Question about Maytag Washing Machines
The buttons on the front of the dishwasher is not working properly. it is a maytag mdb8951AWQ
  • 1,028 Answers
Probably the console/control buttons they have been known to to may proper connection when pressed
Posted on Jul 26, 2008
Maytag dishwasher wont run
Make sure the door is closed tight and the lock leaver is fully lock.
Sep 27, 2016 | Maytag MDB7749AWW Builtin Dishwasher
Maytag PDBL390AWW buttons don't work
you should be able to retrieve the tech spec sheet behind the toe kick panel and it will give you steps to follow to find out which component is defective
Oct 13, 2012 | Maytag Dishwashers
My Maytag Dishwasher wont run
check to see if your float is work properly. the float is the little dome that sits in the front lefthand corner at the bottom. lift it up a couple on time gently and make sure there is no debris such as a spoon preventing the float bob from going all the way down.
Apr 17, 2012 | Maytag MDB6759AW Dishwasher
Myag dishwasher is not draining
Even though Maytag dishwashers range from simple to advanced, any type of Maytag dishwasher can potentially have a problem draining. In many cases, the failure to drain is directly related to a blockage and not caused by electrical or other operational problems. There is a high probability that you can repair a Maytag dishwasher that is not draining without the help of a professional.
Press the "Start/Resume" button on the front of the dishwasher if the dish-washing cycle was cut off before it was able to complete. Close the appliance door within three seconds of pressing the button.
Remove the screw that connects the drain hose to the disposal inlet. Place the tip of a flat head screwdriver in the inlet and along the top edge of the knockout plug, which is located just inside the inlet. Tap the end of the screwdriver with a hammer as many times as needed until the knockout plug gets moved out of its place. The knockout plug does not allow water to flow and causes the water in the dishwasher to backup.
3. Pull out the dishwasher and look for kinks or pinches in the drain hose. The hose must be free of defects to work properly.
4. Flip the switch to run the food disposal to ensure there are not food items inside that would prohibit the free flow of water between the disposal and the dishwasher.
5. Open your fuse box and flip the switch for the breaker associated with the dishwasher to the "On" position if it happens to be set to "Off" because of a power surge.
I hope you find it very helpful. Thanks for using fixya
Aug 11, 2011 | Maytag Dishwashers
Maytag mdbh970aws; s/n 23600314eg performance of front panel touch pad buttons has gotten worse. now the start/cancel button will not work. not sure if problem with control panel, ribbon cable to circuit...
if I may suggest its always worthwhile to go to scrap yard and look for the same model and swap the input touch pad as they wear away and no longer make proper contact or go to the website and find a replacement part good luck eric
Dec 24, 2017 | Maytag 24 in. MDBH970AWS Built-in...
"Start" and "Sanitzie" buttons on the control panel will not work
clean around the door locking mechanism, maybe it is not closing properly and it won't start until it does.
Oct 16, 2009 | Maytag Dishwashers
2 H Flashing
Seems to me you having problem with Touch panel. 2 H means 2 hours delay. It is shows up because for some reason control panel got overheat and stock. But after it cool down it start working again.
Nov 26, 2017 | Maytag 24 in. MDB7601A Free-Standing...
Electronics problem with Maytag Dishwasher
the outlet pump may have become clogged, try removing and cleaning it.
Mar 26, 2008 | Maytag 24 in. MDB9150A Built-in Dishwasher
My MDB7100AWQ has suddenly stopped working. It will fill but then stops and will not move into wash. When I press the drain/off button the lights work but it does not drain. I do hear a switch in the door operate when I press the drain/off.
Jan 21, 2008 | Maytag 24 in. MDBH950AWS Built-in...
Maytag dishwasher mdbh950awb
Sounds like you have a control panel and/or control board issue. Normally when operator functions fail or "halfway" work the main control board, associated keypad, or wiring are the likely suspect. Now...another remote possibility could be the door latch not closing properly. However, this would affect ALL functions. I hope this helps you.
Jul 31, 2007 | Maytag 24 in. MDBH950AWS Built-in...
Open Questions:
Washing Machines Logo
29 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
