Question about Gateway Computers & Internet
Problem in wireless
Wireless intenet disconnect every 5 min i try make everything like make full recovery and i try reinstall driver i talk to customer support they tell me to send it by mail but it need 7 busniess day i need the computer i work in FOREX , so i want to change the computer in otherone the same specification or DELL i buy it before 40days .
  • Glenn Rogers
    Glenn Rogers May 11, 2010
    Have you examined the settings in Control Panel, Internet Options to see if there is a timeout setting in place?
    Worldvet
    Problem Solver:
  • 14 Answers
Troubleshooting wireless is often a multi-step process. Step one is always to bring up the STATUS window and sit there for 10 to 20 minutes (get a strong coffee first) and simply watch the signal strength. To do this (assuming you let Windows manage your wireless) right click on the wireless icon in the system tray in the bottom right-hand corner of your screen and in the pop-up menu click on STATUS. Note the number of bars that are green, sip coffee, repeat for as long as needed to confirm that there is no "drop out" of the signal received.
Step two depends on the results of step 1. If the signal droped out your problem is either the wireless transmitter, EMI or the laptop's ability to receive. More on that later. First, what was the result of step one?
Posted on Jul 26, 2008
No matter what I do I cannot get onto wireless internet. There's nothing wrong with the router, I've configured it for vistas, the signal is good so it says and it says it's connected to talk...
Try this solution. 1. Go to your device manager, try to disable your wireless network adapter for awhile and enable it again. 2. Then go to wireless gaijinproxy.gif signal and click Troubleshoot problems.Apply fixed if ask. 3.if failed go to your wireless status then click and diagnose.
gaijinproxy.png 4. If still failed go to your network properties and tried to enable automatic obtain an ip address. 5. Try to reinstal drivers of your wireless adapter. 6. If none of this work your chances are to reset your router try using a usb wireless adapter just to know if your wireless are low signal or not working anymore.
Sep 09, 2011 | Computers & Internet
Error 668 the coection was terminated
Usually associated with a 'choppy' or disconnected internet connection, for whatever reason - like the line outside your home, ISP problem - or incorrectly installed drivers /set upon your PC.
If the physical internet connection set up is fine on your PC ... cables- routers - - it can also be by driver problems. Try reinstalling the relevant drivers. It could also be a registry error.
Go first to http://download.cnet.com/Free-Window-Registry-Repair/3000-2086_4-10606555.html and download the free Windows registry repair tool. Run it when installed (takes about 5 mins to run).
If the connection still keeps dropping, try reinstalling any drivers you have - modem/router/wireless drivers etc
If the conneection continues to drop the problem may well lie outside of your hands - the ISP. It may just be a temporary problem.
Aug 14, 2010 | Acomdata PHOTON 2.5 (PHD080U2E54) Hard...
Netgear DG834 V4 constantly sending data
It means communication between computer LAN card and router is Ok and ready to use
you donot need to worry about that everything is ok
Please rate the service positively
Thanks for using fixya
Mar 27, 2010 | NetGear DG834G Router
The Broadcom wireless network adapter disabled after a windows update on Laptop HP with Vista. After I took the laptop to my job, to get the LAN *** fix it...the wireless was enabled...the switch shown...
first you can try and boot to the recovery partition by tapping F11 during start up.
then you can go to advanced options and choose Hardware/driver reinstallation.
then you pick your wireless device from the list. adn reinstall it and restart.
if that does not fix it try this:
remove your a/c cord and remove batter too
-hold power button for 30 seconds and dont let go
-then put battery back on and connect a/c cord
-boot to the BIOS by tapping F10
-when it comes up hit F9 to load it to default settings.
-then hit F10 to save and exit and check it
-if its still not showing up i would suggest a full system recovery
If a full system recovery does not fix it i would have to say you have to replace your wireless card.
Good Luck.
HP has an Extended Service on many of the models with wireless failures.Check whether your computer is eligible for a free repair.You will need the P/N and Model from the Service Tag on bottom.
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?docname=c01087277&dlc=en&lc=en&cc=us
Oct 10, 2009 | HP Pavilion dv2000t Notebook
Can't re-install 2Wire USB Wireless adapter
http://rapidshare.com/files/242493363/2wire_usbdrivers__allwindows_.exe
cut and past this in ya address bar, click free and wait like 45 sec then Dl it, feel free to scan it for virusis and all the bad stuff.
this are the same drivers i am using right now.
heres the drivers for ya 2wire. ill look for a file recovery program that works and post a link for you.
May 30, 2009 | 2wire (1000-100052-000) 802.11g/b Wireless...
No wireless settings come up at all
Oh yea I'm sure it had a lot to do with it..when you format a drive you lose everything including drivers. Check the device manager, look for Network Adapter, the click on the "+" to open If you see your wireless deivce then right-click on it and then choose to reinstall drivers..good luck, let me know how it goes and if you have any questions.,
Please rate this solution.
Mar 27, 2009 | Fujitsu AMILO PC Laptops
Black screen/acer laptop
try and reinstall the driver
if you have acer recovery open and reinstall applications
recovery if not on desktop will be in my computer or c:\ drive where you'll see a folder named Acer
Dec 26, 2008 | Acer Aspire 3000 Notebook
Mp3 players
try disconnecting usb and computer power cord for 5 mins. If computer is a laptop also remove battery at same time. Put everything together and restart
Aug 05, 2008 | Audio Players & Recorders
Acre 5520 laptop
Assuming already installed vista.
Just try doing flea power & the power cycle.
1. Disconnect all the peripherals like keyboard,mouse,printer,scanner & monitor and power supply from the CPU.
And press & hold the power button for 1 min, it will release the flea power from the mother board.
Restart the system & check.
2. Disconnect everything.wait for 5-10 minutes and then connect every thing & start the system.
Is it giving any error messages.
Try booting in to safe mode.
If it does then the issue is with something.
Do you have two video adapters.
Try boot from the dvd & run the recovery for vista.
or the system restore from the dvd.
At last run repair reinstallation using the vista dvd.
Hope it helps.
Good Luck.
Live, Love, Laugh.
May 10, 2008 | Acer Aspire T650 (AST650UC3601) PC Desktop
Computers & Internet Logo
44 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
