and pump were not starting. Bled system to below the level of the valve to be changed, and replaced valve with a drayton ( easy quick change of valve head if needed no screws )
Sep 07, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
1,189 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
