Question about Gateway Computers & Internet
No operation system found..
I have brand new HDD and i dont know what is the proplem. It also says that there is media failuer, thank you
  • 68 Answers
Your brand new hdd have already an installation of OS?
Posted on Jul 25, 2008
F3-f100-003 error code what does it mean?
The new HDD apparently has no OS. what is what the msg says.
boot to Bootable media with to install a NEW OS. or boot to your Recovery Media. and let it restore to Factory.
if this does not help - then provide more info.
Jan 18, 2013 | Toshiba Satellite Computers & Internet
Computer wont boot error msg says media test failure check cable operating system not found
problem in your boot device.check your HDD is properly connected and working properly.
if HDD is good,you must install your operating system again.
Hope this will helpful..
Nov 22, 2010 | Computers & Internet
Iff i dont know my hdd password can i just change my hdd for a new one and it wont ask me for my password anymore? thanks...
HDD that has the Operating system will ask for password but if you have not enabled it then ideally there should be no problem with passwords till you activate it for new HDD ,if the case is ....like you have new HDD installed and old is replaced then PLZ dont get bothered about passwords as they are gone with old once!!
kindly rate this solution
Thanks And Regards
Feb 19, 2010 | Dell Vostro 1000
PXE-E61:MEDIA TEST FAILURE PXE-M0F:EXITING BROADCOME PXE ROM
hello, sounds like bad hard drive. here is what you can try, go in to BIOS and reset it factory default save and exit, let the system start again go back in BIOS and check to see if you see your hard drive there, also this time disable Boot from Network option. seeif your system actually starts up... or you get "no operating system found", if you saw the HDD in BIOS and get no operating system found, you can try reinstalling windows.
if you still media test failure and it loops, you need a new hard drive.
let me know if it helps...
good luck
Amar Sondhi
Dec 03, 2009 | Dell Inspiron 1501 Notebook
The ecrane proplem I just see white and some lines red and blue
just remove it ...and connect it to another pc ...and copy all your files
... see that the pc you use to have the same os ..and available port ...ide or sata ...depands of which kind your Hdd is ...it will see it right the way without any problems..the only issue is that it might see your operating system as well ...and prompt you to choose which one to start ...be sure you dont choose but the system from the pc you use...it wil specify the path ...hdd .... C? winouws ...the one ya have to choose isnt the one that bare your Hdd name ..
Apr 09, 2009 | Intel Computers & Internet
Toshiba Media test failure, operating system not found error
That message means it is not reading a drive. Most likely the HDD. I would suggest you replace the HDD. That is likely the problem.
Feb 20, 2009 | Toshiba Satellite M305D Notebook
PXE-E61: Media test failure, check cable
check your harddrive, is it detected in bios ?
if no, it could be motherboard or hdd, but most of the time is hdd problem, so just replace it.
if yes, your operating system is corrupt, so you can reload your operating system.
Sep 30, 2008 | Computers & Internet
Proplem Installing Windows XP Home media edition
Unfortunately, you will need to purchase another operating system disc, even though you have the product key. That key is assigned to the disc that came with the machine. Why exactly did the Xp disc of your father's not work?
Aug 21, 2008 | Toshiba Satellite A105 Notebook
PXE-E61 Media test Failure
hy i have your solution.its simple. the problem is remote network data entry that start in the bios systems, produce by a virus call downloader.trojan or bootable Tj.exe, normally the bios has to read it and it gives the error " media test faliurecheck cables",ir you dont repaired quickly your laptop or desktop eventually will not boot the windows att all, this have to be kill before that happens, First of all clean your pc with Trojan Remover and then do just a simple task restart your desktop or laptop and do not let it initiate windows just press F2 at the bios and go to the Bios program and then go to the tab name Bios and press F9 that means "default bios systems" and everything will change in your bios and when your desktop or pc restart it will never show that message again and your bios will initiate with no problems and the virus that put that into your pc will no longer control your bios system.
May 11, 2008 | Computers & Internet
Trouble Reloading Start-Up Disk on Toshiba Satellite 1905-S301
Please try changing the HDD. If same thing happens the problem may be with ur O/s Cd or the Mother board
Please let me know this is used machine or New one. If new one please take a different O/S cd and install it.
If you are installing XP and your HDD is SATA then you need sata drivers.
Mar 07, 2008 | Toshiba Satellite 1905-S301 Notebook
Computers & Internet Logo
37 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
